  Totally O/T
  Corvette steering coulmn lock plate?
Corvette steering coulmn lock plate? by Hank is Here
Started on: 09-14-2014 04:26 PM
Replies: 3 (115 views)
Last post by: Hank is Here on 09-14-2014 06:27 PM
Hank is Here
Total ratings: 103
Report this Post09-14-2014 04:26 PM Click Here to See the Profile for Hank is HereSend a Private Message to Hank is HereEdit/Delete MessageReply w/QuoteDirect Link to This Post
My father has 1986 Corvette was had/had a loose steering column. Having tightened the elusive torx bolts on a Fiero column I figured no problem doing so in the Corvette. There is one substantial difference between a Fiero and a Corvette of the same vintage and that is that the Corvette column also telescopes as well as tilts. I have no problem getting it all apart however now that I am in the reassembly stages I can't get the darn lock plate on. Since this is a telescoping column the lock plate is different. The lock is more like a c-clip on an axle than a piece of spring steel on a Fiero. My problem is that I don't see any way to put a tool on to depress the lock plate.
Does anyone have and tips, tricks or insights?
pokeyfiero
Total ratings: 309
Report this Post09-14-2014 05:51 PM Click Here to See the Profile for pokeyfieroClick Here to visit pokeyfiero's HomePageSend a Private Message to pokeyfieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
pokeyfiero
Total ratings: 309
Report this Post09-14-2014 05:55 PM Click Here to See the Profile for pokeyfieroClick Here to visit pokeyfiero's HomePageSend a Private Message to pokeyfieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
pokeyfiero
Member since Dec 2003
Hank is Here
Total ratings: 103
Report this Post09-14-2014 06:27 PM Click Here to See the Profile for Hank is HereSend a Private Message to Hank is HereEdit/Delete MessageReply w/QuoteDirect Link to This Post
Pokey,
Thanks...I think I figured out the secret. I have that lock plate tool and have used it on a Fiero. The trick is on the car with telescoping column thre is nothing to hold the center shaft in with. The trick.....you need to but a 5/16-18 set screw to put down the center shaft to lock it. Once the center shaft is locked then you can use to tool as depicted.
