  Totally O/T
  Lasers Revolutionize Your Restoration Projects - 1,000 Watt Hand-Held Laser Stripper!
Lasers Revolutionize Your Restoration Projects - 1,000 Watt Hand-Held Laser Stripper! by Boondawg
Started on: 06-29-2014 07:02 PM
Replies: 10 (792 views)
Last post by: heybjorn on 06-30-2014 06:23 AM
Boondawg
Total ratings: 342
Report this Post06-29-2014 07:02 PM Click Here to See the Profile for BoondawgSend a Private Message to BoondawgEdit/Delete MessageReply w/QuoteDirect Link to This Post
No chemicals, no water, no dust, no clean-up!
Fats
Total ratings: 75
Report this Post06-29-2014 07:11 PM Click Here to See the Profile for FatsSend a Private Message to FatsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Awesome. But there is something left from it. It's not "zero emissions" as the video claims. If the laser is burning paint, or rubber off, it's not deleting it from existence, it's turning it into ash, smoke, and some other stuff.
But I still want one, really bad.
Brad
avengador1
Total ratings: 571
Report this Post06-29-2014 07:41 PM Click Here to See the Profile for avengador1Send a Private Message to avengador1Edit/Delete MessageReply w/QuoteDirect Link to This Post
What does it run on? Pixie dust?
Boondawg
Total ratings: 342
Report this Post06-29-2014 07:46 PM Click Here to See the Profile for BoondawgSend a Private Message to BoondawgEdit/Delete MessageReply w/QuoteDirect Link to This Post
I loved the rust removal!
User00013170
Total ratings: 224
User on Probation
Report this Post06-29-2014 07:46 PM Click Here to See the Profile for User00013170Send a Private Message to User00013170Edit/Delete MessageReply w/QuoteDirect Link to This Post
Good luck getting a license to have it. The limits are well below that for 'citizens'
User00013170
Total ratings: 224
User on Probation
Report this Post06-29-2014 07:48 PM Click Here to See the Profile for User00013170Send a Private Message to User00013170Edit/Delete MessageReply w/QuoteDirect Link to This Post
User00013170
Member since May 2006
Brad
Its actually a zero point energy conversion device. It sends the atoms from the bad stuff to another universe.
Total ratings: 463
Report this Post06-29-2014 08:05 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Get the 1000w version!
Formula88
Total ratings: 554
Report this Post06-29-2014 08:05 PM Click Here to See the Profile for Formula88Send a Private Message to Formula88Edit/Delete MessageReply w/QuoteDirect Link to This Post
Brad
Yeah, the video says it vaporizes the coating and vacuums the debris up, so they're collecting the emissions.
I would imagine all that vaporized exhaust would be incredibly toxic. It is really cool, but can you imagine trying to strip an entire car body and chassis with that thing, considering how small the area of effect is and how slow it takes to clear off a few square inches. Might be great for small parts.
MadMark
Report this Post06-29-2014 10:20 PM Click Here to See the Profile for MadMarkSend a Private Message to MadMarkEdit/Delete MessageReply w/QuoteDirect Link to This Post
Wow, hand held! I have worked on and repair lasers in the 1000 watt range and they were huge. But, of course they were 1st or 2nd generation lasers. We used them at GM for several things. First use was to heat a strip in the body of the recirculating ball steering units. They would put three hot stripes in the body which would harden the metal so that it didn't wear out as fast. We also used one in another plant to burn holes in the boots for the CV joints. The holes were so small water couldn't go through, but the air could.
When we were repairing them sometimes things got crazy and someone would focus the laser on the metal stand and it would burn a hole right through it. Of course this was a focused beam relatively small and not oscillating. Obviously this unit is moving the beam rapidly back and forth to prevent melting what is beneath the rust, paint or whatever.
These older lasers were about 30 to 40 feet long and 7 feet high with a marble plate with the laser tubes mounted on them. Obviously these newer ones are more solid state and much smaller too.
Report this Post06-30-2014 01:51 AM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Nice tool but Zero Emission? Who says?
Depend on what material to remove, can be Toxic to burn many things. Lead Zinc and other coatings/paints/primers are bad. Can turn worse when burn or when fumes cool and react local air.
Vacuum and related parts that suck fumes/ash likely needs to meet OSHA EPA etc rules for vacuuming HAZMAT.
Wrong vacuum can contaminate an entire building.
Even w/o HAZMAT rating, a HEPA seal vacuum is a very good idea. Nano Size crap is not a good thing to breath etc.
Lead is bad? Some Lead Compounds are Worse. Raw Lead is easy to control. Vapor Lead and related Compound that you breath that can poison you fast. Others are skin absorb poisons too.
Zinc is good to coat metal. Zinc in air will quickly put people is the Hospital.
Latex Paint is mostly low or no toxic as paint, wet or dry. Pigments when burn is another story. Example: Titanium dioxide makes good white paint but you shouldn't to breath it. http://en.wikipedia.org/wik...de#Health_and_safety
If laser burn converts the pigment then to what? Ti Metal? Vaporize anything results in nano sized particles can cause health issues too, even if normal whatever are safe.
heybjorn
Total ratings: 97
Report this Post06-30-2014 06:23 AM Click Here to See the Profile for heybjornSend a Private Message to heybjornEdit/Delete MessageReply w/QuoteDirect Link to This Post
I can't believe no one had said this:
Laser Stripper!
I expected something else.
