On eBay: Polished Aluminum Trim Rings for the Fiero Instrument Cluster by Dido Tuning by Vintage-Nut
Started on | : 02-07-2025 09:39 AM |
Replies | : 15 (359 views) |
Last post by | : Vintage-Nut on 03-17-2025 12:23 PM |
Feb 7th, 2025
Vintage-Nut Member Posts: 1383 From: California Registered: Apr 2020
PFF member bjc 350 added these rings in a thread "Another Fiero made it to my house" / General Fiero ChatI'm only sharing the information... Dido TuningFor Pontiac Fiero 1984-1988 Polished Aluminum Trim Rings Instrument Cluster x2 POLISHED OR MATT ALUMINIUM SET OF 2 ALUMINIUM RINGS / SURROUNDS https://www.ebay.com/itm/225487420873?Edit - I ordered a set; my order total was $34.28 ------------------ Original Owner of a Silver '88 GT Under 'Production Refurbishment' @ 136k Miles [This message has been edited by Vintage-Nut (edited 02-07-2025).]
09:39 AM
cliffw Member Posts: 37505 From: Bandera, Texas, USA Registered: Jun 2003
I saw bjc 350's post. Nice look, though there is no chrome on any Fiero I remember. I think that if they had chrome surrounds on all instrument cluster gages I would buy a set.
10:53 AM
Feb 9th, 2025
jjd2296 Member Posts: 1469 From: toronto ON Registered: Jan 2016
this is perfect for my car, I already have chrome door lock slides and chrome HVAC knobs. if anyone is interested, the chrome lock slides are just from any olds/buick from the 80s and the hvac knobs are from a 698 camaro I believe, they are all factory fits.
10:57 AM
Feb 27th, 2025
FYI I ordered the rings on Feb 7 and received them from Poland yesterday, Feb 26
The rings are a friction fit and unfortunately, the rings I got are too small for the OEM holes by 0.07-inch Rings OD are 3.57-inch '88 OEM Panel ID Holes are 3.64-inch
I won't brother you with the fine details, however the manufacturer is sending a larger set.....
09:10 AM
crap, im waiting for mine to show up still. stay tuned.
09:26 AM
He had one panel and thought that all Fiero panels are the same.... I bet your rings will be 3.57-inch OD It's easy to remove the panel with four torx screws If the rings are too small, send photos like *these* and he will send you another set...
11:10 AM
Feb 28th, 2025
actually my rings just arrived and their too big! I then pulled two sets of instrument covers out of one of my boxes, one set the rings are too big, other set they are too small! It looks like there are a few different sizes of these dash covers that were made.
01:30 PM
Send him an email and request 'your' size...
02:52 PM
Mar 2nd, 2025
bjc 350 Member Posts: 967 From: Astoria Registered: Oct 2005
Mine were too small for the 84 car and also too small for the 88. After attempting to use their method of expanding the rings, to no avail, I used a few dabs of "Goop" marine adhesive and they stay in place fine. It seems they make a variety of these rings for many different makes as well as for other gauges and such. I think they add a nice touch. Might add a set to the digital dash in the 86, V8 car.
01:46 AM
IMSA GT Member Posts: 10595 From: California Registered: Aug 2007
They are from Poland so they use a different measuring system over there. A few bottles of Vodka and a carton of cigerettes before they use the metal lathe  And yes, my family is from Poland so I can joke about these things
03:47 PM
My rings at 3.6 od. The size on my dash is 3.36 inches.
04:12 PM
Mar 3rd, 2025
seller is making me another set.
11:47 AM
Mar 7th, 2025
reinhart Member Posts: 1121 From: Orange County, CA Registered: Mar 2002
If I were going to go this route would want all the openings to match, not just the tach/speedo (e.g. The gas, temp, oil, tach, idiot light openings)
04:11 AM
Mar 9th, 2025
ceverhart Member Posts: 250 From: haven ks usa Registered: Apr 2004
The set I received are too small, the compression ring would need to be cut pushed out 1/16 of an inch to hold them in place....Glue would probably work but I will not glue them since it is 88 dot matrix.
12:31 AM
Mar 13th, 2025
Dennis LaGrua Member Posts: 15661 From: Hillsborough, NJ U.S.A. Registered: May 2000
I believe the confusion here is that the Fiero gauge cluster panels were made in two or three different sizes. I found this out when I purchased a set of "wood" aftermarket dash panel covers. ------------------ " THE BLACK PARALYZER" -87GT 3800SC Series III engine, custom ZZP /Frozen Boost Intercooler setup, 3.4" Pulley, Northstar TB, LS1 MAF, 3" Spintech/Hedman Exhaust, P-log Manifold, Autolite 104's, MSD wires, Custom CAI, 4T65eHD w. custom axles, Champion Radiator, S10 Brake Booster, HP Tuners VCM Suite. "THE COLUSSUS" 87GT - ALL OUT 3.4L Turbocharged engine, Garrett Hybrid Turbo, MSD ign., modified TH125H " ON THE LOOSE WITHOUT THE JUICE "
02:32 AM
Mar 17th, 2025
Second Set Are Perfect! The key is to measure your panel ID before ordering, and then inform the seller your 'size'The thin edge of these rings can be easy 'folded' in the panel to hold them in.... https://www.youtube.com/watch?v=h0ROEy11C5A&t=103s EDIT - I'll get the OD 3.57-inch rings for FREE, but you will need to pay the shipping.... [This message has been edited by Vintage-Nut (edited 03-17-2025).]
12:23 PM
