  Totally O/T
  Medical Question: Can You Hack A CPAP (Continuous Positive Airway Pressure) Machine? (Page 1)
Medical Question: Can You Hack A CPAP (Continuous Positive Airway Pressure) Machine? by Boondawg
Started on: 06-29-2014 12:04 AM
Replies: 52 (3336 views)
Last post by: Amethyst on 07-03-2014 12:24 AM
Boondawg
Total ratings: 342
Report this Post06-29-2014 12:04 AM Click Here to See the Profile for BoondawgSend a Private Message to BoondawgEdit/Delete MessageReply w/QuoteDirect Link to This Post
What if you scored a $1,000 CPAP machine?
Can you hack into it (with 40 years experience of knowing your sleeps patterns) to try to cure a 40-year sleep problem (snoring, holding my breath, etc.)?
Can it be dangerous?
Total ratings: 441
Report this Post06-29-2014 12:34 AM Click Here to See the Profile for maryjaneSend a Private Message to maryjaneEdit/Delete MessageReply w/QuoteDirect Link to This Post
yes. Brother in law has screwed with his several times and caused some serious problems. They are not one-size-fits-all things either.
Boondawg
Total ratings: 342
Report this Post06-29-2014 12:46 AM Click Here to See the Profile for BoondawgSend a Private Message to BoondawgEdit/Delete MessageReply w/QuoteDirect Link to This Post
And that's what I don't get....it's just airflow...how can more air be bad?
What are you going to do, breathe yourself to death?...
pokeyfiero
Total ratings: 309
Report this Post06-29-2014 12:54 AM Click Here to See the Profile for pokeyfieroClick Here to visit pokeyfiero's HomePageSend a Private Message to pokeyfieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
I had a cpap/respiratory system that is more complicated.
It monitors my heart and Oxygen level and adds oxygen while controlling my breathing..
I had a power surge and wiped mine out but I typed in the model number and got the instructions for it to do a self diagnostic and self sensing reprogram.
It took a couple nights for it to get it done but it worked. They have sense given me a knew one that makes oxygen from the air.
Id try looking for the instructions online.
IMSA GT
Total ratings: 253
Report this Post06-29-2014 01:13 AM Click Here to See the Profile for IMSA GTSend a Private Message to IMSA GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
A CPAP machine basically is designed to keep your airway open by forcing you to breathe through your nose. Once the unit is turned on, it is almost impossible to breathe through your mouth as well as talk. They are custom fit and the airflow is custom programmed based on the sleep studies that they do on you and the type of sleep apnea that you have.
Marvin McInnis
Total ratings: 227
Report this Post06-29-2014 01:21 AM Click Here to See the Profile for Marvin McInnisClick Here to visit Marvin McInnis's HomePageSend a Private Message to Marvin McInnisEdit/Delete MessageReply w/QuoteDirect Link to This Post
Can you hack a CPAP?
Let me put it this way: Don't overclock your CPAP.
[This message has been edited by Marvin McInnis (edited 06-29-2014).]
Boondawg
Total ratings: 342
Report this Post06-29-2014 01:43 AM Click Here to See the Profile for BoondawgSend a Private Message to BoondawgEdit/Delete MessageReply w/QuoteDirect Link to This Post
Remember the scene in "Brainstorm" where the dude spliced a s3x scene into a continuous loop?...
Report this Post06-29-2014 01:54 AM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Video... or it didn't happen.
Boondawg
Total ratings: 342
Report this Post06-29-2014 01:58 AM Click Here to See the Profile for BoondawgSend a Private Message to BoondawgEdit/Delete MessageReply w/QuoteDirect Link to This Post
The best I could do-1:35
[This message has been edited by Boondawg (edited 06-29-2014).]
Total ratings: 441
Report this Post06-29-2014 02:31 AM Click Here to See the Profile for maryjaneSend a Private Message to maryjaneEdit/Delete MessageReply w/QuoteDirect Link to This Post
Sister said it messed up his blood pH and carbon dioxide levels to the point he couldn't function enough to tell her what was wrong.
Total ratings: 154
Report this Post06-29-2014 08:33 AM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
Usually the machines start out at a low volume and ramp up to a pre-set flow. In part, that's so you can go to sleep before it reaches full pressure. If the pressure is too high, the seal against your face blows out and you start to get what some call Face Farts.
My wife has been using a CPAP and more recently a BiPAP machine since the mid 909's. The CPAP machine had to be programmed by the sleep center. Periodically she would go in for a sleep study and they would make adjustments based on the result. It can be adjusted by an individual, though. Our daughter, a paramedic, has adjusted that one for my wife. The information is online. She adjusted it down when we loaned it to tbone42, a few years ago, but he had difficulty with claustrophobia and couldn't use it. Attaching a line from a concentrator can help to reduce or eliminate that. Practice-wearing it during the day can also get one used to the machine.
As for the BiPAP machine, that one was also set by the sleep center after a study. It, however has a small SIM card plus a radio receiver/transmitter that plugs into the back. The sleep center downloads monthly information, then uploads an adjustment if needed. It does have buttons and a screen, so it can also probably be manually adjusted.
Boon, if you have a ResMed machine, maybe my daughter or son-in-law can help you.
Total ratings: 200
Report this Post06-29-2014 10:35 AM Click Here to See the Profile for 82-T/A [At Work]Send a Private Message to 82-T/A [At Work]Edit/Delete MessageReply w/QuoteDirect Link to This Post
This is probably a stupid question, but I was always under the impression that people who used a CPAP had to do so because they were generally overweight or badly out of shape? Would not simply exercising be a better option than spending money or fiddling with a CPAP machine?
Or am I completely wrong?
Wichita
Report this Post06-29-2014 11:05 AM Click Here to See the Profile for WichitaSend a Private Message to WichitaEdit/Delete MessageReply w/QuoteDirect Link to This Post
I believe that is generally the case, but there might be a few people that are at healthy weight and still need it.
All the people I know are generally older, say 40+, overweight and out of shape. I personally known two people who stopped using it by losing weight and exercising. One of the dude's went through gastric bypass surgery in order to loose weight, but lost a lot a weight and started walking every day and was able to stop using the CPAP.
Both guys were never smokers, so I'm not so sure how much smoking habits play in people needing CPAP. Also, fierofool's wife might not be Gilbert Grape mom big, but generally overweight people is all I know.
I sometimes wonder if CPAP users always dream of scuba diving or being a fighter pilot?
[This message has been edited by Wichita (edited 06-29-2014).]
Total ratings: 154
Report this Post06-29-2014 11:45 AM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
In my wife's case, she has Pulmonary Arterial Hypertension. High blood pressure in the lungs. It's a genetic disorder where the blood vessels of the lungs are constricted so that they don't exchange Co2 and Oxygen as efficiently as normal lungs.
Our bodies has two separate blood pressures. Systemic which is the one we see from the blood pressure cuff, and pulmonary. Pulmonary pressures can only be read by catheterizing the heart and lungs. Yes, people using C or Bi Pap machines are often or maybe usually overweight and are inactive, but that in itself may not be the reason for needing the machine. in the opposite, because people cannot breathe, they become inactive and overweight.
My wife was around 135-140 until she eventually got to the point that she required some degree of oxygen. She could perform normal activities, but couldn't run, swim, or walk very far. That, and combined with the steroids the doctors began to prescribe, she began putting on weight. A lot of weight. A new regimen of medication that slowly reduced the steroids has caused her to loose more than 150 lbs in the last 6 years.
It is a catch 22. Weight problems adds to breathing problems. Breathing problems adds to weight problems.
Boondawg
Total ratings: 342
Report this Post06-29-2014 11:56 AM Click Here to See the Profile for BoondawgSend a Private Message to BoondawgEdit/Delete MessageReply w/QuoteDirect Link to This Post
That's the exact machine I have:
I'm still researching.
I don't want to die in my sleep or nothing (but for the life of me I can't figure out why).
gtjoe
Report this Post06-29-2014 12:07 PM Click Here to See the Profile for gtjoeSend a Private Message to gtjoeEdit/Delete MessageReply w/QuoteDirect Link to This Post
If you think you may have obstructive sleep apnea (which is what this machine is used to treat) You really should see a doctor that specializes in sleep disorders. The only efficient way to find the correct settings for a CPAP is with a sleep study.
Boondawg
Total ratings: 342
Report this Post06-29-2014 01:11 PM Click Here to See the Profile for BoondawgSend a Private Message to BoondawgEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'm thinking a video camera and a lapel mic as my sleep study.
Although, I would also like to record my heart rate in real time, too.
And brainwaves, that would be the icing on the cake.
But what I got is what I got...
MadMark
Report this Post06-29-2014 01:17 PM Click Here to See the Profile for MadMarkSend a Private Message to MadMarkEdit/Delete MessageReply w/QuoteDirect Link to This Post
This is quite true. When the do a sleep study they monitor just about everything on you, from O2 level, to leg movements. The do what is called a titration. This is where they slowly adjust the pressure of the CPAP to see how you do. When they get to the point where your O2 levels are proper then that is basically where they set the pressure.
I have used one for over 10 years and my pressure has remained constant. The masks though have changed significantly so that what used to be restrictive, claustrophobic and down right uncomfortable is now pretty good. I have a little thing that goes under my nose with soft pillows on it and a strap around my head. It is comfortable, open and doesn't leak like crazy.
I would recommend you see a sleep specialist if you are concerned with your sleep patterns especially if you are like me that snore loudly and stop breathing regularly when you sleep.
I had a friend of mine who had bad sleep apnea who was kind of thin. He had surgeries on his upper nose cavities, the back of his throat and the lower part of his throat. That seemed to reduce the snoring a lot, but he still ended up dying of a heart attack due to his sleep apnea problems at 40. So it is something that is very important to take care of if you have that type of problem.
fierobrian
Total ratings: 80
Report this Post06-29-2014 01:21 PM Click Here to See the Profile for fierobrianSend a Private Message to fierobrianEdit/Delete MessageReply w/QuoteDirect Link to This Post
my stepdad is 6 foot 7 and maybe 190 pounds and has too wear one for a few years now
[This message has been edited by fierobrian (edited 06-29-2014).]
Boondawg
Total ratings: 342
Report this Post06-29-2014 01:36 PM Click Here to See the Profile for BoondawgSend a Private Message to BoondawgEdit/Delete MessageReply w/QuoteDirect Link to This Post
Has it improved his life?
Boondawg
Total ratings: 342
Report this Post06-29-2014 01:48 PM Click Here to See the Profile for BoondawgSend a Private Message to BoondawgEdit/Delete MessageReply w/QuoteDirect Link to This Post
Boondawg
Member since Jun 2003
I do, and have not slept well in 40 years.
It is only recently that I started putting all the pieces of the puzzle together.
Ideally, yes, a full-blown sleep study would be perfect.
But financially, this is a do-it-yourself project.
On the other hand, if this is indeed dangerous, the project does lose a considerable amount of interest for me.
I mean, I've survived 40 years of crappy sleep, what's another 40?
Formula88
Total ratings: 554
Report this Post06-29-2014 01:53 PM Click Here to See the Profile for Formula88Send a Private Message to Formula88Edit/Delete MessageReply w/QuoteDirect Link to This Post
So go for it.
Boondawg
Total ratings: 342
Report this Post06-29-2014 01:57 PM Click Here to See the Profile for BoondawgSend a Private Message to BoondawgEdit/Delete MessageReply w/QuoteDirect Link to This Post
So go for it.
Like I said above...
Formula88
Total ratings: 554
Report this Post06-29-2014 02:00 PM Click Here to See the Profile for Formula88Send a Private Message to Formula88Edit/Delete MessageReply w/QuoteDirect Link to This Post
There are many causes of obstructive sleep apnea, not just body weight. That said, sleep apnea can cause serious damage due to spikes in blood pressure, strokes, heart attacks and death. Treating that with a CPAP could help you live long enough to lose weight.
If your doctor told you to lose 30lbs, could you do it? By tomorrow?
User00013170
Total ratings: 224
User on Probation
Report this Post06-29-2014 02:20 PM Click Here to See the Profile for User00013170Send a Private Message to User00013170Edit/Delete MessageReply w/QuoteDirect Link to This Post
Only if you dont care if you die.
User00013170
Total ratings: 224
User on Probation
Report this Post06-29-2014 02:22 PM Click Here to See the Profile for User00013170Send a Private Message to User00013170Edit/Delete MessageReply w/QuoteDirect Link to This Post
User00013170
Member since May 2006
Overnight? Could anyone, without surgery?
Formula88
Total ratings: 554
Report this Post06-29-2014 02:42 PM Click Here to See the Profile for Formula88Send a Private Message to Formula88Edit/Delete MessageReply w/QuoteDirect Link to This Post
That's the point.
Boondawg
Total ratings: 342
Report this Post06-29-2014 02:44 PM Click Here to See the Profile for BoondawgSend a Private Message to BoondawgEdit/Delete MessageReply w/QuoteDirect Link to This Post
Heh, so I can eat a lifetime total of 130 hits of acid and survive it, but I can't supply extra oxygen to myself while I sleep.
What a crazy world...
fierobrian
Total ratings: 80
Report this Post06-29-2014 02:48 PM Click Here to See the Profile for fierobrianSend a Private Message to fierobrianEdit/Delete MessageReply w/QuoteDirect Link to This Post
he said he is able to sleep the whole night and doesnt grind his teeth anymore at night like he did before
pokeyfiero
Total ratings: 309
Report this Post06-29-2014 02:49 PM Click Here to See the Profile for pokeyfieroClick Here to visit pokeyfiero's HomePageSend a Private Message to pokeyfieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
I don't think that machine can record and automatically adjust to you. Not if it fits in a bag. What I was talking about is the size of an end table.
It has a hand attachment and a little finger light to monitor your vitals and O2.
You need to get evaluated and get one of these.
Total ratings: 154
Report this Post06-29-2014 02:53 PM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
How did you get a ResMed 5 without a prescription? The sleep study determines among other things, just how much oxygen you're getting while sleeping. CPAP is one-way Continuous Air Pressure. Even when you exhale, the machine is still putting in the same air flow to the mask, but is exhausted through the ports.
BiPAP machines actually decrease the pump pressure when you exhale. BiPAP machines are also much quieter and have less tendency to break the face seal. Once the seal on either is broken, the machine increases flow to try to attain the programmed positive pressure required for the patient. The result is Face Farts.
If you've had the sleep study and have privately gotten the ResMed to save some money, then get it programmed for your personal needs, or as I offered, maybe my daughter or son-in-law can help you. My wife says the programming instructions are available on the web, but you need to know what values to enter.
It is odd that we can't purchase medical oxygen for our own use, nor can we purchase oxygen concentrators or anything that will provide medical oxygen unless we have a prescription from a pulmonologist. That's one of the reasons that Oxygen Bars were put out of business. They weren't approved by the FDA.
[This message has been edited by fierofool (edited 06-29-2014).]
User00013170
Total ratings: 224
User on Probation
Report this Post06-29-2014 02:56 PM Click Here to See the Profile for User00013170Send a Private Message to User00013170Edit/Delete MessageReply w/QuoteDirect Link to This Post
http://en.wikipedia.org/wiki/Oxygen_toxicity
Boondawg
Total ratings: 342
Report this Post06-29-2014 03:04 PM Click Here to See the Profile for BoondawgSend a Private Message to BoondawgEdit/Delete MessageReply w/QuoteDirect Link to This Post
Networking.
When avoiding the costly medical profession for 30 years, you learn other avenues of acquisition for the medical supplies you need, bypassing the imposed requirement of needing someone else's permission.
It's a lot like working on your own car instead of taking it to a shop.......you just need the smarts and the tools.
Wichita
Report this Post06-29-2014 03:06 PM Click Here to See the Profile for WichitaSend a Private Message to WichitaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Networking.
When avoiding the costly medical profession for 30 years, you learn other avenues of acquisition for the medical supplies you need.
I can dig that!
Total ratings: 154
Report this Post06-29-2014 03:12 PM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
Understood and supported. That's why we sent tbone42 our CPAP. He'd had the study but couldn't afford the machine. That's how we got our first concentrator. Insurance copay was $100 a month. We found that if we ha a prescription we could purchase one for less than $800 (price in the mid 90's), so we bought one from a private individual, along with a bunch of tanks and regulators and a nebulizer, for $250.
gtjoe
Report this Post06-29-2014 03:28 PM Click Here to See the Profile for gtjoeSend a Private Message to gtjoeEdit/Delete MessageReply w/QuoteDirect Link to This Post
If you want to be treated for sleep apnea without a ful sleep study the best way would be with a APAP instead of a CPAP
User00013170
Total ratings: 224
User on Probation
Report this Post06-29-2014 06:33 PM Click Here to See the Profile for User00013170Send a Private Message to User00013170Edit/Delete MessageReply w/QuoteDirect Link to This Post
Networking.
So you have spent some time down at the east docks..
Boondawg
Total ratings: 342
Report this Post06-29-2014 06:39 PM Click Here to See the Profile for BoondawgSend a Private Message to BoondawgEdit/Delete MessageReply w/QuoteDirect Link to This Post
I got the ResMed S7 Lightweight with the heated humidifier:
Boondawg
Total ratings: 342
Report this Post06-29-2014 06:42 PM Click Here to See the Profile for BoondawgSend a Private Message to BoondawgEdit/Delete MessageReply w/QuoteDirect Link to This Post
Boondawg
Just Saturday nights.
But you know me as Maxine DuBois...
Total ratings: 403
Report this Post06-29-2014 06:51 PM Click Here to See the Profile for Jake_DragonSend a Private Message to Jake_DragonEdit/Delete MessageReply w/QuoteDirect Link to This Post
My wife uses one, she noticed a difference the first night.
But sometimes it ramps up too much and "fart" so she wakes up and turns the machine off and back on and it starts the cycle over.
I do think they have the final air flow set too high but it works.
