  Totally O/T
  truck chassis
truck chassis by heybjorn
Started on: 04-08-2014 08:56 AM
Replies: 17 (227 views)
Last post by: ls3mach on 04-08-2014 09:16 PM
heybjorn
Total ratings: 97
Report this Post04-08-2014 08:56 AM Click Here to See the Profile for heybjornSend a Private Message to heybjornEdit/Delete MessageReply w/QuoteDirect Link to This Post
Do small pickups, S 10, Ranger, have a separate frame for load carrying capacity? Is the frame plus box just the least expensive way to add the bed? As far as I can discover online, cabs appear to made the same way and of the same material, stamped and spot welded 16-18 gauge steel, as sedans. Couldn't one be built with a unit body engine bay and cab and the box frame welded to the cab? I assume the engineering would be easy enough ( 84fiero123, please weigh in that ) but cost would be the reason this isn't done. The Honda Ridgeline is unit body but isn't a truck, is it?
84fiero123
Total ratings: 325
Report this Post04-08-2014 09:14 AM Click Here to See the Profile for 84fiero123Send a Private Message to 84fiero123Edit/Delete MessageReply w/QuoteDirect Link to This Post
No it is all one frame, front to back, cab and bed are all on the same frame. the reason I think is so that the load in the bed, sometimes being a half ton or more. hey I often over load my pickups and so do many others and the manufacturers know that. if the bed were attached to the cab overloading the bed would bend the cab as well as the frame. I guess, who knows, I ain't no engineer. they both have separate mounting rubber mounting donuts or whatever they are called, allowing for separate flexing of the bed and cab, ever load a bed with more weight on one side than the other? I forget, haven't had my second cup of coffee yet and just got off Skype with our favorite limey, that confused me even more,
Steve
Total ratings: 441
Report this Post04-08-2014 09:16 AM Click Here to See the Profile for maryjaneSend a Private Message to maryjaneEdit/Delete MessageReply w/QuoteDirect Link to This Post
no heybjorn..
(Steve beat me to it)
The weight carried in the bed, causes what might appear to be a solid frame to flex differently than a car does from front to back--in 2 different planes--vertically and horizontally. They can do it on vehicles like heavy Suburbans because it is generally assumed the weight and abuse put inside a Suburban won't be as much as in the bed of a pickup, (even tho a Burb has a truck frame) but that flexing is why there is a little gap between the bed and the cab. Early 60s Ford Rancheros had a bad habit of body cracks appearing right behind the cab. Don't know if El Caminos had any similar issues or not.
Making a unibody pickup would also limit what type bed options the end user has. They do it in Europe with some small trucks I think.
[This message has been edited by maryjane (edited 04-08-2014).]
heybjorn
Total ratings: 97
Report this Post04-08-2014 10:41 AM Click Here to See the Profile for heybjornSend a Private Message to heybjornEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks guys.
If you were building a custom/show truck which would never haul anything more than the rear axle, could you eliminate the frame under the cab then?
Every night. Especially my side.
84fiero123
Total ratings: 325
Report this Post04-08-2014 10:50 AM Click Here to See the Profile for 84fiero123Send a Private Message to 84fiero123Edit/Delete MessageReply w/QuoteDirect Link to This Post
no heybjorn..
Ayup and I think that was also a problem when Ford first started making their big Burb type vehicle, forget the name, but I think that was one of the problems with their version of the big Burb type as well, everything is a lot heavier on the Burb than a lot of people realize, everything is over kill on the burbs, some have said the 1500/half ton Burbs are actually 3/4 ton trucks but labeled 1/2 ton so people don't try to overload them. but even the Ford version is not uni-body, so I may be wrong about that.
Our first Burb, 86 1/2 ton Melanie came home with like 3/4 of a ton of feed, don't ask she bought that much and no one said anything at the feed store and they just loaded it. when she got home the thing was on the body bumpers, I looked at it from inside the house and almost had a heart attack. the tires were so overloaded they were bulging badly, but it didn't hurt it, never broke anything, springs or nothing. So those people who say that about them my be right, I have no idea, I am no engineer. But it also may have something to do with the extra weight of the wagon type body style of the Burb type vehicles as well if not suspended over the frame right it can cause all sorts of problems with the body welds and fitment. GM has been making the Burban name plate since the 30s so they have a lot of experience at it. That actually is what they call the Burbs body style in the owners manual, "Station wagon body style".
Steve
rogergarrison
Total ratings: 551
Report this Post04-08-2014 11:12 AM Click Here to See the Profile for rogergarrisonSend a Private Message to rogergarrisonEdit/Delete MessageReply w/QuoteDirect Link to This Post
I think your talking about the Expedition and Excursion Steve...also known as a Fordasaurus.
84fiero123
Total ratings: 325
Report this Post04-08-2014 12:12 PM Click Here to See the Profile for 84fiero123Send a Private Message to 84fiero123Edit/Delete MessageReply w/QuoteDirect Link to This Post
I like that!
I did like some of the things they came standard with or maybe they were options I though GM should have put in the Burbs like auto folding mirrors when you got out, nice when the parking space was tight. As well as a lot of Dodges little things like the alarm when you leave your turn signal on for so long. And many others that GM is so far behind on.
Steve
[This message has been edited by 84fiero123 (edited 04-08-2014).]
ray b
Total ratings: 325
Report this Post04-08-2014 01:27 PM Click Here to See the Profile for ray bSend a Private Message to ray bEdit/Delete MessageReply w/QuoteDirect Link to This Post
I weight our suburban at 8700lbs loaded/overloaded it was a 1/2 ton model
but the county uses them like that
I was surprised at the size of the ranger frame and bits under there
I had a chevy el camino and it was way lighter built [with car parts]
84fiero123
Total ratings: 325
Report this Post04-08-2014 05:05 PM Click Here to See the Profile for 84fiero123Send a Private Message to 84fiero123Edit/Delete MessageReply w/QuoteDirect Link to This Post
GM engineers are not all that bright to say the least
What year burb?
Steve
Monkeyman
Total ratings: 182
Report this Post04-08-2014 05:14 PM Click Here to See the Profile for MonkeymanSend a Private Message to MonkeymanEdit/Delete MessageReply w/QuoteDirect Link to This Post
The Expedition would be equivalent to a 4 door Bronco/Blazer. The Excursion was the Ford equivalent to the Chevy/GMC Suburban. ALL Excursions were 3/4 ton rated. The 'Burb came in 1/2 ton and 3/4 ton versions. I like "Fordasaurus". I'd love to have one....someday. BTW, the Yukon XL is a Suburban with different trim.
heybjorn
Total ratings: 97
Report this Post04-08-2014 06:00 PM Click Here to See the Profile for heybjornSend a Private Message to heybjornEdit/Delete MessageReply w/QuoteDirect Link to This Post
What a fascinating discussion of the Suburbs, sorry, Suburbans, or would that be sorry Suburban? Now does any have a thought about my second question?
84fiero123
Total ratings: 325
Report this Post04-08-2014 07:11 PM Click Here to See the Profile for 84fiero123Send a Private Message to 84fiero123Edit/Delete MessageReply w/QuoteDirect Link to This Post
No
Steve
Total ratings: 229
Report this Post04-08-2014 07:22 PM Click Here to See the Profile for blackramsSend a Private Message to blackramsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Mike,
All the hard parts, engine, transmission, drive line, differential, shocks, suspension, axles, etc..... are mounted to that frame (one way or another) you're wanting to eliminate. Additionally, you're talking about sheet metal that was not intended to or designed to carry a load. I suppose if one undertook such a project, you could weld it up, load it on a trailer and transport it to a show but you're going to have to mount all that hardware somewhere and that sheet metal won't take it.
Steve is correct, removing the frame would result in a pile of sheet metal.
Ron
My Uncle Frank was a staunch Conservative and voted straight Republican until the day he died in Chicago. Since then he has voted Democrat. Shrug
heybjorn
Total ratings: 97
Report this Post04-08-2014 07:45 PM Click Here to See the Profile for heybjornSend a Private Message to heybjornEdit/Delete MessageReply w/QuoteDirect Link to This Post
OK.
84fiero123
Total ratings: 325
Report this Post04-08-2014 08:51 PM Click Here to See the Profile for 84fiero123Send a Private Message to 84fiero123Edit/Delete MessageReply w/QuoteDirect Link to This Post
What, Steve, meaning me is right, How is that possible on any subject?
Just kidding you dude.
I recall one engineer saying my welds are not that good in a thread a while ago, not realizing that anything I weld now days is basically blind folded because I weld without a hood on most of my projects on the farm, they will hold up and do hold up just fine. That set of saw horses I made I have put several 2"x12" boards across to use as staging and they held me and a friend of mine up just fine to do a new window in the house a while back.
Although I have to say that Dodge does make uni-body cars without any real frame so I suppose it is possible, but they did like our Fieros are made by making frame rails of sheet metal, not as strong as a full frame vehicle but I suppose it is still possible but you would have to be one talented sheet metal worker and welder to build something like that. Roger and Nick are the only 2 people I would trust to do a project like that. I wouldn't even attempt it myself, I'm a welder but not a sheet metal guy. While I can weld sheet metal and even bend it, I wouldn't trust myself to do something like that. I suppose you could start out with a uni-body type truck, do they even make those? or maybe a car and make something like the old Ranchero and work your way from there but you would have to be one talented guy.
Steve
ls3mach
Total ratings: 226
Report this Post04-08-2014 09:06 PM Click Here to See the Profile for ls3machSend a Private Message to ls3machEdit/Delete MessageReply w/QuoteDirect Link to This Post
Steve
I'd like to offer that payload isn't what you call a 1/2 ton, 3/4 ton, or 1 ton.
http://www.ford.com/trucks/...cifications/payload/
http://auto.howstuffworks.c...ehicle/payload15.htm
[This message has been edited by ls3mach (edited 04-08-2014).]
84fiero123
Total ratings: 325
Report this Post04-08-2014 09:13 PM Click Here to See the Profile for 84fiero123Send a Private Message to 84fiero123Edit/Delete MessageReply w/QuoteDirect Link to This Post
I think when they say payload they are adding passengers as well and with todays average person weighing in at lets just say 200 lbs to make the figuring easy, 5 passengers would take up all of that 1/2 ton and in the case of a suburban type vehicle with 9 passenger capacity that would be 1800 lbs. but I have been told before I was wrong, about just about everything I say.
http://ask.cars.com/2010/04...-drivers-weight.html
Steve
ls3mach
Total ratings: 226
Report this Post04-08-2014 09:16 PM Click Here to See the Profile for ls3machSend a Private Message to ls3machEdit/Delete MessageReply w/QuoteDirect Link to This Post
Steve
There is an actual chart somewhere where it shows GVWR and hauling and towing capacity. I've had a bunch of weight in all my trucks. I notice my 4x4 diesel squats almost none compared to my 4x2 gasser. I assume it has something to do with HD suspension, but the gasser is a single cab and is supposed to have a better payload... I can promise the breaks suck compared to my diesel F250s. We pulled my 25' goose neck once and warped every rotor and had to replace the pads too.
