  The Mall
  Passenger side tail pipe hanger
Passenger side tail pipe hanger by Cliff Pennock
Started on: 11-03-2024 03:58 PM
Replies: 5 (126 views)
Last post by: Kitskaboodle on 11-10-2024 10:09 PM
Cliff Pennock
Administrator
Total ratings: 699
Report this Post11-03-2024 03:58 PM Click Here to See the Profile for Cliff PennockClick Here to visit Cliff Pennock's HomePageSend a Private Message to Cliff PennockEdit/Delete MessageReply w/QuoteDirect Link to This Post
Looking for the passenger side tail pipe hanger...
Vintage-Nut
Report this Post11-04-2024 09:41 AM Click Here to See the Profile for Vintage-NutSend a Private Message to Vintage-NutEdit/Delete MessageReply w/QuoteDirect Link to This Post
Rodney Dickman is still in business and these are "In Stock" as 9-10-24:
1984-1987 Stainless Steel Exhaust Hangers
https://rodneydickman.com/p....php?products_id=166
[This message has been edited by Vintage-Nut (edited 11-04-2024).]
Cliff Pennock
Administrator
Total ratings: 699
Report this Post11-04-2024 12:18 PM Click Here to See the Profile for Cliff PennockClick Here to visit Cliff Pennock's HomePageSend a Private Message to Cliff PennockEdit/Delete MessageReply w/QuoteDirect Link to This Post
Why are these so much more expensive than from the FieroStore? ($120 per set vs $40 per set)?
Vintage-Nut
Report this Post11-04-2024 12:51 PM Click Here to See the Profile for Vintage-NutSend a Private Message to Vintage-NutEdit/Delete MessageReply w/QuoteDirect Link to This Post
Cliff Pennock:
One Cost Difference is Steel vs Stainless Steel
TFS uses Zinc Plated Steel hardware which will rust over time
Rodney use Stainless Steel hardware which will never rust
Edit
Understanding the difference between steel and stainless steel will help you make an informed decision about which material is best suited for your needs and budget constraints.
The cost of stainless steel is generally more expensive 4X to 5X than common steel.
This higher cost is due to the addition of alloying elements such as chromium, nickel, and manganese to stainless steel.
If you’re looking for prefabricated pieces of stainless steel, then expect those prices to be even higher than regular steel which tends to be more budget friendly.
Keep in mind that regular steel is much more affordable but doesn’t offer the same level of protection against corrosion and rusting over time as stainless does.
[This message has been edited by Vintage-Nut (edited 11-05-2024).]
steve308
Total ratings: 57
Report this Post11-09-2024 09:04 AM Click Here to See the Profile for steve308Send a Private Message to steve308Edit/Delete MessageReply w/QuoteDirect Link to This Post
Good Morning Cliff. Most aftermarket exhaust companies carry a line of universal hangers. Also companies like SUMMIT stock hangers at a very competitive price.
Kitskaboodle
Report this Post11-10-2024 10:09 PM Click Here to See the Profile for KitskaboodleSend a Private Message to KitskaboodleEdit/Delete MessageReply w/QuoteDirect Link to This Post
That’s the route that I took. Went to Autozone and bought some generic exhaust hangers that were similar in size & length and made them work. Only about $8/9 dollars but you really do need to have a bench vise, bench grinder and a drill to shape / bend it into the shape you need. It was a little work but I’m too cheap to cough up enough money for even the FieroStore hangers. Besides, it’s going under the car. Who is gonna see it? 😀
Kit
[This message has been edited by Kitskaboodle (edited 11-10-2024).]
