  Totally O/T
  I'm more confused than ever about platinum spark plug gapping
I'm more confused than ever about platinum spark plug gapping by Kitskaboodle
Started on: 07-01-2014 11:18 PM
Replies: 16 (1138 views)
Last post by: Pocket on 07-05-2014 09:35 AM
Kitskaboodle
Report this Post07-01-2014 11:18 PM Click Here to See the Profile for KitskaboodleSend a Private Message to KitskaboodleEdit/Delete MessageReply w/QuoteDirect Link to This Post
My stepdaughter is now driving a 96 Saturn SL2 with the 1.9L DOHC engine. I bought some Bosch double platinum plugs for it. (#8100) But, I am kind of confused about whether these plugs should be gapped for my application? I couldn't find a technical assistance number for Bosch plugs. I ask this because the guy at Autozone showed me his screen and it said these plugs should not be gapped. On another note, some spark plug boxes say that they are pre-gapped but I don't trust that. By the way, I have never been a fan of platinum plugs but for some reason the only plugs listed for this car & engine are platinum. I guess that means I'm forced to use them.
So, what determines whether platinum plugs need gaping or not?
Formula88
Total ratings: 554
Report this Post07-01-2014 11:30 PM Click Here to See the Profile for Formula88Send a Private Message to Formula88Edit/Delete MessageReply w/QuoteDirect Link to This Post
Is this what they look like?
Try to gap plugs with that tiny center electrode and you'll probably break the electrode or crack the insulator and ruin the plug.
[This message has been edited by Formula88 (edited 07-01-2014).]
Doug85GT
Total ratings: 123
Report this Post07-01-2014 11:40 PM Click Here to See the Profile for Doug85GTSend a Private Message to Doug85GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
You can gap it with the correct tools. Many spark plug gap tools have a special arm that is used to bend the ground electrode. You should never pry against the center electrode.
You can buy a relatively inexpensive tool to gap the plug. It looks like this when you gap it:
There are more expensive tools to do it:
Even though they are platinum plugs, they should still be gapped for your vehicle. Many plugs come with the correct gap, but it is always good to double check.
[This message has been edited by Doug85GT (edited 07-01-2014).]
skuzzbomer
Total ratings: 92
Report this Post07-01-2014 11:53 PM Click Here to See the Profile for skuzzbomerSend a Private Message to skuzzbomerEdit/Delete MessageReply w/QuoteDirect Link to This Post
My daily driver takes NGK laser iridium plugs. The ground on those will break off if you try to gap them and at $25 a piece, I'm not budgeting to experiment.
I check the gap at the parts counter with a wire gap tool when I get them in to make sure the measure out to spec. So long as they're close, I roll.
Doug85GT
Total ratings: 123
Report this Post07-02-2014 12:08 AM Click Here to See the Profile for Doug85GTSend a Private Message to Doug85GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
I used NGK laser iridium plugs in my Turbo Dodge Stealth for years. I gapped them myself all the time, which is necessary since I am running higher than stock boost. They came gapped at about .035 and I needed them gapped at .028. It was easy to gap them. They are not as brittle as you think. You just have to take your time, and pay attention to what you are doing.
Also, I would find a different place to buy your plugs. You could probably find those same plugs for half or less. I never paid over $9 each for my NGK li plugs.
zetabird
Report this Post07-02-2014 07:57 AM Click Here to See the Profile for zetabirdSend a Private Message to zetabirdEdit/Delete MessageReply w/QuoteDirect Link to This Post
autozones computers say not to gap them because most people break them trying to do it, they usualy dont know how to do it the right way.its not a big deal if your carefull, i always checked them when i sold them there i know how those boxes are treated.....
heybjorn
Total ratings: 97
Report this Post07-02-2014 08:32 AM Click Here to See the Profile for heybjornSend a Private Message to heybjornEdit/Delete MessageReply w/QuoteDirect Link to This Post
Wife has a small jewelry hammer that works great on plugs.
V8 Vega
Report this Post07-02-2014 11:13 AM Click Here to See the Profile for V8 VegaSend a Private Message to V8 VegaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Why make yourself a bunch of extra work and possible expense? If the instructions say don't gap them then don't.
84fiero123
Total ratings: 325
Report this Post07-02-2014 12:14 PM Click Here to See the Profile for 84fiero123Send a Private Message to 84fiero123Edit/Delete MessageReply w/QuoteDirect Link to This Post
Never heard of trying to do anything with the center electrode to gap a plug, that is not the right way to gap a plug.
This is the proper way to gap a spark plug !
Like he said, all it takes is for just one person to drop the box the plugs come in and the gap is wrong, and we all know how well people who unload trucks handle parts.
Steve
Formula88
Total ratings: 554
Report this Post07-02-2014 12:29 PM Click Here to See the Profile for Formula88Send a Private Message to Formula88Edit/Delete MessageReply w/QuoteDirect Link to This Post
So you're saying you should use the gapping tool the way the engineers designed it to be used?
When checking the gap, your feeler gage has to contact the electrode. Yes, if you're careful and know what you're doing you can do it, but as has been posted they are more prone to breakage and most people aren't careful enough to avoid damaging the plug. I carefully check the gap, but I've never had to adjuste one that came preset. Old style plugs like on the Fiero I routinely have to re-gap before installation.
[This message has been edited by Formula88 (edited 07-02-2014).]
84fiero123
Total ratings: 325
Report this Post07-02-2014 12:37 PM Click Here to See the Profile for 84fiero123Send a Private Message to 84fiero123Edit/Delete MessageReply w/QuoteDirect Link to This Post
Gee it wasn't invented by an enginer just some poor shmuck like me and is the recommended tool for adjusting those type of plugs.
http://www.google.com/url?s...&bvm=bv.70138588,d.c Wc
Its a PDF don't know any other way to link to it.
Steve
Report this Post07-02-2014 12:49 PM Click Here to See the Profile for 2.5Send a Private Message to 2.5Edit/Delete MessageReply w/QuoteDirect Link to This Post
Most plugs I've bought had a cardboard tube around the threaded end to keep the gap even if dropped in the box.
But I still check them.
[This message has been edited by 2.5 (edited 07-02-2014).]
Formula88
Total ratings: 554
Report this Post07-02-2014 12:58 PM Click Here to See the Profile for Formula88Send a Private Message to Formula88Edit/Delete MessageReply w/QuoteDirect Link to This Post
Same here. Older plugs didn't usually, but the ones I've bought in recent years have.
skuzzbomer
Total ratings: 92
Report this Post07-03-2014 01:19 AM Click Here to See the Profile for skuzzbomerSend a Private Message to skuzzbomerEdit/Delete MessageReply w/QuoteDirect Link to This Post
Same technology =/= same plugs.
2) RE7CL
2) RE9BT
If you find me someplace that will sell them for $9 each, I will clear their whole stock
Patrick's Dad
Total ratings: 108
Report this Post07-03-2014 12:18 PM Click Here to See the Profile for Patrick's DadClick Here to visit Patrick's Dad's HomePageSend a Private Message to Patrick's DadEdit/Delete MessageReply w/QuoteDirect Link to This Post
Just put Bosch Platinum plugs in my wife's T&C. Paid $5 each. Didn't gap, per instructions. Nothing's exploded yet. Will keep you updated.
masospaghetti
Report this Post07-03-2014 02:13 PM Click Here to See the Profile for masospaghettiSend a Private Message to masospaghettiEdit/Delete MessageReply w/QuoteDirect Link to This Post
Just FYI - If my memory serves correctly - your Saturn, like many other GM and Ford vehicles of the era, used a waste-spark ignition system. A waste spark system fires each plug twice per combustion cycle, instead of just once like a normal ignition system. This means the electrode essentially has half the life of a regular plug.
More importantly, a waste spark system reverses the current on each firing event. On a single platinum plug, the platinum is used on the electrode that becomes sacrificial (I forget if its the anode or cathode). If you use a single platinum plug, the side without the platinum will wear prematurely, as it wasn't designed for a waste spark system.
That's why the double platinum is a good idea to use.
[This message has been edited by masospaghetti (edited 07-03-2014).]
Pocket
Report this Post07-05-2014 09:35 AM Click Here to See the Profile for PocketSend a Private Message to PocketEdit/Delete MessageReply w/QuoteDirect Link to This Post
What are you smoking?
Waste spark means it fires twice. Two reverse the direction, the cyl head would have to discharge through the ground strap. Ask anyone whoever ever hooked a battery up backwards how that works out in the end
Skip the exotic plugs
