  Totally O/T
  Cheap floor
Cheap floor by TXGOOD
Started on: 05-04-2014 06:38 PM
Replies: 4 (196 views)
Last post by: Boondawg on 05-04-2014 09:42 PM
TXGOOD
Total ratings: 87
Report this Post05-04-2014 06:38 PM Click Here to See the Profile for TXGOODClick Here to visit TXGOOD's HomePageSend a Private Message to TXGOODEdit/Delete MessageReply w/QuoteDirect Link to This Post
Well, a concrete floor was not in the equation but at least I won`t be laying on asphalt.
I got a part of my Garage Deck flooring installed today.
It`s not exactly level but it`s strong and it`s better than asphalt.
As soon as I move the posts I am going to make it about 4ft wider.
cliffw
Total ratings: 295
Report this Post05-04-2014 09:12 PM Click Here to See the Profile for cliffwSend a Private Message to cliffwEdit/Delete MessageReply w/QuoteDirect Link to This Post
That will work Mike ... I think. Can it handle jack stands ( I suppose one could use plywood softeners ) ? Specs ? Supply website ?
Boondawg
Total ratings: 342
Report this Post05-04-2014 09:15 PM Click Here to See the Profile for BoondawgSend a Private Message to BoondawgEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by cliffw:
Can it handle jack stands ? Specs ? Supply website ?
Yes, I also would like to know more.
Looks pretty handy!
TXGOOD
Total ratings: 87
Report this Post05-04-2014 09:28 PM Click Here to See the Profile for TXGOODClick Here to visit TXGOOD's HomePageSend a Private Message to TXGOODEdit/Delete MessageReply w/QuoteDirect Link to This Post
It`s called Garage Deck which is the cheaper version of Race Deck.
You do have to use plywood or metal plate under jack stands just to keep it from denting.
People claim though that if it does get a dent it will pop back out within a day or so.
I mainly got it to put my project on stands or a lift and then be able to crawl under it without scrambling around on the asphalt.
It`s also got channels under it so if water leaks into my carport it will run under it.
http://www.bigfloors.com/shop/garagedeck-2/
Boondawg
Total ratings: 342
Report this Post05-04-2014 09:42 PM Click Here to See the Profile for BoondawgSend a Private Message to BoondawgEdit/Delete MessageReply w/QuoteDirect Link to This Post
Cool, thanx!
