  Totally O/T
  New valveless engine. Wonder if they'll keep calling it Duke..
New valveless engine. Wonder if they'll keep calling it Duke.. by 2.5
Started on: 09-04-2014 03:14 PM
Replies: 10 (1103 views)
Last post by: 2.5 on 09-05-2014 12:49 PM
Report this Post09-04-2014 03:14 PM Click Here to See the Profile for 2.5Send a Private Message to 2.5Edit/Delete MessageReply w/QuoteDirect Link to This Post
http://www.gizmag.com/duke-engines-axial/33631/
"axial engine prototype that completely does away with valves, while delivering excellent power and torque from an engine much smaller, lighter and simpler than the existing technology
Duke Engines' 3-liter, five cylinder test mule is already making a healthy 215 horsepower and 250 lb-ft of torque at 4,500rpm
The Duke engine is an axial design, meaning that its five cylinders encircle the drive shaft and run parallel with it. The pistons drive a star-shaped reciprocator, which nutates around the drive shaft, kind of like a spinning coin coming to rest on a table.
Instead of cam- or pneumatically-operated intake and outlet valves, the cylinders rotate past intake and outlet ports in a stationary head ring. The spark plugs are also mounted in this stationary ring – the cylinders simply slide past each port or plug at the stage of the cycle it's needed for and move on. In this way, Duke eliminates all the complexity of valve operation and manages to run a five-cylinder engine with just three spark plugs and three fuel injectors.
Maybe Aluminum Duke instead of Iron Duke.
Marvin McInnis
Total ratings: 227
Report this Post09-04-2014 04:03 PM Click Here to See the Profile for Marvin McInnisClick Here to visit Marvin McInnis's HomePageSend a Private Message to Marvin McInnisEdit/Delete MessageReply w/QuoteDirect Link to This Post
1) Not valveless. It's a variant of the rotary valve engine.
2) Cylinder head sealing and lubrication?
3) Friction, lubrication, cooling, and sealing of the rotating cylinder block?
[This message has been edited by Marvin McInnis (edited 09-05-2014).]
Report this Post09-04-2014 04:26 PM Click Here to See the Profile for 2.5Send a Private Message to 2.5Edit/Delete MessageReply w/QuoteDirect Link to This Post
2) Cylinder head sealing?
Well, they call it valveless
Yeah I would think the friction on that pivoting spinning main bearing there would be harsh?
Csjag
Report this Post09-04-2014 06:57 PM Click Here to See the Profile for CsjagSend a Private Message to CsjagEdit/Delete MessageReply w/QuoteDirect Link to This Post
I wonder what fuel mileage would be, the Mazda rotaries were pretty thirsty
Formula88
Total ratings: 554
Report this Post09-05-2014 09:29 AM Click Here to See the Profile for Formula88Send a Private Message to Formula88Edit/Delete MessageReply w/QuoteDirect Link to This Post
I wonder how the head ring seals to the combustion chambers.
FIEROPHREK
Total ratings: 137
Report this Post09-05-2014 11:24 AM Click Here to See the Profile for FIEROPHREKSend a Private Message to FIEROPHREKEdit/Delete MessageReply w/QuoteDirect Link to This Post
I really wish the coates sperical valve engine would be more available. I read years ago in a hotrod mag about this retrofit head kit that would make a stock engine into a bad a$$ monster. It eliminated all the horsepower robing parts like cams ,lifters and springs. It also allowed a standard engines RPM level to be pushed up into the 15K's! Higher compression ratio could be run on lower octane fuels as well.From what i remember of the article they took a standard issue 5.0 liter ford motor from a mustang or T-bird (early 90's). The motor made close to 250 hp in stock form. With the coates haeds it made close to 500 hp. It seems coates in focusing its energy on genrators now though
12.3 is faster than a 13.2
fierosound
Total ratings: 286
Report this Post09-05-2014 11:33 AM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
It's a "Duke Engine" because it's the family name.
http://www.dukeengines.com/application/multi-aps/
Calgary time/temp
zetabird
Report this Post09-05-2014 11:38 AM Click Here to See the Profile for zetabirdSend a Private Message to zetabirdEdit/Delete MessageReply w/QuoteDirect Link to This Post
a set of thouse ball valve heads would be pretty neat on my 327
FIEROPHREK
Total ratings: 137
Report this Post09-05-2014 12:23 PM Click Here to See the Profile for FIEROPHREKSend a Private Message to FIEROPHREKEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yours and mine!
Report this Post09-05-2014 12:47 PM Click Here to See the Profile for 2.5Send a Private Message to 2.5Edit/Delete MessageReply w/QuoteDirect Link to This Post
Yeah I just thought it was a funny coincidence, and was part of the reason I posted it on this forum.
Report this Post09-05-2014 12:49 PM Click Here to See the Profile for 2.5Send a Private Message to 2.5Edit/Delete MessageReply w/QuoteDirect Link to This Post
Member since May 2007
Sounds sweet!
