  Totally O/T
  Need advice on intake system smokers
Need advice on intake system smokers by Kitskaboodle
Started on: 05-04-2014 12:29 AM
Replies: 5 (154 views)
Last post by: 84fiero123 on 05-04-2014 04:31 PM
Kitskaboodle
Report this Post05-04-2014 12:29 AM Click Here to See the Profile for KitskaboodleSend a Private Message to KitskaboodleEdit/Delete MessageReply w/QuoteDirect Link to This Post
I would like to buy an affordable smoker for intake system leak detecting . I heard they are on Ebay for as low as 60.00. Has anyone bought one before? I have watched some YouTube videos on these smokers and they seem to be very helpful at finding intake manifold leaks. I have tried propane (with a hose attachment) but it's kind of hard to get the hose all around the plenum, intake manifolds, injectors, etc.. Bottom line is the propane method did not help me find the leak. The smoke method seems more foolproof and safer to boot. Lastly, I know some have made their own but I would prefer to buy one over the counter.
Any suggestions? Thanks, Kit
Total ratings: 297
Report this Post05-04-2014 12:39 AM Click Here to See the Profile for MidEngineManiacSend a Private Message to MidEngineManiacEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have had good luck using the O2 (with hose and nozzle) from an oxy-propane barzing kit like this http://www.canadiantire.ca/...9p.html#.U2XELVdHaM8
You will definatley hear it when the oxygen hits the leak. Or even n oxy-acetalyne torch if you have one handy.
[This message has been edited by MidEngineManiac (edited 05-04-2014).]
84fiero123
Total ratings: 325
Report this Post05-04-2014 11:20 AM Click Here to See the Profile for 84fiero123Send a Private Message to 84fiero123Edit/Delete MessageReply w/QuoteDirect Link to This Post
I like starting fluid or water, water is safer. starting fluid is dangerous around hot engine parts. so only use that when the engine is cold, when you hit a vacuum leak it will raise the RPMs quick when it comes close to a vacuum leak.
Steve
Kitskaboodle
Report this Post05-04-2014 03:02 PM Click Here to See the Profile for KitskaboodleSend a Private Message to KitskaboodleEdit/Delete MessageReply w/QuoteDirect Link to This Post
You can use water??
Is it as effective as propane, starting fluid or parts cleaner fluid?
Kit
Total ratings: 297
Report this Post05-04-2014 03:12 PM Click Here to See the Profile for MidEngineManiacSend a Private Message to MidEngineManiacEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by Kitskaboodle:
You can use water??
Kit
VERY carefully...I dont do or recommend it. Google "shock cooling". If you do, use a mist especially around aluminum castings.
84fiero123
Total ratings: 325
Report this Post05-04-2014 04:31 PM Click Here to See the Profile for 84fiero123Send a Private Message to 84fiero123Edit/Delete MessageReply w/QuoteDirect Link to This Post
Hey I didn't say I recommended it ether, nor did I recommend using the starting fluid but hey I have a death wish!
Steve
