  Totally O/T
  My new project... Teardrop Camper for pulling behind the Fiero... (Page 8)
My new project... Teardrop Camper for pulling behind the Fiero... by Synthesis
Started on: 03-28-2011 01:54 PM
Replies: 297 (19316 views)
Last post by: 84fiero123 on 07-05-2014 11:11 PM
Report this Post07-26-2012 03:39 PM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
With the lightweight and the strength of Alumalite or similar corrugated aluminum panels, it would allow use of heavier materials elsewhere, like 3/4 MDO for the flooring. Beds could be of the inflatable Coleman style mattresses for additional weight savings. As I said, you can actually roll-form these panels in their thinner versions, if you have a large enough press.
I have a number of subdivision signs made from this 1/2 inch material that have been in place since the mid 90's. Most of them were lettered with computer cut Scotchlite materials. The reason for that is that lighting for entrance signs requires a dedicated power meter and the reflective materials made them visible at night. The same principal could be used to create your own custom trailer graphics. They have an edge finishing channel, too that snaps over the edges to keep out water and other materials.
Report this Post07-26-2012 03:41 PM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
Member since Jan 2002
double post
[This message has been edited by fierofool (edited 07-26-2012).]
Gokart Mozart
Total ratings: 159
Report this Post07-28-2012 05:12 PM Click Here to See the Profile for Gokart MozartClick Here to visit Gokart Mozart's HomePageSend a Private Message to Gokart MozartEdit/Delete MessageReply w/QuoteDirect Link to This Post
carnut122
Total ratings: 83
Report this Post07-28-2012 08:01 PM Click Here to See the Profile for carnut122Send a Private Message to carnut122Edit/Delete MessageReply w/QuoteDirect Link to This Post
Tom, there's a supplier near you, over in Cumming. Aluma-Panel
http://www.alumapanel.com/v...D=733&name=Alumalite
Thanks Charlie! Is there any insulation value to the core material?
[This message has been edited by carnut122 (edited 07-28-2012).]
Report this Post07-28-2012 09:20 PM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
Tom, the material I used didn't have a solid core. It was fluted inside like a sheet of cardboard. If you looked down between the surfaces you could see all the way through. I doubt it would have much insulation value, other than what the dead air space would provide. I guess you could put a thin sheet on either side of your framework and insulate between.
texasfiero
Total ratings: 82
Report this Post08-06-2012 11:21 AM Click Here to See the Profile for texasfieroSend a Private Message to texasfieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
A trailer for the off-roaders in the croud.
He said he was building it for "sales".
[This message has been edited by texasfiero (edited 08-06-2012).]
Gokart Mozart
Total ratings: 159
Report this Post08-06-2012 11:46 AM Click Here to See the Profile for Gokart MozartClick Here to visit Gokart Mozart's HomePageSend a Private Message to Gokart MozartEdit/Delete MessageReply w/QuoteDirect Link to This Post
Report this Post08-06-2012 01:47 PM Click Here to See the Profile for 2.5Send a Private Message to 2.5Edit/Delete MessageReply w/QuoteDirect Link to This Post
Beds could be of the inflatable Coleman style mattresses for additional weight savings. .
Inflate with helium for additional weight savings
j/k
XgovernmentAgent
Report this Post10-13-2012 06:48 PM Click Here to See the Profile for XgovernmentAgentSend a Private Message to XgovernmentAgentEdit/Delete MessageReply w/QuoteDirect Link to This Post
Did you use the common hitch for the Fiero or did you make one like some others have done for a hidden hitch?
Synthesis
Total ratings: 290
Report this Post11-13-2013 12:32 PM Click Here to See the Profile for SynthesisSend a Private Message to SynthesisEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have opted to sell the Teardrop as I need the money more than I need to find a way to store it this winter...
As much as I enjoy using it, I don't use it enough. We used it exactly once this year at Camp Shipman, and haven't touched it since.
http://minneapolis.craigsli.../rvs/4188572377.html
Synthesis
Total ratings: 290
Report this Post07-03-2014 09:31 PM Click Here to See the Profile for SynthesisSend a Private Message to SynthesisEdit/Delete MessageReply w/QuoteDirect Link to This Post
I started my quest to repair the water damage from storing it outside this past winter.
While I've got the sides off, I'm also working on upgrading the wiring, adding a couple more 12v circuits for additional lighting and options, as well as adding in 120v outlets inside the camper.
I'm also building a cabinet inside the camper to provide permanent storage rather than the cloth "hammock" shelf I had made previously.
Pictures as I take them to show my continued progress.
Edit: Every time someone expressed interest in the teardrop, I second guessed myself on selling it, and decided not to.
[This message has been edited by Synthesis (edited 07-03-2014).]
Boondawg
Total ratings: 342
Report this Post07-03-2014 09:37 PM Click Here to See the Profile for BoondawgSend a Private Message to BoondawgEdit/Delete MessageReply w/QuoteDirect Link to This Post
Might as well switch over to LED...
Looking forward to pictures!
htexans1
Total ratings: 116
Report this Post07-03-2014 10:00 PM Click Here to See the Profile for htexans1Send a Private Message to htexans1Edit/Delete MessageReply w/QuoteDirect Link to This Post
Consider using Carbon Fiber-- Homebuilders use it on the Long EZ Cozy and other homebuilt aircraft. Use it on your teardrop trailer...
Lightweight, and pretty weatherproof as far as materiel goes. It won't rust or corrode. -- and its formable easily into a Tear.
Get water in it, wipe it up and thats it.
We use a form of it on the 787, so it'll work on your trailer easily.
www.wicksaircraft.com
www.aircraftspruce.com
Both sell "composite" or Carbon Fiber. Its not as expensive as you'd think.
[This message has been edited by htexans1 (edited 07-03-2014).]
Fats
Total ratings: 75
Report this Post07-03-2014 10:51 PM Click Here to See the Profile for FatsSend a Private Message to FatsEdit/Delete MessageReply w/QuoteDirect Link to This Post
The teardrop is still one of my favorites.
Brad
84fiero123
Total ratings: 325
Report this Post07-04-2014 07:30 AM Click Here to See the Profile for 84fiero123Send a Private Message to 84fiero123Edit/Delete MessageReply w/QuoteDirect Link to This Post
You are in a heavy snow area like we are, did you just cover it with a tarp last year? Lots of people who have campers with the flat roof do that up here and regret it in the spring because of the weight of the snow creating leaks on the roof. Best thing is to put it under a roof, arched is the strongest weight bearing kind but don't cheap out, buy the best one you can, if they even allow you to do that where you are. that is another problem for people who have campers and live in apartments as well. then you are stuck renting a garage or storage unit for them, yours is small enough to fit in a regular size garage though. If you can find one at a reasonable rental.
Good luck with the repairs.
Steve
carnut122
Total ratings: 83
Report this Post07-04-2014 07:39 AM Click Here to See the Profile for carnut122Send a Private Message to carnut122Edit/Delete MessageReply w/QuoteDirect Link to This Post
Please post pictures of the updates. I've enjoyed this thread in the past as I had plans on building one of these. But, the wife's idea of roughing it is Super-8 Motel, so I'm thinking of a camper shell for my truck instead.
Synthesis
Total ratings: 290
Report this Post07-05-2014 04:30 PM Click Here to See the Profile for SynthesisSend a Private Message to SynthesisEdit/Delete MessageReply w/QuoteDirect Link to This Post
I've been struggling with radiusing 1x1" aluminum angle in order to trim out the edges of the door openings.
I can't get them to curve nicely, even with annealing the aluminum...
Have to try to find a bender, or find someone who can do an outside radius (the leg would stretch on the outside of the curve).
The new wood side is on, and new wiring has been added for some additional lighting circuits and the like.
I've also added the 120v wiring, the circuit breaker panel and several electrical outlet boxes.
I'll post pics as soon as my site becomes available again.
84fiero123
Total ratings: 325
Report this Post07-05-2014 11:11 PM Click Here to See the Profile for 84fiero123Send a Private Message to 84fiero123Edit/Delete MessageReply w/QuoteDirect Link to This Post
Roller will bend that without distorting the stock to bad but if that is really a problem give yourself some extra length on the tube and cut it square after bending it. Most fab shops, some farmers who have their own machine shop, you would be surprised how many have a small set up just for repairing their own equipment.
Steve
