  Totally O/T
  Need Best printer advice
Need Best printer advice by pokeyfiero
Started on: 04-02-2014 03:14 AM
Replies: 8 (151 views)
Last post by: Doug85GT on 04-02-2014 05:12 PM
pokeyfiero
Total ratings: 306
Report this Post04-02-2014 03:14 AM Click Here to See the Profile for pokeyfieroClick Here to visit pokeyfiero's HomePageSend a Private Message to pokeyfieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Printer ink is a huge scam and it is really costing me a fortune.
I need to make color copies two sided about 250 to 500 a month.
I know the cheaper the printer the more expensive the ink. I don't want to spend a fortune on the printer but my biggest concern is lowest price per page in color.
Any recommendations?
Taijiguy
Total ratings: 244
Report this Post04-02-2014 07:03 AM Click Here to See the Profile for TaijiguySend a Private Message to TaijiguyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Laser. The initial cost is a bit higher, but the per page cost is a fraction of ink. Many laser cartridges will cost from 60-100 a piece. Ink is somewhat less, but ink cartridges are only good for a few hundred pages, where most toner cartridges are 2000, 3000, or 7000 pages. You'll recover the cost of the printer by the second time you replace the cartridges.
You also don't have to deal with waste from cleanings and alignments, or tossing the printer because it has a clogged print head.
[This message has been edited by Taijiguy (edited 04-02-2014).]
TheDigitalAlchemist
Total ratings: 94
Report this Post04-02-2014 08:48 AM Click Here to See the Profile for TheDigitalAlchemistClick Here to visit TheDigitalAlchemist's HomePageSend a Private Message to TheDigitalAlchemistEdit/Delete MessageReply w/QuoteDirect Link to This Post
Buy a used color hp laser. One that has cartridges for each color. Toner costs a few hundred bucks, but it lasts for thousands of pages. The two kits you need to swap out last for a few hundred thousand pages and are easy swaps. When I get into work, I'll shoot you the prices for some of the items. Or send it out to a local printer(not Staples or Kinkos or other major company)
See if they'll do it for half the price of those other places...
ls3mach
Total ratings: 222
Report this Post04-02-2014 09:11 AM Click Here to See the Profile for ls3machSend a Private Message to ls3machEdit/Delete MessageReply w/QuoteDirect Link to This Post
I really like the Samsung CLP-315W. I have a few of them. Toner is reasonable. I also have an HP M375nw. The toner is more expensive, and likely a lot of more than you are needing from a printer.
pokeyfiero
Total ratings: 306
Report this Post04-02-2014 01:34 PM Click Here to See the Profile for pokeyfieroClick Here to visit pokeyfiero's HomePageSend a Private Message to pokeyfieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Ok , so toner seems to be the best bet. I'll start looking at those. Thanks guys.
Report this Post04-02-2014 01:56 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Note: What you print matters...
Page Spec are % of page covered by ink/toner and means text and "spot color."
Backgrounds and pictures eats ink and toner no matter what type/class of printer.
1. # of copies likely means laser printer. Pennies per page and fast.
Home/SOHO classes will run out of ink. Can be issues for same class of laser.
Business class ink printers are fast and ink tank has large capacity.
Business Color and B/W lasers and ink printer get more prints per cart but cost around same $ as SOHO units But Business class units often cost more up front.
2. HP is high but is "future proof." Most HP printer ever made are using same driver setup and still works w/ win7 etc. If OS doesn't use exact driver, many current drivers work with old printers.
Allot of others brands have problem when you the updated OS.
example:
Finding Win7 x64 (64 bit) drivers for old HP printers? Easy. Just tell Win7 to get driver from MS internet library. (I mean old... Original LaserJet series, LJ2, etc.)
Do same for other brand often is not easy most times and Maker's support might not have one either.
Is can be a big problem... MS change Window name, Vista 7 8.x etc, but is minor kernel updates. Even minor update can cause many drivers have problem.
To make it more confusing... Many drivers say supports Vista and 7 but only x86 (32 bit) versions. Big problem when buying used devices. Most 7 & 8.x installs are x64 and will not load x86 drivers. (Let's ignore any workaround. Not supported by MS or anyone else.)
[This message has been edited by theogre (edited 04-02-2014).]
Report this Post04-02-2014 02:13 PM Click Here to See the Profile for 2.5Send a Private Message to 2.5Edit/Delete MessageReply w/QuoteDirect Link to This Post
Yeah consider farming the print job out. At least get estimates.
rogergarrison
Total ratings: 551
Report this Post04-02-2014 04:55 PM Click Here to See the Profile for rogergarrisonSend a Private Message to rogergarrisonEdit/Delete MessageReply w/QuoteDirect Link to This Post
I used to print LOTS of photos. I like Canon printers best. mine all have like 5 cartridges for photo printing. I havent bought any lately, but I was going online and getting 70 mixed cartridges for $50. It was I think www.inkcartridges.com . I do have a Brother all in one, but it prints slow as hell but I needed the fax. I get all 4 cartidges (and there big) for like $15. My HP uses just a black and a tri color...black was $40, Color was $70. I just use it for printing checks and estimates (blk only).
I DO know people that just buy a new cheap printer when the ink runs out because its cheaper that way.
[This message has been edited by rogergarrison (edited 04-02-2014).]
Doug85GT
Total ratings: 128
Report this Post04-02-2014 05:12 PM Click Here to See the Profile for Doug85GTSend a Private Message to Doug85GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
+1 on laser printer. They are excellent, quick and cheaper to operate over the long term.
Be sure your printer has duplex printing if you want it to print on both sides. The lower end models do not have that feature.
In most major cities, there are usually stores that sell used commercial office equipment like copiers, computers and printers. You can usually get a good deal on a used printer there. Just make sure they have a return and/or exchange policy in case you get a bad one.
