  The Mall
  Cosworth SD4
Cosworth SD4 by michaelmount123
Started on: 03-23-2025 11:54 PM
Replies: 3 (208 views)
Last post by: RandomTask on 04-01-2025 11:17 AM
michaelmount123
Report this Post03-23-2025 11:54 PM Click Here to See the Profile for michaelmount123Send a Private Message to michaelmount123Edit/Delete MessageReply w/QuoteDirect Link to This Post
This is an IMSA GTP/L configuration 3.0L. Reconditioned by a top performance engine shop, and ready to go. It was prepared for a stillborn Bonneville Land Speed project. Have documentation and two Cosworth ECU's. I also have whatever you see missing in the photos.
[This message has been edited by michaelmount123 (edited 03-23-2025).]
Total ratings: 328
Report this Post03-25-2025 03:36 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
So what will you do with this engine? If it was configured for a land speed record, the RPM power band may not be suitable for street use. Also does it have the GM FWD pattern for the bell housing? That would be necessary for a powertrain swap. All things aside this is a very rare engine that you have there. If we compare this to the Cosworth Vega 4 cyl, those engines made less than 200HP and used sleeveless aluminum blocks. Those Vegas were quite fast for the mid 1970's
cartercarbaficionado
Report this Post03-25-2025 10:39 PM Click Here to See the Profile for cartercarbaficionadoSend a Private Message to cartercarbaficionadoEdit/Delete MessageReply w/QuoteDirect Link to This Post
probably dont have the cash required for this. whatca looking to get for it? i can tell its a gm bellhousing but not if its the early fwd or the high value bellhousing pattern
RandomTask
Total ratings: 150
Report this Post04-01-2025 11:17 AM Click Here to See the Profile for RandomTaskSend a Private Message to RandomTaskEdit/Delete MessageReply w/QuoteDirect Link to This Post
Is this located in silver spring? Interested. PM your number.
