  The Mall
  84 to 87 front lower control arm/A arm
84 to 87 front lower control arm/A arm by thelinsells
Started on: 11-17-2024 09:40 AM
Replies: 4 (131 views)
Last post by: zmcdonal on 11-19-2024 05:09 PM
thelinsells
Report this Post11-17-2024 09:40 AM Click Here to See the Profile for thelinsellsSend a Private Message to thelinsellsEdit/Delete MessageReply w/QuoteDirect Link to This Post
This is a quest to is if there is any intrest in total adjustable front lower control arm.The original is so limited as to not correct all alighnment angles.The new hand made unit projected cost is about $300.Is there enough call for a production run?
Wichita
Report this Post11-18-2024 09:22 AM Click Here to See the Profile for WichitaSend a Private Message to WichitaEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'm assuming $300 a piece or is it a pair?
Spadesluck
Report this Post11-18-2024 12:38 PM Click Here to See the Profile for SpadesluckSend a Private Message to SpadesluckEdit/Delete MessageReply w/QuoteDirect Link to This Post
Will this include a coilover setup?
gtoformula
Report this Post11-18-2024 02:58 PM Click Here to See the Profile for gtoformulaSend a Private Message to gtoformulaEdit/Delete MessageReply w/QuoteDirect Link to This Post
I don't have any idea regarding the interest in this product or the quantity of orders that you might anticipate. However, an adjustable lower control arm would provide a much needed alignment capability for our Fieros. Currently, one of the most popular methods of camber adjustment is using a slotted upper control arm balljoint. Moving the balljoint is not a particularly pleasant task. Caster adjustment is a rear PITA as it's somewhat trial and error and requires removal of the upper control arm shot to swap shims. Not fun. A lower control arm with, what I assume would be dual threaded adjustment capability, would allow for both caster and camber adjustments without having to remove any parts and could be done underneath the car. Good luck with your project. I may be interested if you go through with it.
zmcdonal
Report this Post11-19-2024 05:09 PM Click Here to See the Profile for zmcdonalSend a Private Message to zmcdonalEdit/Delete MessageReply w/QuoteDirect Link to This Post
Why an adjustable lower, and why not just buy adjustable uppers that are offered by both Pickardt Performance and West Coast Fiero?
I just installed one of Pickardt Performance's 84-87 front coilover kits with custom lower A-arm and adjustable upper.
[This message has been edited by zmcdonal (edited 11-19-2024).]
