  Totally O/T
  My new project... Teardrop Camper for pulling behind the Fiero... (Page 3)
My new project... Teardrop Camper for pulling behind the Fiero... by Synthesis
Started on: 03-28-2011 01:54 PM
Replies: 297 (19316 views)
Last post by: 84fiero123 on 07-05-2014 11:11 PM
tbone42
Total ratings: 127
Report this Post05-03-2011 03:11 PM Click Here to See the Profile for tbone42Send a Private Message to tbone42Edit/Delete MessageReply w/QuoteDirect Link to This Post
Urethane Construction Adhesive all the way
I would recommend, once the process is finished, carrying a tarp, bungies and some sort of sealant/tape for if leaks do appear while you are on the road. I am a long time RV camper, and we always carry duct tape and bailing wire when we camp.. its a must. I also use plumbers putty for temporary leak solutions (Great for temporarily plugging the leak in the rain..) and Eternabond for permanent. I doubt you would want to use eternabond if you are making your teardrop a woody.. it would ruin the wood finish and need redone. That stuff STICKS.
Again,
Synthesis
Total ratings: 290
Report this Post05-03-2011 08:25 PM Click Here to See the Profile for SynthesisSend a Private Message to SynthesisEdit/Delete MessageReply w/QuoteDirect Link to This Post
On with the show...
The spars are in, as stated.. Today, I framed in the bulkhead with 2x2 furring strips, and framed the counter surface for the back.
Yes, I know my rear profile is a bit... Blocky right now...
I have plans for this section, you'll see them soon.
Here is the rear of the trailer, framed in. I'll be doing some insulating and trim work. This is a quick and dirty build to get me on the road, and when I have more funds and time I will start a new slow build project. Teardrop time? I don't need teardrop time for THIS build.
I also got the first interior section of roof skinned. The hard part. Did it myself. Glued and screwed in place. It helps to be a former Defensive End with the added cushioning from the IT Physique (AKA I am a fat former football player. )
One thing you will see is that I have panel gaps on the ceiling skin on the edges. This was NOT intentional... Everything is glued and solid for the spars and side walls, but without solid bar clamps, I was unable to pull the sides together the way I wanted. I will attempt to remedy this when I can drive 80 miles and borrow some from a friend.. The joys of not having enough tools.
This thing is VERY rigid with the ceiling skin glued and screwed into place. All of my flex, which was very minimal to begin with, is gone entirely.
Here are the angle brackets I am using for my roof spars. I do not have them all installed yet, as I have deck screws in the ends of the spars, and the metal brackets are specifically for brace-work. They may not be needed at this time. I will install them anyway.
And, my favorite new tool.. This little guy makes placing and holding bulkhead frames a BREEZE... Align, tack a nail in on either side, reinforce with screws.
[This message has been edited by Synthesis (edited 05-03-2011).]
Synthesis
Total ratings: 290
Report this Post05-04-2011 08:25 PM Click Here to See the Profile for SynthesisSend a Private Message to SynthesisEdit/Delete MessageReply w/QuoteDirect Link to This Post
Update... No photos, but I finished framing in the rear galley "arch" on the side walls. I got the inner wall skins for the galley installed, glued and nailed into place.
I got the second sheet of ceiling skin installed. Had some minor fitment issues, but will be covering the seam anyway with a trim board, so no big deal to me.
And, I cut the 3/4" birch plywood "counter" to fit the galley. I then lopped off three inches on one edge of it, attached that to the galley framework with adhesive and screws, and then attached the piano hinge for the counter lid.
I am currently three sheets of plywood short of my goal to have this campable..
I have one 4x8 sheet of plywood for the roof skin, but this will not be enough for the roof. I need two more sheets to complete the roof, and one sheet to complete the galley bulkhead (cabin side)..
No finances for it, and not looking good for the rest of the month. We'll see what happens.
In the meantime, I can insulate the side walls and roof, attach the side-wall skins and attach the first roof section.
Once the side walls are on, I can treat them with Spar Urethane.
Synthesis
Total ratings: 290
Report this Post05-05-2011 03:25 PM Click Here to See the Profile for SynthesisSend a Private Message to SynthesisEdit/Delete MessageReply w/QuoteDirect Link to This Post
Photos of the tear as it sits this morning...
While I know this teardrop is not as pretty or detailed as some of the ones I have seen on here, I am quite happy with it.
I am pushing to get this done, as I want and need a functional camper that I can use immediately.
I grew up building cabinetry and remodeling homes with my family. I consider myself to be fairly skilled when it comes to wood working, but do not have the tools to complement that skill.
This is a budget build with a need for speed, as I need it ready for this year.
When I get more time/tools/money, I fully intend to build something a little more "quality".
On with the pictures.
The rear arch for the galley. Now you see the real profile.
The hinged galley counter...
The ceiling skin.
Synthesis
Total ratings: 290
Report this Post05-05-2011 07:49 PM Click Here to See the Profile for SynthesisSend a Private Message to SynthesisEdit/Delete MessageReply w/QuoteDirect Link to This Post
Synthesis
Member since Feb 2002
Got the two outer wall skins treated today.
50/50 Mineral Spirits Minwax Spar Urethane..
This is the first coat of 4 of the 50/50 mix, and then another 2-3 of straight up urethane, sanded in between.
Three shots, one before treatment, one after, and one close up of the grain. Click to view fullsize.
Zeb
Total ratings: 52
Report this Post05-05-2011 08:30 PM Click Here to See the Profile for ZebSend a Private Message to ZebEdit/Delete MessageReply w/QuoteDirect Link to This Post
If this is your idea of a quick, slap it together job, well, WOW. I can't imagine what you'd turn out with a good shop and some time.
Synthesis
Total ratings: 290
Report this Post05-05-2011 09:49 PM Click Here to See the Profile for SynthesisSend a Private Message to SynthesisEdit/Delete MessageReply w/QuoteDirect Link to This Post
Well, thank you.
It won't be professional quality, but it will be functional for what I need.
twofatguys
Total ratings: 227
Report this Post05-05-2011 10:04 PM Click Here to See the Profile for twofatguysSend a Private Message to twofatguysEdit/Delete MessageReply w/QuoteDirect Link to This Post
Synthesis
Total ratings: 290
Report this Post05-05-2011 10:51 PM Click Here to See the Profile for SynthesisSend a Private Message to SynthesisEdit/Delete MessageReply w/QuoteDirect Link to This Post
Work is on hold for the weekend... Have my court mandated visitation with the children this weekend (not that I don't want to see the children...)
The court has REQUIRED that I go up every two weeks and visit my children if I want any chance at custody of them, regardless of financial ability.
Joy.
Tony Kania
Total ratings: 305
Report this Post05-06-2011 12:08 AM Click Here to See the Profile for Tony KaniaSend a Private Message to Tony KaniaEdit/Delete MessageReply w/QuoteDirect Link to This Post
I know that is difficult for you, (I have read the story. ) but it is necessary. The courts can be unreasonable, and I believe that with some patience, you WILL get through this. The camper will only help. It looks great, and I wish that I could be there to help you.
If there is anything that I can do, just ask.
Tony
Danyel
Total ratings: 169
Report this Post05-08-2011 01:12 AM Click Here to See the Profile for DanyelClick Here to visit Danyel's HomePageSend a Private Message to DanyelEdit/Delete MessageReply w/QuoteDirect Link to This Post
Man I hope mine turns out as good as yours..... keep up the good work my friend
My build Thread
http://www.tylerstoy.com
Boondawg
Total ratings: 342
Report this Post05-08-2011 01:23 AM Click Here to See the Profile for BoondawgSend a Private Message to BoondawgEdit/Delete MessageReply w/QuoteDirect Link to This Post
Very nice indeed!
DeLorean00
Total ratings: 100
Report this Post05-08-2011 01:29 AM Click Here to See the Profile for DeLorean00Send a Private Message to DeLorean00Edit/Delete MessageReply w/QuoteDirect Link to This Post
That is coming together nicely!!
carnut122
Total ratings: 83
Report this Post05-08-2011 09:44 AM Click Here to See the Profile for carnut122Send a Private Message to carnut122Edit/Delete MessageReply w/QuoteDirect Link to This Post
Very nice job! Thanks for posting the pictures. Maybe I'm missing something( I don't know much about teardrops, except I want to build one to drag up the Alaskan Highway), but I'm curious as to why the counter top is hinged? I know what you mean by the lack of proper tools limiting the quality of what you can do.
User00013170
Total ratings: 224
User on Probation
Report this Post05-08-2011 09:59 AM Click Here to See the Profile for User00013170Send a Private Message to User00013170Edit/Delete MessageReply w/QuoteDirect Link to This Post
I have to agree it looks great. I assume you will paint it to match the car
Tho its already done, if it was me there is one thing id change in procedure: instead of manhandling the skinning of the curved sections, i think id build the 'frame' then use a ratchet strap of some sort to gently ease the wood down to the curve, then calmly attach it with screws to keep it down. Let the tools do the work, not my arms ( and i would wet/heat it first to reduce its tendency to go back straight.. its what i have seen done when they build guitar bodies )..
Synthesis
Total ratings: 290
Report this Post05-08-2011 06:53 PM Click Here to See the Profile for SynthesisSend a Private Message to SynthesisEdit/Delete MessageReply w/QuoteDirect Link to This Post
I wanted access to the foot well of the sleeping area for loading/unload/maintenance purposes.
With it hinged, I can slide a twin mattress through the opening and into the cabin of the teardrop without having to fight it.
Actually, I am going with a natural wood finish with several coats of high gloss Spar Urethane.
I am still debating what to do with the roof skin, whether I will leave it a wood finish, or wrap it in aluminum or even just an RV rubber roof style design.
I got one side skin attached today. I insulated the camper walls, and then ran adhesive all over the wall studs/foam board.
I aligned the skin, and then firmly attached it using the finish nailer with 1.25" finishing nails. Had some minor issues, but nothing an epoxy wood filler can't take care of.
The side walls have received four coats of Urethane, three thinned and one straight.
I plan to add another one to two coats after the epoxy filler has cured.
It looks GREAT!
Shananigans
Report this Post05-08-2011 07:37 PM Click Here to See the Profile for ShananigansSend a Private Message to ShananigansEdit/Delete MessageReply w/QuoteDirect Link to This Post
It coming along real nice,good job. I am partial to the aluminum skin because it has the classic look of the old time teardrops,and it looks great and not too awfully expensive, also easy to install. Seems the aluminum will last the longest with minimal maintenance and you can polish to shine as shiny as want or just leave it dull.
carnut122
Total ratings: 83
Report this Post05-08-2011 10:05 PM Click Here to See the Profile for carnut122Send a Private Message to carnut122Edit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks for the reply on the hinges. Now I'll be able to sleep at night.
OKflyboy
Total ratings: 86
Report this Post05-08-2011 10:15 PM Click Here to See the Profile for OKflyboySend a Private Message to OKflyboyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Lookin' good!
Synthesis
Total ratings: 290
Report this Post05-15-2011 07:42 PM Click Here to See the Profile for SynthesisSend a Private Message to SynthesisEdit/Delete MessageReply w/QuoteDirect Link to This Post
Not much progress in the last week, the weather has been horrible.
Did some today though with the weather as nice as it was..
I had to haul it in it's current condition down to the local Fleet Farm to pick up some stuff today that I could not haul in the car..
LOTS of looks, several Thumbs Up, and more than an hour of conversation with at least four different people about it when I finally got out of the store.
The right hand side skin, I attached it approximately a week ago. Urethane adhesive, panel, 1.25" 15g finishing nails. (I LOVE MY NAIL GUN)
Side profile of the car and camper... It is a bit taller than the car, but not by much.
First front skin attached. Several boo-boos as I tried to find the roof spars... I even had them marked and still missed them... WTF.. LOTS of screws holding it on. Nothing else seemed to have the holding power.
Down the side to show the glossy finish. I still have two coats of Urethane to put on after the nail holes have been filled with Epoxy filler.
The rear Galley area counter, showing the high gloss Urethane finish... Loving the way this is turning out so far.
Shot of the sanding work on the right side of the trailer. Almost into the wood, but not quite. This will be 2 more coats of straight urethane now that the filler has been sanded down.
[This message has been edited by Synthesis (edited 05-15-2011).]
ls3mach
Total ratings: 222
Report this Post05-15-2011 07:50 PM Click Here to See the Profile for ls3machSend a Private Message to ls3machEdit/Delete MessageReply w/QuoteDirect Link to This Post
Impressive job bud. Do you have a running cost to date? Less tools.
If 1 vest is thin, then rock 2 vest.
Synthesis
Total ratings: 290
Report this Post05-15-2011 07:51 PM Click Here to See the Profile for SynthesisSend a Private Message to SynthesisEdit/Delete MessageReply w/QuoteDirect Link to This Post
Not counting the trailer (100 bucks), I am sitting right around 650 in supplies.
Danyel
Total ratings: 169
Report this Post05-15-2011 07:59 PM Click Here to See the Profile for DanyelClick Here to visit Danyel's HomePageSend a Private Message to DanyelEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thats looking pretty awsome ... after much research mine will be a Reversed Teardrop because I do not want the kitchen part and more aerodynamic .. dont want to pull a brick along specially with a gas guzzling V8 ... It will be inside storage and the access door will be in the back with a window on each side and a top vent with fan ....
Keep going there Synth its really looking good !!!!
Here's a video of the shape mine will be ...
[This message has been edited by Danyel (edited 05-15-2011).]
ls3mach
Total ratings: 222
Report this Post05-15-2011 08:41 PM Click Here to See the Profile for ls3machSend a Private Message to ls3machEdit/Delete MessageReply w/QuoteDirect Link to This Post
Consider selling it?
Synthesis
Total ratings: 290
Report this Post05-15-2011 08:48 PM Click Here to See the Profile for SynthesisSend a Private Message to SynthesisEdit/Delete MessageReply w/QuoteDirect Link to This Post
This one? I was considering it after this summer/winter, possibly next summer building another one with the proceeds from this one.
I might if the price were right. There is a LOT of labor involved, and I still don't have Windows or Trim for the corners and the roof hinge.
The starting price for a "store bought" trailer from a builder starts around 5,000 for the very very basic model with no extras.
While nicely built, they don't seem to take the time to really make it a family heirloom quality, with proper sealing etc.. They last, but you really have to stay on top of them maintenance wise.
When I am done with this one, I expect to have to inspect it yearly, and make sure things are sealed and clean.. The drawbacks to "woody" style teardrops.
Aluminum cladding helps a lot, but hides water leaks and damage, where-as the woody exposes it before it gets to be too late and allows you to repair or catch anything that may be an issue.
avengador1
Total ratings: 571
Report this Post05-16-2011 11:58 AM Click Here to See the Profile for avengador1Send a Private Message to avengador1Edit/Delete MessageReply w/QuoteDirect Link to This Post
Guess what one of the prices was on The Price Is Right today.
www.golittleguy.com
Here is a place that rents them.
http://youcampwerent.com/
[This message has been edited by avengador1 (edited 05-16-2011).]
Synthesis
Total ratings: 290
Report this Post05-17-2011 01:52 PM Click Here to See the Profile for SynthesisSend a Private Message to SynthesisEdit/Delete MessageReply w/QuoteDirect Link to This Post
Close enough I can start looking at the final trim work for the galley edges, seals, doors, etc...
My final over-all cost for the camper, after the cost of the trailer, the materials, the trim, is going to be around 1400.
I knew it would be pricey, but did not expect the aluminum trim to add up that much.
Synthesis
Total ratings: 290
Report this Post05-23-2011 07:55 PM Click Here to See the Profile for SynthesisSend a Private Message to SynthesisEdit/Delete MessageReply w/QuoteDirect Link to This Post
Remainder of items needed ordered...
Today I gave the walls their final Urethane coat, laid out the rubber roofing and trimmed it, and then glued it in place.
Tomorrow I hope to be able to begin mounting the roof edge trim and sealing the roof in. I will have to cut the hatch framing and get the hatch started. Should have the hinge by Friday so I can get the hatch hinged and mounted. SOON!
Synthesis
Total ratings: 290
Report this Post05-23-2011 10:54 PM Click Here to See the Profile for SynthesisSend a Private Message to SynthesisEdit/Delete MessageReply w/QuoteDirect Link to This Post
Synthesis
Some progress tonight!
I sanded the roof seam down after hitting it with some filler this weekend.
I also sanded both sides again, gave a light wipe-down with mineral spirits, and gave them their final coat of Urethane.
After cleaning everything off and giving it a once over, I then rolled the RV EPDM rubber roof out over the main roof.
Since my hatch is not installed yet, I ran three screws into the wall framing about 7 inches below the rear edge of the roof, below where the hurricane hinge will be located. This held the rear of the skin in place while I laid it out where it needed to go.
Once I got the roof aligned, I flipped the front back up and over the back so I could apply the EPDM Latex adhesive.
This adhesive allows two forms of application.
Dual surface contact, or single surface pressure.
Since I was doing this myself, I opted for the latter, where you coat the wood surface, immediately lay the EPDM down, and smooth it. After approximately 30 minutes you brush the roof firmly with a push broom to press everything into place.
I applied putty tape along the very edge of the roof before laying the edge of the EPDM over the side. I pressed the EPDM into place over the putty tape, and then began measuring the front radius for the roof edge molding.
My front radius is 24 inches, and since my walls sit flush with the top of the trailer, I have an idea in mind for the lower trim along the trailer.
I have some T6061 1/4" thick by 3 inches wide that will go side to side across the trailer just below the edge of the plywood. The EPDM roof will come down below the wall line and overlap the front of the trailer frame with putty tape underneath it. Then, there will also be putty tape over this behind the T6061. This will be attached using self-tapping screws into the trailer frame and provide a weather tight seal for the very lower front edge of the trailer.
Back to the topic of the radius... The roof edge molding is powder coated extruded aluminum, and since I want to overlap the T6061 at the front lower edge, I measured 27 inches from the end of the roof molding, and began marking every 1 inch. A total of 36 cuts were made.
This allowed the roof edge molding to contour to the frame. It overlapped the EPDM flap sticking off the side as well.
I applied another strip of putty tape immediately between the EPDM and the roof edge molding, and then ran some lathe screws through the molding, the first layers of putty tape, the EPDM and the second layer of putty tape. Why Lathe screws? They have a flat, wide head, rather than a tall head.
Then, I trimmed the majority of the rubber back (as seen in the picture of the cuts above, and the following picture.
After the EPDM is trimmed back, I will mask the wood and roof and touch up the cuts with some white "Appliance" enamel, then I will run some clear "50 year" silicone caulk into the cracks as well as under the edge of the trim against the wood.
1988holleyformula
Total ratings: 68
Report this Post05-24-2011 12:01 AM Click Here to See the Profile for 1988holleyformulaSend a Private Message to 1988holleyformulaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Ohhhh, EPMD, not EPDM. Sorry.
Good looking camper there Chris! Still reading every update!
Synthesis
Total ratings: 290
Report this Post05-24-2011 08:24 PM Click Here to See the Profile for SynthesisSend a Private Message to SynthesisEdit/Delete MessageReply w/QuoteDirect Link to This Post
More work.
The roof is officially done, except for the roof vent.
I may wait on the vent for a few weeks, as funding is very tight.
The trim strip along the lower front.
The rubber roof lays over the front of the trailer frame with putty tape sealing the roof to the frame, then the aluminum bar stock with putty tape behind it sealing the screw holes and the aluminum to the roof.
The side roof edge trim has the two layers of tape, one above and one below the EPDM sealing the ends as it overlaps the aluminum strip.
Gratuitous roof shots:
Installing the first of the bulkhead panels.
I laid the rubber roof flap between the frame and the bulkhead panel. The hurricane hinge will cover the top edge, the EPDM will help trim out the hardwood spar that supports the hinge and hatch.
Shot of the galley counter with hinge.
I appreciate any and all feedback. This is my first Teardrop build, and my first major non-car project that I have ever taken on by myself.
Boondawg
Total ratings: 342
Report this Post05-24-2011 08:44 PM Click Here to See the Profile for BoondawgSend a Private Message to BoondawgEdit/Delete MessageReply w/QuoteDirect Link to This Post
I helped a roofer friend build a camper and cover the whole thing in rubber.
I don't remember why, but we found out we had to drill some holes into the outside walls and insert these little vent things that were about the size of a quarter.
I think becouse with the insulation and airtight rubber, the whole thing would start sweating?
I don't remember.
I do remember that the rubber would not let anything breath...........even people, when the windows, doors, and roofvent was closed.
At first it was very dangerous when working inside.
Have to always leave something open, or maybe permanatly vent it slightly, somehow.
I don't quite remember, been 25 years or so.....
[This message has been edited by Boondawg (edited 05-24-2011).]
Synthesis
Total ratings: 290
Report this Post05-24-2011 08:47 PM Click Here to See the Profile for SynthesisSend a Private Message to SynthesisEdit/Delete MessageReply w/QuoteDirect Link to This Post
I don't remember.
The EPDM is only over the roof. The walls are finished, as you currently see them.
An air tight camper can kill you. This camper will have a permanent vent installed in the foot well area, and the windows will always be open when camping anyway.
Boondawg
Total ratings: 342
Report this Post05-24-2011 09:35 PM Click Here to See the Profile for BoondawgSend a Private Message to BoondawgEdit/Delete MessageReply w/QuoteDirect Link to This Post
Cool.
Just relaying stuff I didn't know about campers before I knew those things.
I knew about carbon monoxide, but not about.........carbon dioxide.............breathing in breath?
Mcfleev-O
Report this Post05-24-2011 10:15 PM Click Here to See the Profile for Mcfleev-OSend a Private Message to Mcfleev-OEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thats so sick!
Someone should do a Fiero themed trailer like this one
http://peacetek.net/saab-ra...trailer-martin-h.jpg
[This message has been edited by Mcfleev-O (edited 05-24-2011).]
Zeb
Total ratings: 52
Report this Post05-24-2011 10:30 PM Click Here to See the Profile for ZebSend a Private Message to ZebEdit/Delete MessageReply w/QuoteDirect Link to This Post
The top screw in this photo isn't perfectly straight. That is the ONLY imperfection I've been able to find....
Synthesis
Total ratings: 290
Report this Post05-24-2011 10:32 PM Click Here to See the Profile for SynthesisSend a Private Message to SynthesisEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks.
It is actually crooked because I hit the drywall screw beneath it that is holding the paneling on.
Gokart Mozart
Total ratings: 159
Report this Post05-24-2011 10:33 PM Click Here to See the Profile for Gokart MozartClick Here to visit Gokart Mozart's HomePageSend a Private Message to Gokart MozartEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by Mcfleev-O:
Thats so sick!
https://www.fiero.nl/forum/A...060811-2-057971.html
Synthesis
Total ratings: 290
Report this Post05-26-2011 07:52 PM Click Here to See the Profile for SynthesisSend a Private Message to SynthesisEdit/Delete MessageReply w/QuoteDirect Link to This Post
The hatch is built with the exception of a small strip of plywood at the very top front edge (intentionally left off for now, until the hinge comes in)...
Note the curve of the hatch matches the curve of the side perfectly. The bottom is moved out 1/4". Knocking it back into place lines it up spot on.
The hatch will actually ride about 1/4" further from the side than it is now, to make room for the gasket seal.
The top edge shown up close. It is intentionally lower than the main roof line. Disregard the rough cut on the trim. It will be cleaned up when the hinge arrives and I can mount it to the roof.
The hatch will be raised up to roof level when the hinge arrives and the last strip of plywood is attached and glued. Once I get the hinge lined up and attached to the hatch and everything is hunky dory, I will remove the hatch entirely.
Here is the underside of the hatch. Yes, the screws are sticking through. These will be sanded off smooth, and then whenever I get around to it, I will be attaching a canvas liner to the hatch to cover the roof spars and provide some nice trim. I did not need or want to double the roof spars up to 2x2, when a 1x2 oak spar will work fine. The hatch is VERY rigid.
The edges of the hatch. This plywood will receive a very thick coat of fiberglass resin on the underside of the lip. This will stiffen the edge and reinforce it enough that I should not need to worry about breaking a corner somewhere.
The hatch will get the same edge treatment that the main roof has, the hard molding. Since I am only going through fiberglass reinforced 1/4" plywood, the trim will be attached via countersunk style machine screws with nuts and Loctite. The screws will stick up through the plywood from the bottom side, the nuts will go on with a healthy dose of blue loctite for serviceability. Excess screw length will be trimmed so the plastic insert can cover the nuts.
The side leg will be notched as the front radius is to provide a smooth curve, and consistency with the rest of the trim.
The galley wall edges will be capped with 1.25" dead soft aluminum "L" trim. The short leg overlaps the plywood on the side. The long leg fits the galley wall edge.
And, the radius fillers for the door frames. These will be trimmed to match the plywood. They were installed last night with adhesive, and screws to hold them in. Out come the screws and then they get a healthy trim.
buds
Report this Post05-26-2011 08:58 PM Click Here to See the Profile for budsSend a Private Message to budsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Cool project !!! Now I want to build one
Please keep updating this thread as I am enjoying the build
