  Totally O/T
  statue of liberty
statue of liberty by hookdonspeed
Started on: 05-03-2014 10:53 PM
Replies: 9 (372 views)
Last post by: Wichita on 05-04-2014 07:02 PM
hookdonspeed
Total ratings: 131
Report this Post05-03-2014 10:53 PM Click Here to See the Profile for hookdonspeedClick Here to visit hookdonspeed's HomePageSend a Private Message to hookdonspeedEdit/Delete MessageReply w/QuoteDirect Link to This Post
of all the things our government spends $ on, why dont they sandblast the statue of liberty back to its original copper color and clear coat is to keep it from oxidizing? would looks alot better in its natural metal color and not oxidized green....
craigsfiero2007
Total ratings: 71
Report this Post05-03-2014 11:13 PM Click Here to See the Profile for craigsfiero2007Send a Private Message to craigsfiero2007Edit/Delete MessageReply w/QuoteDirect Link to This Post
But if you go around and ask people what the original color of the statue of liberty was, they will more than likely say green. It would be really cool if it was a shiny copper color again though.
Formula88
Total ratings: 554
Report this Post05-03-2014 11:22 PM Click Here to See the Profile for Formula88Send a Private Message to Formula88Edit/Delete MessageReply w/QuoteDirect Link to This Post
The patina is intentional.
Copper’s most famous trait is its display from a bright metallic colour to iridescent brown to near black and finally to a greenish verdigris patina. Architects describe the array of browns as russet, chocolate, plum, mahogany, and ebony. The metal’s distinctive green patina has long been coveted by architects and designers.1
1The glory of copper; Metal Roofing Magazine, December 2002/January 2003
hookdonspeed
Total ratings: 131
Report this Post05-03-2014 11:27 PM Click Here to See the Profile for hookdonspeedClick Here to visit hookdonspeed's HomePageSend a Private Message to hookdonspeedEdit/Delete MessageReply w/QuoteDirect Link to This Post
eh.. fine then, blast it down and let people watch the transformation again took what, 30years to happen?
Boostdreamer
Total ratings: 98
Report this Post05-03-2014 11:38 PM Click Here to See the Profile for BoostdreamerSend a Private Message to BoostdreamerEdit/Delete MessageReply w/QuoteDirect Link to This Post
Copper oxidizes until there is a protective coating all over it. Then the oxidation stops and it protects the metal from further reaction with oxygen. It is the reason you DON'T have to paint or clear coat it.
spark1
Total ratings: 175
Report this Post05-03-2014 11:51 PM Click Here to See the Profile for spark1Send a Private Message to spark1Edit/Delete MessageReply w/QuoteDirect Link to This Post
The Arizona state capitol dome was restored to the original copper color many years ago and it still looks great!
Contrary to popular belief, the angel on top of the dome is not Moroni.
[This message has been edited by spark1 (edited 05-03-2014).]
cmechmann
Report this Post05-04-2014 12:02 AM Click Here to See the Profile for cmechmannSend a Private Message to cmechmannEdit/Delete MessageReply w/QuoteDirect Link to This Post
I had got away from working on cars for a while. During that time I had worked for a company that did a lot of historical buildings. Many of these had semi exotic metals. Lead, zinc, aluminum, stainless steel and copper. Had to learn the different ways to work with them. Each had their own characteristics. Some would work well with others. Some not.
Aluminum is really an easily corrosive metal by itself. But it is it's oxidation that makes it durable. Aluminum oxide is the second hardest naturally occurring substance, second to diamond. The oxide is so thin we can see through it. When you clean it off, the aluminum reacts so fast to oxygen, it takes very little time for the oxidation to reform. Mercury reacts with aluminum in a way which keeps the oxide from reforming and aluminum under those conditions, will "rott" away quickly.
Zinc and copper are very similar, with their oxides, but takes much longer(several years) The oxides are what makes them very resistant to water. Unlike ferrous metal's oxides, water does not penetrate into them. Cleaning these oxides reduces the thickness of the metals a little each time. So not only for the "look" the patinas are left on to lenthen their service life. The patinas will last decades longer than clear coats.
Most of the copper cladded building we worked on had the copper replaced not because they failed, but mostly due to damage. We had did the Naval Academy(Mother B) and most of the over 100 year old roof panels were replaced due to the many hurricane induced damage they had received or improper care. Most of the unreplacable ornimental metal work was cleaned, repaired and reinstalled.
Copper and zinc are mixed as alloys to add desired hardness. Both brass and bronze are copper/zinc (sometimes tin) alloys.
On the Supreme Court building we worked with brass, copper and lead. Government and historical buildings are the only ones EPA allows to have lead reinstalled.
On the Hippodrome Theater we worked with zinc on the marque. And the bank next door had copper ballisters and brass rails for snow/ice protection.
Edited note: one of the other biggest issues with roof panel corrosion also was from seagull and pigeon crap. The Maryland state highway building in Ocean city had to have the ridge cap replaced and bird spikes installed due to all the seagulls landing on it. (YUMMY)
[This message has been edited by cmechmann (edited 05-04-2014).]
DanDamage
Total ratings: 81
Report this Post05-04-2014 12:22 PM Click Here to See the Profile for DanDamageSend a Private Message to DanDamageEdit/Delete MessageReply w/QuoteDirect Link to This Post
they wont even spend the money till it looks like this
htexans1
Total ratings: 118
Report this Post05-04-2014 02:39 PM Click Here to See the Profile for htexans1Send a Private Message to htexans1Edit/Delete MessageReply w/QuoteDirect Link to This Post
The Kansas statehouse was recently redone to include its copper roof. Looking similar to the pic on here, except for "Ad Astra" depicting a Kanza indian shooting an arrow at the north star-- that statue is still green.
Wichita
Report this Post05-04-2014 07:02 PM Click Here to See the Profile for WichitaSend a Private Message to WichitaEdit/Delete MessageReply w/QuoteDirect Link to This Post
I signed my name on the bottom of that statue, before it was put up permanently installed on top of the dome.
