  Totally O/T
  Never had that happen before....NOTE of caution
Never had that happen before....NOTE of caution by MidEngineManiac
Started on: 05-16-2014 07:25 PM
Replies: 7 (684 views)
Last post by: fireboss on 05-17-2014 08:10 PM
Total ratings: 297
Report this Post05-16-2014 07:25 PM Click Here to See the Profile for MidEngineManiacSend a Private Message to MidEngineManiacEdit/Delete MessageReply w/QuoteDirect Link to This Post
Well, I wont be doing that again....
I had (operative word) an old East-Block made air riffle. Best guess of manufacture ia late 50's/early 60's. The markings were so rusted it was impossible to read. I thought it would be a good idea to re-build so gave it a proper oil soak, clean-up, new o-rings, roll pins, polished the spring, made new leather seals (yes, its that old). I got it at a yard sale last fall and played with it over the winter.
(break-barrel design)....so I cocked and loaded. Put it on the rest and pulled the trigger.......and all hell broke loose. As soon as the spring let loose, so did the tube. split down the bottom, broke the wood, threw off the spring lever, broke a bolt and just generally self-destructed. Split from the end of the cocking lever slot to the trigger opening.
If I had been shooting in a standing stance instead of a rest, I would have lost a hand, it came apart that hard. There is a LOT of energy in those springs..
Best I can guess is the tube seam was originally welded badly (soviet-era manufacturing) THEN, they put the cut-outs along the weld, and in the 1st place used rolled steel instead of tube....and 50+ years of age and metal fatigue and gawd-knows-what before I got it.
If ya come across one of these things at a yard-sale, hang it on a wall......and if ya open an airgun and find leather inside....hang it on a wall.
YUP, I had a great start to my long weekend.
Aw, well....It WAS the oldest one I have, but not the only one. I just hate seeing an antique destruct.
[This message has been edited by MidEngineManiac (edited 05-16-2014).]
tesmith66
Total ratings: 135
Report this Post05-16-2014 08:28 PM Click Here to See the Profile for tesmith66Send a Private Message to tesmith66Edit/Delete MessageReply w/QuoteDirect Link to This Post
Huh...
I have a 1920's Crossman model 101 .22 cal air rifle with leather seals. Works fantastic. My dad gave it to me when I was 10 (37 years ago). Last time I used it it had been sitting for over 20 years. I oiled it up and shot a snake.
Tony Kania
Total ratings: 305
Report this Post05-16-2014 08:29 PM Click Here to See the Profile for Tony KaniaSend a Private Message to Tony KaniaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Pics? Glad you weren't hurt.
Total ratings: 297
Report this Post05-16-2014 08:36 PM Click Here to See the Profile for MidEngineManiacSend a Private Message to MidEngineManiacEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by tesmith66:
Huh...
I have a 1920's Crossman model 101 .22 cal air rifle shot a snake.
Crossman.....American..
We are talking about a Soviet gun that blew apart
V8 Vega
Report this Post05-17-2014 12:28 PM Click Here to See the Profile for V8 VegaSend a Private Message to V8 VegaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Its known never to open it and then pull the trigger before closing it up again, I think doing that breaks the stock. Also on all old air guns without anti bear trap mechanism always hold the barrel so it cant close on your fingers while your loading the pellet. It can cut of a finger.
[This message has been edited by V8 Vega (edited 05-17-2014).]
84fiero123
Total ratings: 325
Report this Post05-17-2014 02:35 PM Click Here to See the Profile for 84fiero123Send a Private Message to 84fiero123Edit/Delete MessageReply w/QuoteDirect Link to This Post
OK I am not going to say you are an idiot, ah screw it, yes I am, You are an idiot.
You said you put it in an oil bath and I know you so I am going to ask you a couple of stupid questions, just because I know you
You did run a cleaning rod down the barrel to make sure it was clean and free of any obstructions, right?
You did run a clean patch down threw the barrel to make sure, right?
And yet one last important question,
You did try to push a pellet or BB of the correct caliber threw the barrel with the ram rod, Right?
OK enough making fun of you, it could have happened to me as well, a 60+ year old gun should always be fired from a vise the first time, just to make sure it won't do just what yours did, glad you didn't get hurt.
Steve
Cooter
Total ratings: 138
Report this Post05-17-2014 05:44 PM Click Here to See the Profile for CooterSend a Private Message to CooterEdit/Delete MessageReply w/QuoteDirect Link to This Post
Old air rifles are cool...
fireboss
Total ratings: 58
Report this Post05-17-2014 08:10 PM Click Here to See the Profile for firebossSend a Private Message to firebossEdit/Delete MessageReply w/QuoteDirect Link to This Post
Now that's cool..
