  Totally O/T
  problem with convertxtodvd 5
problem with convertxtodvd 5 by Tweeder
Started on: 01-05-2015 02:21 PM
Replies: 5 (3755 views)
Last post by: Tweeder on 01-06-2015 11:40 PM
Tweeder
Report this Post01-05-2015 02:21 PM Click Here to See the Profile for TweederSend a Private Message to TweederEdit/Delete MessageReply w/QuoteDirect Link to This Post
This is the second video in the past few days thats giving me an error saying "the titleset 1 doesnt have an enabled video stream. Each titleset must contain atleast one enabled video stream." These are MKV files. Never had this problem before and I have burned tons of mkv files.
86 SE Convertible 3800sc 4t65e HD(2002), Gen V, 3.3 pulley, SD headers
TheDigitalAlchemist
Total ratings: 94
Report this Post01-05-2015 02:50 PM Click Here to See the Profile for TheDigitalAlchemistClick Here to visit TheDigitalAlchemist's HomePageSend a Private Message to TheDigitalAlchemistEdit/Delete MessageReply w/QuoteDirect Link to This Post
Try using one of the two tools mentioned here to examine those 2 files...see what's 'different'
[This message has been edited by TheDigitalAlchemist (edited 01-05-2015).]
Tweeder
Report this Post01-05-2015 02:52 PM Click Here to See the Profile for TweederSend a Private Message to TweederEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by TheDigitalAlchemist:
Use g-spot, see what's up*> (I'm assuming g-spot can view that stuff)
Compare those 2 with others which work for you...
All google gave me is sex advice, lol
Edit, the linky came through after I posted this.
[This message has been edited by Tweeder (edited 01-05-2015).]
TheDigitalAlchemist
Total ratings: 94
Report this Post01-05-2015 02:53 PM Click Here to See the Profile for TheDigitalAlchemistClick Here to visit TheDigitalAlchemist's HomePageSend a Private Message to TheDigitalAlchemistEdit/Delete MessageReply w/QuoteDirect Link to This Post
I updated my info above
Tweeder
Report this Post01-05-2015 03:42 PM Click Here to See the Profile for TweederSend a Private Message to TweederEdit/Delete MessageReply w/QuoteDirect Link to This Post
the g spot showed up unknown. mediainfo came up with a virus that avg killed and matroskadiag came up with this
Matroska file info : G:\Fury.2014.720p.WEBRiP.x265.AC3.SiMPLE\Fury.2014.720p.WEBRiP.x265.AC3.SiMPLE.mkv
File size : 2.87 GB
DirectShow RenderFile check :
Matroska Splitter : Gabest's Matroska Splitter
Installed : no
Can be created : no
Matroska Splitter : Haali's Matroska Splitter
Installed : no
Can be created : no
RenderFile with DirectShow : Cannot play back the file. The format is not supported. (0x80040265)
DirectShow detailed rendering :
0> MyRenderFile : G:\Fury.2014.720p.WEBRiP.x265.AC3.SiMPLE\Fury.2014.720p.WEBRiP.x265.AC3.SiMPLE.mkv
0> Creation of GraphBuilder : OK
0> Creation of FilterMapper2 : OK
0> Adding graph to ROT : OK
78> Creation of source filter : OK
78> # Rendering output pin G:\Fury.2014.720p.WEBRiP.x265.AC3.SiMPLE\Fury.2014.720p.WEBRiP.x265.AC3.SiMPLE.mkv(Output)
78> Filters matching mediatype : CyberLink FLV Splitter(PDVD10), AVI Splitter, AC3 Parser Filter, CyberLink RealMedia Splitter(PDVD10), MPEG-2 Demultiplexer, MPEG-I Stream Splitter, CyberLink MPEG-4 Splitter (PDVD10)
78> Trying connection to CyberLink FLV Splitter(PDVD10) :
94> Failed connecting pin to CyberLink FLV Splitter(PDVD10), removing it now.
109> Trying connection to AVI Splitter :
109> Failed connecting pin to AVI Splitter, removing it now.
109> Trying connection to AC3 Parser Filter :
109> Failed connecting pin to AC3 Parser Filter, removing it now.
109> Trying connection to CyberLink RealMedia Splitter(PDVD10) :
109> Failed connecting pin to CyberLink RealMedia Splitter(PDVD10), removing it now.
109> Trying connection to MPEG-2 Demultiplexer :
109> Failed connecting pin to MPEG-2 Demultiplexer, removing it now.
109> Trying connection to MPEG-I Stream Splitter :
109> Failed connecting pin to MPEG-I Stream Splitter, removing it now.
109> Trying connection to CyberLink MPEG-4 Splitter (PDVD10) :
15250> Failed connecting pin to CyberLink MPEG-4 Splitter (PDVD10), removing it now.
15250> MyRenderFile finished : There is no common media type between these pins. (0x80040207)
and i couldn't figure out the mkvtools program.
Tweeder
Report this Post01-06-2015 11:40 PM Click Here to See the Profile for TweederSend a Private Message to TweederEdit/Delete MessageReply w/QuoteDirect Link to This Post
Any info on that garble I posted?
