  Totally O/T
  H-45 military tent heater review
H-45 military tent heater review by Cooter
Started on: 12-06-2014 10:03 PM
Replies: 7 (5254 views)
Last post by: maryjane on 12-07-2014 03:25 PM
Cooter
Total ratings: 138
Report this Post12-06-2014 10:03 PM Click Here to See the Profile for CooterSend a Private Message to CooterEdit/Delete MessageReply w/QuoteDirect Link to This Post
It seems that eBay sellers found a warehouse full of these surplus diesel fuel powered tent heaters. A friend picked one up to put in his shop and we have played around with it just a bit and for a non-powered heater, it really throws out some BTU's! After getting all the cosmoline burned off, there is no odor from it and it runs for at least a couple of hours on a gallon of fuel. Since he is an amateur cook, he has a lot of old cooking oil that he was saving to use for bio-diesel, but we decided to try it in the heater blended with 50% diesel fuel. With the old fry oil, it burns clean and seems to heat about as well as it does with straight diesel. I used a thermal gun to check the temp of the outside of the heater and with the fry oil, there was about 100 degrees difference (400 degrees vs 500)- still plenty hot enough to heat the shop.
All in all, for about $120, it is a great vented heater that will run on many different fuels (gasoline, jp5, jp8 and diesel), kicks out up to 45,000 BTUs and does it quietly.
Total ratings: 441
Report this Post12-06-2014 10:48 PM Click Here to See the Profile for maryjaneSend a Private Message to maryjaneEdit/Delete MessageReply w/QuoteDirect Link to This Post
Is it what used to be called the hunter heater--just a round tub looking thing? Hunters are hard to beat.
old style--no hoses or nything else.
The newer style, you attach a tank off to the side of it--the older ones, you just pour fuel into the bottom of the tub.
Cooter
Total ratings: 138
Report this Post12-06-2014 10:58 PM Click Here to See the Profile for CooterSend a Private Message to CooterEdit/Delete MessageReply w/QuoteDirect Link to This Post
That's the one. It came with an adjustable 'thermostat' with selections for the different fuels, and the hoses for attaching it to a standard 5 gallon 'jerry can'. Super simple and effective design. The surplus market seems to be flooded with them right now, so I wonder if a replacement has been issued and all the old ones are being phased out. If you need a small shop heater, this thing will do it.
Total ratings: 441
Report this Post12-06-2014 11:20 PM Click Here to See the Profile for maryjaneSend a Private Message to maryjaneEdit/Delete MessageReply w/QuoteDirect Link to This Post
If it has hoses, then it's a relatively newer model than what I have expereince with.
The old ones I am familar with, look a lot like that, but were from the 1940s and Korean War. a 1941 design if I remember correctly. When it ran out of fuel, youlet it cool down and poured some more desel into the bottom of it--had some kind of wick looking thing all around the bottom.
(they still used them at one of the little outlying fields at Cherry Pt Marine Air Base when I was there in the early 70s--some ind of field training facility--I forget it's name)
pokeyfiero
Total ratings: 309
Report this Post12-07-2014 02:15 AM Click Here to See the Profile for pokeyfieroClick Here to visit pokeyfiero's HomePageSend a Private Message to pokeyfieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Government liquidation has them now and again in lots of 12 usually of lots of several lift2 of 12 each.
Never had any experience though. Sounds expensive.
Probably buy the lot of 12 for 120 bucks but you still deal with shipping if you can't pick up yourself.
jimbolaya
Total ratings: 114
Report this Post12-07-2014 06:34 AM Click Here to See the Profile for jimbolayaSend a Private Message to jimbolayaEdit/Delete MessageReply w/QuoteDirect Link to This Post
These can run indoors? No CO issues?
Jim
Cooter
Total ratings: 138
Report this Post12-07-2014 09:58 AM Click Here to See the Profile for CooterSend a Private Message to CooterEdit/Delete MessageReply w/QuoteDirect Link to This Post
I figured they went pretty cheap at the government auctions, but they are heavy (like 80 pounds), so the cost of shipping them is steep. These heaters are just another example of our tax dollars wasted- each one cost around $800 for the government to purchase and they are selling them off by the truckload for only pennies on the dollar
Jim- they are supposed to be vented. When you first light it off and shut it down, it smokes a lot. When it is running, it still puffs some black smoke so there is no way that I would run one in a tightly enclosed area. Even with the stack vented to the outside, it probably still leaks some CO. I would only use it in a garage or shop that has some air leaks, or leave a window cracked just a bit.
I know that diesel is not the cheapest fuel supply, but if you are using a kerosene heater, this might be something to consider. There are no electric components or wick and the 45,000 BTU is a bit higher than many similar priced non-powered kerosene heaters. Since it seems to run well on the mix of waste vegetable oil and diesel, we are going to try it with used motor oil and diesel and see how it does. If it will burn the oil, we have a very large supply of fuel ready to go, so fuel cost would be pretty low. I'll let you know how it goes.
Total ratings: 441
Report this Post12-07-2014 03:25 PM Click Here to See the Profile for maryjaneSend a Private Message to maryjaneEdit/Delete MessageReply w/QuoteDirect Link to This Post
Many years ago, when I was a teenager used to frequent a covered rodeo arena right down the road from my house-- a kinda of seedy place, where a young man could learn both good and not-so-good habits from the older cowboys--and cowgirls. They had good rodeos on Saturday night and Sun afternoons, but Tuesday and Thurs nights were "practice" nights where you could ride a bull or bucking horse for a fe bucks per buck out. Above the roping chutes, there was a concession stand, jukebox and little dance floor, but most weekday nights, there was a poker game going on at a table in the middle of that dance floor--us young ones were not allowed to play or drink beer from the concession stand, but we usually found a way--it was a pretty rough place and my mother hated the fact that I spent a lot of tuesday and thursday nights there--she called it "that den of inequity". Lots of fights and other such excitement but plenty of buckle bunnies there tho...and our 'mentors' were probably not what was envisoned when the place was built as a youth rodeo facility. It wasn't named the Double Trouble Arena for nothing. In winter, they had one of the heaters pictured above and it put out a heck of a lot of heat and not much fumes if the damper was set right. You just poured deisel or kerosene or whatever they could find to burn in the bottom, dropped a lit piece of paper down in and the surface oof the liquid would soon start up burning. The heat from that created a volatile vapor, and that burning gas is really what created the heat. Had an air damper on the inlet tube to control the flame, and to put it out, you just closed both dampers and placed a cover over the stack. If they used bad fuel to, and had the air damper open too mch, flames would leap out the top, and closing the air off too suddenly cause the thing to start 'WoooF! Whoof! whoofing'-pouring flame and smoke alternately in big pulses out the stack and the entire base would jump up and down off the floor. I saw it get out of hand one night and they ended up having to shove the whole thing off the dance foor over the edge and down onto the dirt arena floor below.
Good times in that place..
[This message has been edited by maryjane (edited 12-07-2014).]
