  Totally O/T
  Will we ever know what happened to Malaysia Flight MH-370 (Page 2)
This topic is 10 pages long:  1   2   3   4   5   6   7   8   9   10
Will we ever know what happened to Malaysia Flight MH-370 by maryjane
Started on: 03-10-2014 09:00 AM
Replies: 365 (7330 views)
Last post by: maryjane on 01-17-2017 08:17 AM
Gokart Mozart
Total ratings: 159
Report this Post03-11-2014 04:55 PM Click Here to See the Profile for Gokart MozartClick Here to visit Gokart Mozart's HomePageSend a Private Message to Gokart MozartEdit/Delete MessageReply w/QuoteDirect Link to This Post
http://www.educateinspirech...ines-flight-370.html
• Fact #1: All Boeing 777 commercial jets are equipped with black box recorders that can survive any on-board explosion
No explosion from the plane itself can destroy the black box recorders. They are bomb-proof structures that hold digital recordings of cockpit conversations as well as detailed flight data and control surface data.
• Fact #2: All black box recorders transmit locator signals for at least 30 days after falling into the ocean
Yet the black box from this particular incident hasn’t been detected at all. That’s why investigators are having such trouble finding it. Normally, they only need to “home in” on the black box transmitter signal. But in this case, the absence of a signal means the black box itself — an object designed to survive powerful explosions — has either vanished, malfunctioned or been obliterated by some powerful force beyond the worst fears of aircraft design engineers.
• Fact #3: Many parts of destroyed aircraft are naturally bouyant and will float in water
In past cases of aircraft destroyed over the ocean or crashing into the ocean, debris has always been spotted floating on the surface of the water. That’s because — as you may recall from the safety briefing you’ve learned to ignore — “your seat cushion may be used as a flotation device.”
Yes, seat cushions float. So do many other non-metallic aircraft parts. If Flight 370 was brought down by an explosion of some sort, there would be massive debris floating on the ocean, and that debris would not be difficult to spot. The fact that it has not yet been spotted only adds to the mystery of how Flight 370 appears to have literally vanished from the face of the Earth.
• Fact #4: If a missile destroyed Flight 370, the missile would have left a radar signature
One theory currently circulating on the ‘net is that a missile brought down the airliner, somehow blasting the aircraft and all its contents to “smithereens” — which means very tiny pieces of matter that are undetectable as debris.
The problem with this theory is that there exists no known ground-to-air or air-to-air missile with such a capability. All known missiles generate tremendous debris when they explode on target. Both the missile and the debris produce very large radar signatures which would be easily visible to both military vessels and air traffic authorities.
• Fact #5: The location of the aircraft when it vanished is not a mystery
Air traffic controllers have full details of almost exactly where the aircraft was at the moment it vanished. They know the location, elevation and airspeed — three pieces of information which can readily be used to estimate the likely location of debris.
Remember: air safety investigators are not stupid people. They’ve seen mid-air explosions before, and they know how debris falls. There is already a substantial data set of airline explosions and crashes from which investigators can make well-educated guesses about where debris should be found. And yet, even armed with all this experience and information, they remain totally baffled on what happened to Flight 370.
• Fact #6: If Flight 370 was hijacked, it would not have vanished from radar
Hijacking an airplane does not cause it to simply vanish from radar. Even if transponders are disabled on the aircraft, ground radar can still readily track the location of the aircraft using so-called “passive” radar (classic ground-based radar systems that emit a signal and monitor its reflection).
Thus, the theory that the flight was hijacked makes no sense whatsoever. When planes are hijacked, they do not magically vanish from radar.
Conclusion: Flight 370 did not explode; it vanished
The inescapable conclusion from what we know so far is that Flight 370 seems to have utterly and inexplicably vanished. It clearly was not hijacked (unless there is a cover-up regarding the radar data), and we can all be increasingly confident by the hour that this was not a mid-air explosion (unless debris suddenly turns up that they’ve somehow missed all along).
The inescapable conclusion is that Flight 370 simply vanished in some way that we do not yet understand. This is what is currently giving rise to all sorts of bizarre-sounding theories across the ‘net, including discussions of possible secret military weapons tests, Bermuda Triangle-like ripples in the fabric of spacetime, and even conjecture that non-terrestrial (alien) technology may have teleported the plane away.
Personally, I’m not buying any of that without a lot more evidence. The most likely explanation so far is that the debris simply hasn’t been found yet because it fell over an area which is somehow outside the search zone. But as each day goes by, even this explanation becomes harder and harder to swallow.
The frightening part about all this is not that we will find the debris of Flight 370; but rather that we won’t. If we never find the debris, it means some entirely new, mysterious and powerful force is at work on our planet which can pluck airplanes out of the sky without leaving behind even a shred of evidence.
If there does exist a weapon with such capabilities, whoever control it already has the ability to dominate all of Earth’s nations with a fearsome military weapon of unimaginable power. That thought is a lot more scary than the idea of an aircraft suffering a fatal mechanical failure.
Cheever3000
Total ratings: 178
Report this Post03-11-2014 04:57 PM Click Here to See the Profile for Cheever3000Send a Private Message to Cheever3000Edit/Delete MessageReply w/QuoteDirect Link to This Post
I don't have a lot of confidence in Malaysian search & rescue. They just haven't looked in the right place yet.
The U.S. Navy, yes, but they're just looking in the ocean, so...
MadMark
Report this Post03-11-2014 05:38 PM Click Here to See the Profile for MadMarkSend a Private Message to MadMarkEdit/Delete MessageReply w/QuoteDirect Link to This Post
As of today there are reports that this flight turned off its transponder and still flew for over an hour after that. I also changed direction at that time and flew over Malaysia and ended up over the Straits of Malacca. Where it eventually went off of military radar. The principle way for the air traffic controllers to monitor the airplane's movement is by watching it's transponder signal which also gives off information on height, position and speed. After the transponder is turned off it requires an active radar to pick it up. Which is what the military used to see the last hour or so of this flight. So most likely the plane went down somewhere they are not searching.
An alternative to this is that it somehow evaded the military radar (by presumably going lower where it could not be seen) and it landed somewhere. Highly unlikely not to be seen though.
This does raise a whole lot of questions:
Why turn off the transponder?
Why turn around?
Why no communications from the pilots?
And why are the officials trying to rule out sabotage and terrorist attacks now? Just when it seems that that is a very likely scenario with turning off the transponder?
Neils88
Total ratings: 56
Report this Post03-11-2014 07:05 PM Click Here to See the Profile for Neils88Send a Private Message to Neils88Edit/Delete MessageReply w/QuoteDirect Link to This Post
Fact #1 - there is no such thing as "bomb-proof". Bomb resistant, yes, but not bomb proof. The location of a bomb in relation to the black box is relevant to this fact.
Fact #2 - there is a relatively small sound signature underwater for a black box. It's a big-ass ocean. You need to have a reasonable idea where to start looking before you can home in on the exact location.
Fact #3 - true. Regardless of how the plane hits the water, there will be a debris field. The angle and speed that it hits the water will determine the initial field size, then water/weather conditions will dictate how the field propagates.
Fact #4 - a missile may or may not have been picked up on radar. There would still be a debris field since a missile would not completely disintegrate a plane of that size.
Fact #5 - yes...but this in itself doesn't guarantee knowledge of where the plane hit the water (assuming it did). Not every radar set up tracks all information. Radar have limited range. There are several other sources of information that are available as transmitted from the 777, but these can be shut off or eliminated due to electrical issues.
Fact #6 - see Fact #5
The two most valid theories are mechanical failure and hijacking. The plane appeared to turn around and then disappeared when the transponder stopped transmitting. At this point the civilian systems could no longer track it. Military systems have limitations too...unclear if the plane moved out of it's range. The plane could have experienced cascading mechanical failure (often due to an onboard fire) or been under the control of hijackers (before the pilots could react and send out a warning). In this case...passenger could have fought back resulting in loss of the plane. When the plane did go down, it could have been well away from where people now expect it to be. Locating the debris field could take a long time.
http://ca.reuters.com/artic...dCABREA2701720140311
Sorry...theories about aliens or supernatural phenomena really have no place in an educated discussion.
Red88FF
Total ratings: 130
Report this Post03-11-2014 07:08 PM Click Here to See the Profile for Red88FFSend a Private Message to Red88FFEdit/Delete MessageReply w/QuoteDirect Link to This Post
Why turn around?
Feels like a highjack, especially so because the officials are attempting to rule it out this early without finding or giving any other answers.
pokeyfiero
Total ratings: 306
Report this Post03-11-2014 07:23 PM Click Here to See the Profile for pokeyfieroClick Here to visit pokeyfiero's HomePageSend a Private Message to pokeyfieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Sorry...theories about aliens or supernatural phenomena really have no place in an educated discussion. [/QUOTE]
84fiero123
Total ratings: 325
Report this Post03-11-2014 08:13 PM Click Here to See the Profile for 84fiero123Send a Private Message to 84fiero123Edit/Delete MessageReply w/QuoteDirect Link to This Post
You haven't seen my mailbox,
Steve
Neils88
Total ratings: 56
Report this Post03-11-2014 08:31 PM Click Here to See the Profile for Neils88Send a Private Message to Neils88Edit/Delete MessageReply w/QuoteDirect Link to This Post
Steve
No...but I'm happy to blow it up to prove my point....
Taijiguy
Total ratings: 244
Report this Post03-11-2014 08:38 PM Click Here to See the Profile for TaijiguySend a Private Message to TaijiguyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Stolen passports
zero communication
no debris
20 employees of a high tech chip company on one plane
phones still ringing but no one locating the phones
What else is odd?
This is what too few people are talking about. That's significant I think. I mean, aliens would have to steal passports to get on board.
Taijiguy
Total ratings: 244
Report this Post03-11-2014 08:41 PM Click Here to See the Profile for TaijiguySend a Private Message to TaijiguyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Taijiguy
Member since Jul 99
I've got it! I know what happened!
http://en.wikipedia.org/wiki/Millennium_%28film%29
We totally should have seen this coming!
[This message has been edited by Taijiguy (edited 03-11-2014).]
Report this Post03-11-2014 08:55 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
A little far from the Bermuda Triangle, but...
Total ratings: 436
Report this Post03-11-2014 09:42 PM Click Here to See the Profile for maryjaneSend a Private Message to maryjaneEdit/Delete MessageReply w/QuoteDirect Link to This Post
I am really suprised that even tho this is Maylaysian territorial air space and water, that the Chinese haven't said "Enough is enough--we're taking over this search--NOW".
And why is Boeing being less than forthcoming about ACARS or other instrumentation on this aircraft?
Asked to detail the communications devices aboard the missing jet, Boeing spokesman Doug Alder said, "It's not appropriate for us to discuss that right now."
http://www.cnn.com/2014/03/...?iid=article_sidebar
Hudini
Total ratings: 165
Report this Post03-12-2014 07:41 AM Click Here to See the Profile for HudiniSend a Private Message to HudiniEdit/Delete MessageReply w/QuoteDirect Link to This Post
Fact 2 is not exactly true. Remember it took a long time to find them for the Air France A330 in 2009. 500 miles offshore in deep water is not an easy thing to overcome.
Mj is right on about Boeing though. What instrumentation does the 777 have and why can't they comment? Air France had down to the second data being transmitted by their A330 even as it plunged into the ocean. You would think the 777 has a similar setup via satellite. Unless it's an optional equipment sort of thing and Malaysia Airlines did not purchase it. But that is easily answered by Boeing.
DanDamage
Total ratings: 81
Report this Post03-12-2014 09:18 AM Click Here to See the Profile for DanDamageSend a Private Message to DanDamageEdit/Delete MessageReply w/QuoteDirect Link to This Post
this my god this... aliens!
84fiero123
Total ratings: 325
Report this Post03-12-2014 10:05 AM Click Here to See the Profile for 84fiero123Send a Private Message to 84fiero123Edit/Delete MessageReply w/QuoteDirect Link to This Post
You could have a point, at the exact polar opposite there is the Dragon's Triangle.
Steve
Marvin McInnis
Total ratings: 227
Report this Post03-12-2014 10:07 AM Click Here to See the Profile for Marvin McInnisClick Here to visit Marvin McInnis's HomePageSend a Private Message to Marvin McInnisEdit/Delete MessageReply w/QuoteDirect Link to This Post
I've personally flown small aircraft in the Bermuda Triangle on several occasions ... and survived ... and there are plenty of perfectly reasonable explanations for most aircraft/watercraft losses there that do not require supernatural phenomena.
With respect to flight MH-370, I'm putting my money on the Dr. Evil scenario.
More seriously ... I think when the probable cause[s] of the MH-370 incident is eventually determined, it will be more mundane than most of the current speculation.
[This message has been edited by Marvin McInnis (edited 03-12-2014).]
84fiero123
Total ratings: 325
Report this Post03-12-2014 10:09 AM Click Here to See the Profile for 84fiero123Send a Private Message to 84fiero123Edit/Delete MessageReply w/QuoteDirect Link to This Post
Come on down, bet you can't do it!
Not without at least 20 pounds of C4 anyway.
Steve
DanDamage
Total ratings: 81
Report this Post03-12-2014 10:13 AM Click Here to See the Profile for DanDamageSend a Private Message to DanDamageEdit/Delete MessageReply w/QuoteDirect Link to This Post
careful , i think youve got mail
lurker
Total ratings: 236
Report this Post03-12-2014 11:36 AM Click Here to See the Profile for lurkerSend a Private Message to lurkerEdit/Delete MessageReply w/QuoteDirect Link to This Post
Steve
last (and first) time i looked, the dragon triangle is off the east coast of australia (that's the new zealand side, not the malaysia side). proff should know. yesterday, i checked yesterday. please don't make me dig up the link.
84fiero123
Total ratings: 325
Report this Post03-12-2014 12:12 PM Click Here to See the Profile for 84fiero123Send a Private Message to 84fiero123Edit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by Marvin McInnis:
I've personally flown small aircraft in the Bermuda Triangle on several occasions ... and survived ... and there are plenty of perfectly reasonable explanations for aircraft/watercraft losses that do not require supernatural phenomena.
We are not so sure you survived, I think you are an alien replacement myself.
Steve
Marvin McInnis
Total ratings: 227
Report this Post03-12-2014 12:53 PM Click Here to See the Profile for Marvin McInnisClick Here to visit Marvin McInnis's HomePageSend a Private Message to Marvin McInnisEdit/Delete MessageReply w/QuoteDirect Link to This Post
No, I'm just an engineer ... but I realize that to you all engineers are aliens.
84fiero123
Total ratings: 325
Report this Post03-12-2014 02:51 PM Click Here to See the Profile for 84fiero123Send a Private Message to 84fiero123Edit/Delete MessageReply w/QuoteDirect Link to This Post
good one! Would have been even better if you said, "Illegal aliens." Then it would be so true.
Steve
[This message has been edited by 84fiero123 (edited 03-12-2014).]
Boostdreamer
Total ratings: 98
Report this Post03-12-2014 03:10 PM Click Here to See the Profile for BoostdreamerSend a Private Message to BoostdreamerEdit/Delete MessageReply w/QuoteDirect Link to This Post
[SARCASM]
At this point in the history of the flight, what difference does it make!!!??
[/SARCASM]
TK
Total ratings: 200
Report this Post03-12-2014 03:33 PM Click Here to See the Profile for TKSend a Private Message to TKEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'm thinking the turn is a red herring. Maybe they tracked a different plane. Just weird at many levels.
Marvin McInnis
Total ratings: 227
Report this Post03-12-2014 04:00 PM Click Here to See the Profile for Marvin McInnisClick Here to visit Marvin McInnis's HomePageSend a Private Message to Marvin McInnisEdit/Delete MessageReply w/QuoteDirect Link to This Post
Tracking primary targets (without transponder returns) is always problematic, even in countries with widespread radar coverage. 50 nm (terminal approach/departure radar) to 200 nm (enroute radar) is about the limit, though, and the relative lack of operator experience tracking primary targets complicates the matter even further. For several reasons ... not least that it was subsequently disclaimed ... I'm not sure that the southwest-bound aircraft reportedly tracked by the Malaysian military was valid.
Nope. I'm legal. I even have a birth certificate to prove it. (Hmmmmm ... I guess that doesn't always work out so well, though.)
cliffw
Total ratings: 292
Report this Post03-12-2014 04:38 PM Click Here to See the Profile for cliffwSend a Private Message to cliffwEdit/Delete MessageReply w/QuoteDirect Link to This Post
May be it didn't even get off the treadmill.
DanDamage
Total ratings: 81
Report this Post03-12-2014 04:59 PM Click Here to See the Profile for DanDamageSend a Private Message to DanDamageEdit/Delete MessageReply w/QuoteDirect Link to This Post
pavo_roddy
Total ratings: 71
Report this Post03-12-2014 05:10 PM Click Here to See the Profile for pavo_roddySend a Private Message to pavo_roddyEdit/Delete MessageReply w/QuoteDirect Link to This Post
HI all
Is this the first accident with a 777?
Air-eek
Enzo Ferrari....
Aerodynamics are for people who can't build engines....
Enzo Ferrari...
Today they are called garage's, yesterday, they were stable's! Eric Jacobsen.... An advancement, of other
voices I came across.
Do not walk infront of me, I may not follow. Do not walk behind me, I may not lead. Walk beside me and be my friend forever.
-unknown- found here: http://crystal-cure.com/love-quote.html
DanDamage
Total ratings: 81
Report this Post03-12-2014 05:21 PM Click Here to See the Profile for DanDamageSend a Private Message to DanDamageEdit/Delete MessageReply w/QuoteDirect Link to This Post
Purple86GT
Total ratings: 62
Report this Post03-13-2014 11:43 AM Click Here to See the Profile for Purple86GTSend a Private Message to Purple86GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Not much progress as of yet to locate that plane.
kwagner
Total ratings: 62
Report this Post03-13-2014 02:01 PM Click Here to See the Profile for kwagnerClick Here to visit kwagner's HomePageSend a Private Message to kwagnerEdit/Delete MessageReply w/QuoteDirect Link to This Post
http://online.wsj.com/news/...AxMTA0MDEwMzExNDMyWj
From other sources I've read that there is some kind of engine-maintenance data link that I believe happens once an hour. I am unsure what all data it contains, but people didn't seem to think it contained any GPS or navigation info.
That's a lot of ground/ocean to cover for a search.
Edit: here's an interesting idea: http://www.tomnod.com/nod/c...e/malaysiaairsar2014
[This message has been edited by kwagner (edited 03-13-2014).]
Wichita
Total ratings: 322
Report this Post03-13-2014 06:30 PM Click Here to See the Profile for WichitaSend a Private Message to WichitaEdit/Delete MessageReply w/QuoteDirect Link to This Post
AP is reporting that the airplane was pinging a satellite that is used to transmit data from planes, but Malaysian Airlines said they didn't subscribe to that service so there wasn't any data transfer. But the airplane was pinging this satellite for four hours after it went off radar and they say it only pings if it is flying.
More mystery.
User00013170
Total ratings: 224
User on Probation
Report this Post03-13-2014 06:38 PM Click Here to See the Profile for User00013170Send a Private Message to User00013170Edit/Delete MessageReply w/QuoteDirect Link to This Post
its just out of range. Mars is a long long way away.
User00013170
Total ratings: 224
User on Probation
Report this Post03-13-2014 06:40 PM Click Here to See the Profile for User00013170Send a Private Message to User00013170Edit/Delete MessageReply w/QuoteDirect Link to This Post
User00013170
Member since May 2006
Originally posted by pavo_roddy:
HI all
Air-eek
The VERY first link on google.. Did you even try? http://www.washingtonpost.c...y-of-the-boeing-777/
User00013170
Total ratings: 224
User on Probation
Report this Post03-13-2014 06:47 PM Click Here to See the Profile for User00013170Send a Private Message to User00013170Edit/Delete MessageReply w/QuoteDirect Link to This Post
User00013170
Not all of us...
spark1
Total ratings: 175
Report this Post03-13-2014 10:41 PM Click Here to See the Profile for spark1Send a Private Message to spark1Edit/Delete MessageReply w/QuoteDirect Link to This Post
Maybe the Langoliers?
Cheever3000
Total ratings: 178
Report this Post03-13-2014 10:56 PM Click Here to See the Profile for Cheever3000Send a Private Message to Cheever3000Edit/Delete MessageReply w/QuoteDirect Link to This Post
Is anybody else looking on Tomnod.com?
I just started about 30 minutes ago.
pokeyfiero
Total ratings: 306
Report this Post03-13-2014 11:27 PM Click Here to See the Profile for pokeyfieroClick Here to visit pokeyfiero's HomePageSend a Private Message to pokeyfieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Tomnod is experiencing technical difficulties. We apologize. We're poking our servers with pointy sticks to figure out what's wrong.
spark1
Total ratings: 175
Report this Post03-14-2014 01:00 AM Click Here to See the Profile for spark1Send a Private Message to spark1Edit/Delete MessageReply w/QuoteDirect Link to This Post
This is now sounding like Payne Stewart's last flight.
Total ratings: 436
Report this Post03-14-2014 02:33 AM Click Here to See the Profile for maryjaneSend a Private Message to maryjaneEdit/Delete MessageReply w/QuoteDirect Link to This Post
Heard that mentioned and fairly quickly dismissed on a panel discussion earlier tonight on PBS.
Where's the debris field?
But this would be more comparative than a LearJet.
http://en.wikipedia.org/wik...s_Airways_Flight_522
[This message has been edited by maryjane (edited 03-14-2014).]
