  Totally O/T
  Just Letting You Know About A Good Deal On A 120GB Solid State Drive...
Just Letting You Know About A Good Deal On A 120GB Solid State Drive... by Boondawg
Started on: 04-29-2014 11:53 AM
Replies: 14 (369 views)
Last post by: Boondawg on 05-04-2014 05:14 PM
Boondawg
Total ratings: 342
Report this Post04-29-2014 11:53 AM Click Here to See the Profile for BoondawgSend a Private Message to BoondawgEdit/Delete MessageReply w/QuoteDirect Link to This Post
I start my build today, and after experiencing first-hand how great SSD's cut boot times of the operating system (my old system has a 64GB SSD), I just can't go back to the old 'spinning-mass' boot system.
At 50 cents a GB, I had to make my play...
DANGERUS
Report this Post04-29-2014 01:05 PM Click Here to See the Profile for DANGERUSSend a Private Message to DANGERUSEdit/Delete MessageReply w/QuoteDirect Link to This Post
Just a question; what would go wrong with a solid state drive that people are refurbishing them? Are there quality issues? I guess that's two questions.
Boondawg
Total ratings: 342
Report this Post04-29-2014 01:53 PM Click Here to See the Profile for BoondawgSend a Private Message to BoondawgEdit/Delete MessageReply w/QuoteDirect Link to This Post
I am guessing someone didn't know how to configure their computer for it.
Probably sent it back saying "It don't work!"
Or it could have just needed (and been given) a firmware update.
At any rate, Crucial AND Newegg have an excellent customer service department and have never let me down on repairs, returns, or replacement.
Capt Fiero
Total ratings: 260
Report this Post04-29-2014 02:26 PM Click Here to See the Profile for Capt FieroClick Here to visit Capt Fiero's HomePageSend a Private Message to Capt FieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Boonies probably right, about the customer not knowing what they were doing. My first SSD swap into my I7 Laptop was a piece of cake, however when I went to do the same to my desktop, it was a freaking nightmare. I have 9 hard drives in my machine, and tried to run the SSD from one of the add in SATA cards, it would not work due to a driver issue, tried to run it on the MB and Bios flipped out. Finally after a bios update it would work. The average person would have taken it back when the MB said it was a dead or nonexistent drive. I get a lot of good tech parts from the "open box" bin at my local computer store. As usually there is nothing wrong with it, it was just a display model, or customer bought it, couldn't figure it out and returned it. This is especially true if you buy a lot of OEM stuff that does not come with any drivers or instructions.
857GT Part 85GT Part 87GT Part Caddy, 93 Eldorado 4.9, 5spd Dual O2 Custom Chip, Custom Exhaust. MSD Everything Now with Nitrous. Capt Fiero --- My Over View Cadero Pics For Sale $4000, Yellow 88GT 5spd Full Poly Suspension, Lowered 1/2" in front, Corner Carver.
Blacktree
Total ratings: 350
Report this Post04-29-2014 03:52 PM Click Here to See the Profile for BlacktreeClick Here to visit Blacktree's HomePageSend a Private Message to BlacktreeEdit/Delete MessageReply w/QuoteDirect Link to This Post
I know what you mean, Boonie. About a year or so ago, I snagged an OCZ Vertex 240GB SSD on sale, and never looked back. I still keep a standard hard drive for bulk storage, but will not go back to a standard hard drive as the boot drive unless I have no other choice.
James Bond 007
Total ratings: 263
Report this Post04-29-2014 04:05 PM Click Here to See the Profile for James Bond 007Send a Private Message to James Bond 007Edit/Delete MessageReply w/QuoteDirect Link to This Post
Not bad and Thanks for the tip...Would be nice if you had a Frys Electronics,
http://www.bhphotovideo.com...&Q=&is=REG&A=details
Edit: sorry wrong link to frys Electronics.
http://www.frys.com/categor...d+Drives+-+External/
[This message has been edited by James Bond 007 (edited 04-29-2014).]
Boondawg
Total ratings: 342
Report this Post04-29-2014 05:37 PM Click Here to See the Profile for BoondawgSend a Private Message to BoondawgEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by James Bond 007:
Not bad and Thanks for the tip...Would be nice if you had a link to frys Electronics.
Yeah, sorry, I spaced it out:
http://www.newegg.com/Produ...SSD-_-20233471-L010D
Well, I got my old system all swapped over into the new box with a spare Thermaltake 600watt power supply to have it up & running while I build the new system in my current NZXT Phantom box.
When plugging everything in I see that the Thermaltake 600watt powersupply don't have an 8pin 12v power plug that my motherboard requires in addition to the 24pin ATX.
I seem to remember that I have an adaptor for just such an instance when using older powersupplies with newer motherboards somewhere, but I'm not sure I'm even remembering correctly.
Regardless, if I have it, I couldn't find it.
I also noticed my videocards take 4 - 6pin PCI-e plugs (2 each card) and the Thermaltake 600watt powersupply only had 2 PCI-e plugs.
I'm sure there are adaptors somewhere, but again I could not find them.
So, I had to put my old system back together (which I am typing from now) until I can get the powersupply adapters I require.
Project Progress?
Stalled.
[This message has been edited by Boondawg (edited 04-29-2014).]
Boondawg
Total ratings: 342
Report this Post04-29-2014 10:35 PM Click Here to See the Profile for BoondawgSend a Private Message to BoondawgEdit/Delete MessageReply w/QuoteDirect Link to This Post
Boondawg
Member since Jun 2003
Cool, it took some diggin' but I found what I need.
2 Double Molex to PCIe, a 4pin to 8pin adapter, and a 8" Molex doubler.
I even found an old 24pin to 20pin power supply to motherboard adapter!
I guess it pays to hold onto every wire, screw, bolt, bracket, & cable you ever come across!
Boondawg
Total ratings: 342
Report this Post05-04-2014 12:35 PM Click Here to See the Profile for BoondawgSend a Private Message to BoondawgEdit/Delete MessageReply w/QuoteDirect Link to This Post
Time to build some computers today!
Got everything I need, feel good, feel strong, mind is fresh & clear....let's let some magic smoke out!!
Report this Post05-04-2014 02:05 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
As long as you refrain from inhaling "magic smoke" during the assembly, you'll be fine.
htexans1
Total ratings: 118
Report this Post05-04-2014 02:20 PM Click Here to See the Profile for htexans1Send a Private Message to htexans1Edit/Delete MessageReply w/QuoteDirect Link to This Post
Space, the final frontier SSD style Im getting a couple for laptops. Heck I just may replace the desktop drive (booting side) with one, too
With what you ask? A 1 Terabyte SSD drive. Not a hybrid, a true 1 terabyte pure SSD drive.
and its under $500!
http://www.amazon.com/Samsu...words=1+tb+ssd+drive
Now back to Boonie's build!! I gotta see how this comes out. Whenever this man starts on a build, I just HAVE TO WATCH!!
[This message has been edited by htexans1 (edited 05-04-2014).]
Blacktree
Total ratings: 350
Report this Post05-04-2014 03:22 PM Click Here to See the Profile for BlacktreeClick Here to visit Blacktree's HomePageSend a Private Message to BlacktreeEdit/Delete MessageReply w/QuoteDirect Link to This Post
So the big question is: Will Boonie keep doing the SLI thing, or will he go for a single high-end video card?
htexans1
Total ratings: 118
Report this Post05-04-2014 04:21 PM Click Here to See the Profile for htexans1Send a Private Message to htexans1Edit/Delete MessageReply w/QuoteDirect Link to This Post
Because Inquiring minds wish to know.
Boondawg
Total ratings: 342
Report this Post05-04-2014 05:12 PM Click Here to See the Profile for BoondawgSend a Private Message to BoondawgEdit/Delete MessageReply w/QuoteDirect Link to This Post
I will have to use my existing cards for now.
I'm out of money.
The question is valid, though, as I have been giving that lots of thought for the future.
If pressed for a definitive answer, I am an SLI-guy.
And always have been since the Diamond Monster 3D days.
I paid $300 apiece for those cards back in the day!
That's like $600-apiece money today!
Boondawg
Total ratings: 342
Report this Post05-04-2014 05:14 PM Click Here to See the Profile for BoondawgSend a Private Message to BoondawgEdit/Delete MessageReply w/QuoteDirect Link to This Post
Boondawg
P.S. I got all my old computer parts in the new box and am posting from it now.
The swap got up & running with nary a hiccup.
Pictures to follow.
Continued here: https://www.fiero.nl/forum/F.../HTML/106603.html#p0
[This message has been edited by Boondawg (edited 05-04-2014).]
