  Totally O/T
  Peanut brittle 1 tooth 0 Need a bit of direction
Peanut brittle 1 tooth 0 Need a bit of direction by jetsnvettes2000
Started on: 04-27-2014 10:40 PM
Replies: 16 (247 views)
Last post by: heybjorn on 04-28-2014 08:36 PM
jetsnvettes2000
Report this Post04-27-2014 10:40 PM Click Here to See the Profile for jetsnvettes2000Send a Private Message to jetsnvettes2000Edit/Delete MessageReply w/QuoteDirect Link to This Post
So, my daughter talked me into buying some peanut brittle and well I took a bite and it won. So, now I sit here in a bit of pain as I swallowed a quarter of one of my molars. Anyone have a easy temp fix? IT HURTS!!!!!! and how much should I expect to pay to fix it. I do not have dental thanks to our lovely government killing my nice health care plan that I had dental with at work.
California Kid
Total ratings: 274
Report this Post04-27-2014 10:43 PM Click Here to See the Profile for California KidSend a Private Message to California KidEdit/Delete MessageReply w/QuoteDirect Link to This Post
Heard "Cloves" work, but never tried it.
Crown's run about $400 and up depending on Dentist.
hookdonspeed
Total ratings: 131
Report this Post04-27-2014 10:54 PM Click Here to See the Profile for hookdonspeedClick Here to visit hookdonspeed's HomePageSend a Private Message to hookdonspeedEdit/Delete MessageReply w/QuoteDirect Link to This Post
press crushed aspirin on it or something like that, lots of orajel maybe?
ibuprofen is the best painkiller for toothaches without prescription... whole lotta screaming?
hope ya get it fixed fast, tooth pain is the worse!
jetsnvettes2000
Report this Post04-27-2014 10:55 PM Click Here to See the Profile for jetsnvettes2000Send a Private Message to jetsnvettes2000Edit/Delete MessageReply w/QuoteDirect Link to This Post
Ouch I would rather they just pull it at that cost. It is in the back anyway so will not effect my hotness lol
jetsnvettes2000
Report this Post04-27-2014 10:59 PM Click Here to See the Profile for jetsnvettes2000Send a Private Message to jetsnvettes2000Edit/Delete MessageReply w/QuoteDirect Link to This Post
jetsnvettes2000
Member since Dec 2009
I have some numbing stuff I put on it and grabbed a little jar of temp filling but I do not think this will hold. the whole corner broke off so there is nothing for it to hold onto but I am going to try anyway this really hurts!!!! Funny thing tho as this all went on my daughter lost a tooth as well weird!!!
Khw
Total ratings: 134
Report this Post04-28-2014 12:45 AM Click Here to See the Profile for KhwSend a Private Message to KhwEdit/Delete MessageReply w/QuoteDirect Link to This Post
I wish there was something I could tell you that you aren't already trying . I HATE when my tooth aches. I can't sleep. I can't seem to do anything to get my mind off the throbbing. Eating and drinking becomes extremely difficult. Tooth pain is one of the worst pains IMHO. I'm not saying I haven't had other pain that hurt more or that I don't commonly have pain that is just as annoying and as much of a hindrance, but something about tooth pain just drives me bonkers. Here's hoping you can get to a dentist quick!
pokeyfiero
Total ratings: 309
Report this Post04-28-2014 12:53 AM Click Here to See the Profile for pokeyfieroClick Here to visit pokeyfiero's HomePageSend a Private Message to pokeyfieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Take drugs... Copious amounts of drugs!!!!!
OMG it hurts just thinking about it.
You must have a vicodin in one of those drawers!
ls3mach
Total ratings: 226
Report this Post04-28-2014 10:01 AM Click Here to See the Profile for ls3machSend a Private Message to ls3machEdit/Delete MessageReply w/QuoteDirect Link to This Post
$400 to save a tooth is too much?
Aspirin, don't crush it, just hold it there.
hnthomps
Total ratings: 51
Report this Post04-28-2014 10:35 AM Click Here to See the Profile for hnthompsSend a Private Message to hnthompsEdit/Delete MessageReply w/QuoteDirect Link to This Post
If you just yank it out you may then require a partial plate to prevent your teeth from shifting to fill the gap. Partials and implants are likely to cost even more than saving the tooth. If your dentist has the right equipment, he/she can do a HD scan of the tooth remains and use a CNC mill to construct a replacement piece and attach it to your remaining tooth. The process is called an "inlay" and appears to work at least as well as a crown but at a slightly lower cost. It is certainly faster and mine was done in less than one hour start to finish.
Nelson
aceman
Total ratings: 203
Report this Post04-28-2014 10:39 AM Click Here to See the Profile for acemanSend a Private Message to acemanEdit/Delete MessageReply w/QuoteDirect Link to This Post
I've has 3 of the 4 far back molars pulled. If it was the farthest back molar, you could probably get by with extracting it. I regret having them pulled as I now have 2 root canals and crowns on one side of the mouth that could have gone together to create a bridge/partial. An extraction will probably cost a couple hundred. Just look into getting it crowned.
loafer87gt
Total ratings: 163
Report this Post04-28-2014 10:41 AM Click Here to See the Profile for loafer87gtSend a Private Message to loafer87gtEdit/Delete MessageReply w/QuoteDirect Link to This Post
If you have a nearby dental college nearby check with them to see if they take outside patients. My previous dentist estimate $900+ to have a crown done of one of my rear molars, but the folks at the dental college were able to get me in, do all the necessary prep work and crown for under $600.
James Bond 007
Total ratings: 263
Report this Post04-28-2014 11:10 AM Click Here to See the Profile for James Bond 007Send a Private Message to James Bond 007Edit/Delete MessageReply w/QuoteDirect Link to This Post
I just had the same situation, but on a hard cookie! PM sent.
Report this Post04-28-2014 01:05 PM Click Here to See the Profile for 2.5Send a Private Message to 2.5Edit/Delete MessageReply w/QuoteDirect Link to This Post
Aleve or Ibuprofen should help.
[This message has been edited by 2.5 (edited 04-28-2014).]
Red88FF
Total ratings: 130
Report this Post04-28-2014 02:22 PM Click Here to See the Profile for Red88FFSend a Private Message to Red88FFEdit/Delete MessageReply w/QuoteDirect Link to This Post
Spend the money and save the tooth, and get some real pain meds. You will not regret it later. If you don't. the pain will either go away on it's own done that before or get very very bad done that too.
I need some work done but the last toot canal and crown I got was over three grand all said and done. I am lucky not so much and have these dammed hooked roots is why the cost. You will use and need your teeth the rest of your life so act accordingly.
jetsnvettes2000
Report this Post04-28-2014 07:19 PM Click Here to See the Profile for jetsnvettes2000Send a Private Message to jetsnvettes2000Edit/Delete MessageReply w/QuoteDirect Link to This Post
Well, good news got into dentist and they are going to fix it for under 200 bucks since it was the filling they put in that fell out and caused the problem. SO, Wednesday I go in and they are going to rebuild it somehow I guess.
Red88FF
Total ratings: 130
Report this Post04-28-2014 08:34 PM Click Here to See the Profile for Red88FFSend a Private Message to Red88FFEdit/Delete MessageReply w/QuoteDirect Link to This Post
AWSOME! interesting that most went with a worst case scenario. I hate going in, not much scares me but I fear the dentist
heybjorn
Total ratings: 97
Report this Post04-28-2014 08:36 PM Click Here to See the Profile for heybjornSend a Private Message to heybjornEdit/Delete MessageReply w/QuoteDirect Link to This Post
They will rebuild it with magic and a Dremel tool. I hope it solves your tooth problem permanently.
