  Totally O/T
  Homebrew TCU
Homebrew TCU by WellThatsSuprising
Started on: 06-24-2014 09:13 AM
Replies: 5 (264 views)
Last post by: WellThatsSuprising on 06-24-2014 05:10 PM
WellThatsSuprising
Report this Post06-24-2014 09:13 AM Click Here to See the Profile for WellThatsSuprisingSend a Private Message to WellThatsSuprisingEdit/Delete MessageReply w/QuoteDirect Link to This Post
First off, if this belongs in the "Other Cars" section tell me and I will gladly continue it over there. Now I lay out my problem. As of now I have a FA4A-EL transmission without a TCU and it's no longer an option to re-use the stock unit as the stock ECU is gone also. I know I can manually control the solenoids for shifting through the gears but that still leaves line pressure unregulated and on a chassis so light the harsh shifts will be extremely troublesome. I can bring a calculated load off of the MegaSquirt just as the stock ECU would but I have no idea how to translate that into something that I can output to the regulator on the transmission. Any ideas?
Little bit more info, the drivetrain is out of a 2002 Kia Spectra. Some of you are probably thinking that there's no way a cruddy Kia would be light enough for hard shifts to be a problem. Well, this is only about 1/3 of a Kia. Build thread is on another forum if you want more info. It has come a long way since this picture but it's still far from done.
zetabird
Report this Post06-24-2014 09:19 AM Click Here to See the Profile for zetabirdSend a Private Message to zetabirdEdit/Delete MessageReply w/QuoteDirect Link to This Post
cant help you with the tcu but one word, wheelibars... and counter weight... looks fun tho
heybjorn
Total ratings: 97
Report this Post06-24-2014 11:14 AM Click Here to See the Profile for heybjornSend a Private Message to heybjornEdit/Delete MessageReply w/QuoteDirect Link to This Post
Interesting build.
WellThatsSuprising
Report this Post06-24-2014 04:00 PM Click Here to See the Profile for WellThatsSuprisingSend a Private Message to WellThatsSuprisingEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by heybjorn:
Interesting build.
Thanks, though I think I'll be fine without the bar. Most of the driving is going to be on gravel and I doubt the puny 1.8 could pull enough to lift the front, even on pavement.
zetabird
Report this Post06-24-2014 04:42 PM Click Here to See the Profile for zetabirdSend a Private Message to zetabirdEdit/Delete MessageReply w/QuoteDirect Link to This Post
with almost no weight over the front id be interested to see how it behaves under acceleration.
WellThatsSuprising
Report this Post06-24-2014 05:10 PM Click Here to See the Profile for WellThatsSuprisingSend a Private Message to WellThatsSuprisingEdit/Delete MessageReply w/QuoteDirect Link to This Post
As am I. The thing is either getting the front subframe out of my buddies 3000GT or I'm going to cut up the front of an ATV, but front suspension is a must-have.
