  Totally O/T
  What Will Happen If You Let A Beaded Chain Pull Itself From a Glass.....Up On A Roof?
What Will Happen If You Let A Beaded Chain Pull Itself From a Glass.....Up On A Roof? by Boondawg
Started on: 04-30-2014 10:11 PM
Replies: 16 (439 views)
Last post by: Marvin McInnis on 05-02-2014 12:53 PM
Boondawg
Total ratings: 342
Report this Post04-30-2014 10:11 PM Click Here to See the Profile for BoondawgSend a Private Message to BoondawgEdit/Delete MessageReply w/QuoteDirect Link to This Post
How:
Click to show
[This message has been edited by Boondawg (edited 04-30-2014).]
Wichita
Report this Post04-30-2014 11:06 PM Click Here to See the Profile for WichitaSend a Private Message to WichitaEdit/Delete MessageReply w/QuoteDirect Link to This Post
I would like to see it dropped from a higher location than a house roof.
But that is very cool.
Marvin McInnis
Total ratings: 227
Report this Post05-01-2014 01:01 AM Click Here to See the Profile for Marvin McInnisClick Here to visit Marvin McInnis's HomePageSend a Private Message to Marvin McInnisEdit/Delete MessageReply w/QuoteDirect Link to This Post
Cool ... and an excellent example of a simple but powerful experiment. I've never thought about centrifugal acceleration that way. (Hint: Think of a jet of water in place of the chain. The source of energy driving the motion is different, but the trajectories are similar.)
[This message has been edited by Marvin McInnis (edited 05-01-2014).]
lurker
Total ratings: 236
Report this Post05-01-2014 01:33 AM Click Here to See the Profile for lurkerSend a Private Message to lurkerEdit/Delete MessageReply w/QuoteDirect Link to This Post
question about youtube:
after the linked video plays, do the other videos offered on the page depend on what the person who linked looked at earlier?
Total ratings: 466
Report this Post05-01-2014 01:40 AM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Ah yes, the trajectory. Reminds me of the last time I drank beer while out in the woods.
Marvin, here's a question for you. Since the pot pushes the end of each rod on the chain up as the rod pivots (which supplies that extra bit of acceleration), what would the end result be if the experiment was done in a high speed elevator? For argument's sake, let's say a hundred foot chain would only drop 20 feet before it hits the "floor" in either scenario (to eliminate the variable of a greater weight of chain due to an increased drop). Would the trajectory of the chain be higher, or lower, as it's being pulled out of an ascending pot compared to a stationary pot... or to a descending pot?
[This message has been edited by Patrick (edited 05-01-2014).]
heybjorn
Total ratings: 97
Report this Post05-01-2014 07:58 AM Click Here to See the Profile for heybjornSend a Private Message to heybjornEdit/Delete MessageReply w/QuoteDirect Link to This Post
It couldn't take off, Patrick.
I enjoyed learning this. Thanks for posting it, Boondawg.
Report this Post05-01-2014 08:38 AM Click Here to See the Profile for 2.5Send a Private Message to 2.5Edit/Delete MessageReply w/QuoteDirect Link to This Post
Is that what ya call kinetic energy?
Marvin McInnis
Total ratings: 227
Report this Post05-01-2014 11:29 AM Click Here to See the Profile for Marvin McInnisClick Here to visit Marvin McInnis's HomePageSend a Private Message to Marvin McInnisEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by Patrick:
Since the pot pushes the end of each rod on the chain up ...
No. The desending chain, which is inelastic, pulls itself out of the reservoir. The key consideration is that the speed is the same everywhere along the chain. Say the chain is descending at 50 feet per second. That means that the chain must also be moving upward at 50 fps as it leaves the reservoir.
I think it would be the same, as long as the elevator is moving at constant velocity (i.e. not accelerating or decelerating).
Total ratings: 466
Report this Post05-01-2014 12:25 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Marvin, did you watch the second video that Boonie linked to? They spent a considerable amount of time discussing how the pot also "pushes" the chain, and this is why I was wondering if movement (up or down) of the pot itself might affect the trajectory of the chain.
Marvin McInnis
Total ratings: 227
Report this Post05-01-2014 12:56 PM Click Here to See the Profile for Marvin McInnisClick Here to visit Marvin McInnis's HomePageSend a Private Message to Marvin McInnisEdit/Delete MessageReply w/QuoteDirect Link to This Post
... the pot also "pushes" the chain ...
I disagree. At the very least, they failed to consider the stiffness/flexibility of the links connecting the masses. I think that is probably important, as well as the mass distribution. I would like to see the experiment repeated with moderately stiff rope or wire cable, either of which has a continuous mass distribution and would eliminate the alleged dynamic "kick" from the reservoir. Of course, both rope and cable have significant internal friction, which might serve to dampen the dynamic effects.
Purple86GT
Total ratings: 62
Report this Post05-01-2014 01:09 PM Click Here to See the Profile for Purple86GTSend a Private Message to Purple86GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
The pot does not really push up on the chain (unless you are talking about opposing forces ect..) but it does store the potential energy of the chain’s kinetic energy. Much like a syphon works, as long as your output is lower than your input, gravity will do the rest. The chain has a surface tension cause by the links. The faster the chain drops, the less time the chain has to “flex” and therefore pulls itself up from the pot. The limits will be reached when the chain reaches its terminal velocity.
Interesting experiment would be to make a loop… A motor that would provide just enough force to bring the chain back up in the pot and make an endless loop.
Blacktree
Total ratings: 350
Report this Post05-01-2014 01:17 PM Click Here to See the Profile for BlacktreeClick Here to visit Blacktree's HomePageSend a Private Message to BlacktreeEdit/Delete MessageReply w/QuoteDirect Link to This Post
I suppose you could test that theory by lifting and/or lowering the pot while the chain is playing out, and see how it affects the trajectory. Actually, since the experimenters are holding the pot in their hands during the experiment, the pot must be pushing down on their hand anyway (equal and opposite force to the one pushing the chain up). Maybe ask them if they feel an extra downward push when the chain starts playing out.
[This message has been edited by Blacktree (edited 05-01-2014).]
Marvin McInnis
Total ratings: 227
Report this Post05-01-2014 03:16 PM Click Here to See the Profile for Marvin McInnisClick Here to visit Marvin McInnis's HomePageSend a Private Message to Marvin McInnisEdit/Delete MessageReply w/QuoteDirect Link to This Post
A better experimental design would be to put the reservoir on a sensitive scale, sitting on a firm table. If the reservoir is indeed "pushing" the chain, the weight of the reservoir should decrease smoothly as the chain is depleted, but there should be an abrupt drop in measured force as the last link of chain breaks contact with the bottom of the reservoir.
Neils88
Total ratings: 56
Report this Post05-01-2014 07:38 PM Click Here to See the Profile for Neils88Send a Private Message to Neils88Edit/Delete MessageReply w/QuoteDirect Link to This Post
Saw this on Mythbusters last month. Jamie did the same thing with a really large beaded-chain. The metal beads were each the size of large marbles...it was impressive, and obviously worked the same at the little chains in all the other videos.
Total ratings: 441
Report this Post05-01-2014 11:37 PM Click Here to See the Profile for maryjaneSend a Private Message to maryjaneEdit/Delete MessageReply w/QuoteDirect Link to This Post
I saw the wire rope that holds the hook and swivel come loose from the deadman clamp once. 1 5/8" diameter IIRC. Even after the hook hit the drilling floor, the cable just kept coming off the main spool, up thru the crown block sheaves and it arced up pretty high above the first sheave (big pulley).
(That was looking back over my shoulder as I was running down the steps--I think I only touched about 3 of the 30 steps )
Formula88
Total ratings: 554
Report this Post05-02-2014 11:19 AM Click Here to See the Profile for Formula88Send a Private Message to Formula88Edit/Delete MessageReply w/QuoteDirect Link to This Post
All they'll feel is the pot getting lighter as the chain feeds out. There is no upward force on the pot/chain other than the hand holding it in place. If the post is held stationary, that force is equal and opposite to gravity and is constant. As the chain feeds out, the mass reduces and less force is required to hold the pot.
As far as holding the pot is concerned, it's no different than pouring water out of a pitcher.
Marvin McInnis
Total ratings: 227
Report this Post05-02-2014 12:53 PM Click Here to See the Profile for Marvin McInnisClick Here to visit Marvin McInnis's HomePageSend a Private Message to Marvin McInnisEdit/Delete MessageReply w/QuoteDirect Link to This Post
Run away! BTDT.
[This message has been edited by Marvin McInnis (edited 05-02-2014).]
