Watch the bullets carefully. Even though Hammers are control 1 trigger, bullets often don't leave the barrel at same time.
Got to be interesting how stresses for slide, ejector and barrel locking affects wearing the gun or feed/ejecting problems over time.
Is that from spring rate varying or load inconsistencies? The mechanicals seem to be fixed.
I'm thinking it has to be due to variances in powder load/burn rate. The hammer's drop at the same time and ignight the bullets at the same time. Whenever you chrono a given bullet for muzzle velocity you always take an average of several shots because the muzzle velocity does vary from shot to shot.
[This message has been edited by Formula88 (edited 01-29-2016).]
I would bet that using the same brand and type of ammo in both magazines won't cause a problem over time. Now putting regular ammo in one side and +P in the other, or different grain weight bullets in both sides is probably not a good idea.
