  Totally O/T
  If you ever plan to vacation in Hawaii ...... (Page 2)
If you ever plan to vacation in Hawaii ...... by 8Ball
Started on: 08-29-2013 07:43 AM
Replies: 59 (1111 views)
Last post by: pontiackid86 on 02-24-2015 05:43 AM
MadMark
Report this Post08-29-2013 09:51 PM Click Here to See the Profile for MadMarkSend a Private Message to MadMarkEdit/Delete MessageReply w/QuoteDirect Link to This Post
One other thing I would like to point out is that with the possibility of a China Syndrome that would occur shortly after shutdown the problem would be from the fuel becoming in close proximity to itself. By this I mean that either the fuel rods degrade due to Zirc Hydration allowing the fuel pellets to come close together or the fuel actually melts. Since the uranium is very heavy it would tend to go to the bottom of the pile. As it get into close proximity it then goes critical causing more heat which could then burn through the containment structure. Then as this pool of fuel burns it way down it would hit the water table which would cause a steam explosion blowing the whole mess apart and spreading serious contamination with high level radioactive daughter products of fission. Along with that it could contaminate the water supply for a large area.
That was a huge concern at Chernobyl. Several people willingly went in and dug up the area under Chernobyl and installed a cone shaped column that distributed the mess so that it could not reach the water table. These men were unsung heroes who willingly gave up their lives to save the Ukraine. Also, there we others who gave up their lives to fly helicopters dropping water on Chernobyl. Chernobyl was a much worse case scenario than Fukishima even though Fukishima affect several plants.
Total ratings: 436
Report this Post08-29-2013 10:14 PM Click Here to See the Profile for maryjaneSend a Private Message to maryjaneEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks for your invaluable insight on this Mark!!
One of the most fascinating bits of info I ever ran across are the natural fission reactors that existed here on Earth at Gabon (Africa) long before man came along. Pretty neat, that they operated all by themselves for several 100 thousands of years and no meltdowns. They even "turned themselves on and off" when water stopped flowing.
http://blogs.scientificamer...abon-western-africa/
MadMark
Report this Post08-29-2013 11:02 PM Click Here to See the Profile for MadMarkSend a Private Message to MadMarkEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have never heard about the natural reactors. So I guess I have a lot to learn about them.
One other major radiation disaster happened in Idaho, I think it was in 61. The Army was trying to develop a small nuclear reactor and had a system set up on the National Reactor Testing Facility West of Idaho Falls. It was designated SL-1. The reactor was shut down and they were doing maintenance. The had the control rods inserted but the mechanisms were taken apart. One of the technicians was fooling around with another technician's wife and he was upset. Upset enough that he supposedly pulled one of the rods out by hand, actually yanked it out. Several things affect the criticality of a reactor. The temperature of the water is one of them. As the water gets colder it is denser and acts better as a reflector and a moderator. So this reactor was closer to criticality because of that. Also, nuclear reactions happen at 10 to the minus 23 seconds. So each generation is infinitestably short. So if you insert a lot of reactivity, even if it is not enough to go critical under stable conditions, it can cause a major uptick in reactivity. Since this happens so fast it didn't have time to naturally turn around the reactivity and it overshot drastically. This high level of power overshot and almost instantly boiled the water out of the reactor causing it to create steam. The steam blew apart the reactor and caused a radioactivity release. The operator who pulled the control rod ended up stuck to the ceiling of the reactor room. Several other operators and technicians who were there died also from radiation poisoning. Radiation alarms across the site went off and when they investigated they found this plant was the cause.
Here is a report on it: http://www.radiationworks.com/sl1reactor.htm
There have been several accidents in the nuclear industry over the years, but in the baby stages it was all hidden from the public.
MadMark
Report this Post08-29-2013 11:16 PM Click Here to See the Profile for MadMarkSend a Private Message to MadMarkEdit/Delete MessageReply w/QuoteDirect Link to This Post
MadMark
Member since Feb 2010
What triggered that memory was the reference to the natural reactors and the water. I just read the report on the natural reactors and it is interesting.
Total ratings: 436
Report this Post08-29-2013 11:38 PM Click Here to See the Profile for maryjaneSend a Private Message to maryjaneEdit/Delete MessageReply w/QuoteDirect Link to This Post
Interesting stuff, and places I'd like to go visit.
"The resulting power surge caused the reactor power to reach 20,000MW in about .01 seconds,"
I need that in my Indy.
rinselberg
Total ratings: 147
Report this Post08-29-2013 11:47 PM Click Here to See the Profile for rinselbergClick Here to visit rinselberg's HomePageSend a Private Message to rinselbergEdit/Delete MessageReply w/QuoteDirect Link to This Post
No problemo, says New Scientist
Report from New Scientist, just a few days ago, ends with this:
On an international level, even if all the waste from Fukushima was dumped neat into the Pacific, dilution would eliminate any radiation risks to distant countries like the US, says Simon Boxall of the National Oceanography Centre in Southampton, UK.
The ocean would be the safest place for the waste water, says Geraldine Thomas, who runs the Chernobyl Tissue Bank at Imperial College London. "But to make that politically acceptable they have to talk to the local population. They have to make people understand that low levels of radiation don't matter because we're all exposed to it all the time."
In other words, it is more of a communication problem than a public health problem. "None of this is going to do anything health wise," she says. "Fukushima is nothing compared to Chernobyl."
http://www.newscientist.com...ea.html#.UiADVBZ_1cQ
Total ratings: 436
Report this Post08-30-2013 12:05 AM Click Here to See the Profile for maryjaneSend a Private Message to maryjaneEdit/Delete MessageReply w/QuoteDirect Link to This Post
Well Capt Maven, you're a bit late. We all came to that conclusion back on pg 1.
avengador1
Total ratings: 571
Report this Post12-08-2013 10:26 PM Click Here to See the Profile for avengador1Send a Private Message to avengador1Edit/Delete MessageReply w/QuoteDirect Link to This Post
RADIATION EFFECTS IN U.S. FROM JAPAN NUKE ACCIDENT
Tuesday, 26 November 2013
http://www.turnerradionetwork.com/news/72-mjt
DeV8er
Report this Post12-09-2013 10:19 AM Click Here to See the Profile for DeV8erSend a Private Message to DeV8erEdit/Delete MessageReply w/QuoteDirect Link to This Post
TRUTH?
"You can't handle the truth! "
Report this Post12-09-2013 10:28 AM Click Here to See the Profile for 2.5Send a Private Message to 2.5Edit/Delete MessageReply w/QuoteDirect Link to This Post
article:
"In other words, it is more of a communication problem than a public health problem. "None of this is going to do anything health wise," she says."
It seems the choice we have, is to take their word for it.
Cheever3000
Total ratings: 178
Report this Post02-20-2015 03:28 PM Click Here to See the Profile for Cheever3000Send a Private Message to Cheever3000Edit/Delete MessageReply w/QuoteDirect Link to This Post
So ... what's the bottom line on vacationing in Hawaii? Good idea? Bad idea?
Report this Post02-20-2015 03:51 PM Click Here to See the Profile for 2.5Send a Private Message to 2.5Edit/Delete MessageReply w/QuoteDirect Link to This Post
If people who live there arent getting sick, you there for a week wont have a problem.
Total ratings: 436
Report this Post02-20-2015 07:03 PM Click Here to See the Profile for maryjaneSend a Private Message to maryjaneEdit/Delete MessageReply w/QuoteDirect Link to This Post
unless they sacrifice you to pele, the volcano goddess.
Hudini
Total ratings: 165
Report this Post02-20-2015 07:12 PM Click Here to See the Profile for HudiniSend a Private Message to HudiniEdit/Delete MessageReply w/QuoteDirect Link to This Post
I would go there again. It's a beautiful place, but very expensive. You can rent waterproof cameras for underwater stuff. (You can rent anything really)
Do NOT go here: http://www.hawaiinewsnow.co...-limits-sacred-falls
carnut122
Total ratings: 83
Report this Post02-20-2015 07:45 PM Click Here to See the Profile for carnut122Send a Private Message to carnut122Edit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by cliffw:
Do we want radiation in the atmosphere, or, CO2 ?
I don't think it's "either or" as we have plenty of both.
FriendGregory
Report this Post02-21-2015 02:41 PM Click Here to See the Profile for FriendGregorySend a Private Message to FriendGregoryEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by Taijiguy:Protect Hawaii, it can have Cali.
Thanks buddy, we are just glowing with the love.
Gokart Mozart
Total ratings: 159
Report this Post02-21-2015 03:15 PM Click Here to See the Profile for Gokart MozartClick Here to visit Gokart Mozart's HomePageSend a Private Message to Gokart MozartEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by Raydar:
I tend to believe that sooner or later, an uncontrolled melt is inevitable. At some point, the area around the site is going to become too contaminated to be worked in or around.
I suppose my question is what would happen in such a situation? I would think that there would be a nice beam of radioactivity projected out of the hole in an ever narrowing beam. Probably accompanied by lots of radioactive steam. (Or at least particulates, since radioactive water is not a possibility. Did I get that right?) At some point, I have to believe that the earth would just fall in on the molten blob. Would that tend to cause it to go critical and explode? Or would it, at some point, just reach a depth where it would become insignificant? As hot as the earth is, below ground, it makes me wonder if it would reach a certain level and just disburse in the rest of the molten material.
Could make an interesting sci-fi film, for sure. ("China Syndrome II, the aftermath", anybody?) Not to make light of an ugly situation.
James Bond 007
Total ratings: 263
Report this Post02-23-2015 10:49 PM Click Here to See the Profile for James Bond 007Send a Private Message to James Bond 007Edit/Delete MessageReply w/QuoteDirect Link to This Post
genetic mutations, yea!! Ive allways wanted an extra weiner!
Total ratings: 436
Report this Post02-23-2015 11:53 PM Click Here to See the Profile for maryjaneSend a Private Message to maryjaneEdit/Delete MessageReply w/QuoteDirect Link to This Post
Double dingus McGee?
pontiackid86
Total ratings: 344
Report this Post02-24-2015 05:43 AM Click Here to See the Profile for pontiackid86Send a Private Message to pontiackid86Edit/Delete MessageReply w/QuoteDirect Link to This Post
Yea it can have cali...
Cali fiero owners... get out lol
[This message has been edited by pontiackid86 (edited 02-24-2015).]
