  Totally O/T
  Construction guys-Flooring over plastic
Construction guys-Flooring over plastic by MidEngineManiac
Started on: 04-09-2018 12:52 PM
Replies: 14 (456 views)
Last post by: Notorio on 12-27-2020 10:45 PM
Total ratings: 297
Report this Post04-09-2018 12:52 PM Click Here to See the Profile for MidEngineManiacSend a Private Message to MidEngineManiacEdit/Delete MessageReply w/QuoteDirect Link to This Post
Never tried this before.
One of my clients has a plastic garage/shed (11x22) he wants me to put a sub-floor into, then lay down vinyl tiles. (He uses it as a woodworking shop, so easy sweep-up is important.)
Since the floor is already plastic (24x24 tiles with ribs underneath), I am thinking that should act just fine as a vapor barrier, and I can just glue down some 3/4" pressure-treated plywood then 1/4 sub-flooring over that, then lay the tiles.
That should give him a nice solid floor point-loads wont dent into, and the nice easy clean-up he is after.
Anybody see anything wrong with the idea ?
Here is the building, the flooring is already strong enough to park a car on, but a point-load (wheels on a tool cabinet, legs on a table saw ect WILL eventually sink in and create a dent). Dad had a Keter 8x10 of the same type so I already know the limitations of the building type with respect to condensation ect.
Tony Kania
Total ratings: 305
Report this Post04-09-2018 12:58 PM Click Here to See the Profile for Tony KaniaSend a Private Message to Tony KaniaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Just questions...
Is the building anchored?
What surface is the plastic building sitting on?
What are the chances of water seeping through the plastic existing flooring?
What is being done to prevent water damage?
Any interior pics of the actual building, or it's builder's .com?
What type of tile are you planning on installing?
What type of mastic are you using?
Total ratings: 297
Report this Post04-09-2018 01:08 PM Click Here to See the Profile for MidEngineManiacSend a Private Message to MidEngineManiacEdit/Delete MessageReply w/QuoteDirect Link to This Post
Just questions...
Free-floating on a gravel base
Pretty slim, he said he had a professional site-prep when ha got it in a few years ago and has had no issues since. I am guessing either 4 or 6" of gravel but aint about to move the building and dig down to find out
Just whats already there. Factory rain gutters, and he runs a dehumidifier in the summer to handle the condensation.
10-year peel-and-stick from Home Depot.
Construction adhesive, probably Bulldog, for the plywood.
Tony Kania
Total ratings: 305
Report this Post04-09-2018 01:16 PM Click Here to See the Profile for Tony KaniaSend a Private Message to Tony KaniaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Very cool.
My only thought now is a vapor barrier needed between the plastic flooring already there, and the sub floor?
Edit: That plastic flooring will sweat a lot. May want to check into laying down some .6 mil? I have not done this before, but that is where my concern lies at the moment.
[This message has been edited by Tony Kania (edited 04-09-2018).]
Total ratings: 297
Report this Post04-09-2018 01:28 PM Click Here to See the Profile for MidEngineManiacSend a Private Message to MidEngineManiacEdit/Delete MessageReply w/QuoteDirect Link to This Post
Costco sells them, and there is no-where else in Canada you are going to get over 200 sq ft of shop space for under $5,000.
https://www.costco.ca/Lifet...roduct.10365120.html
Total ratings: 154
Report this Post04-09-2018 05:51 PM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
My home is built on a slab. It had carpet when it was built. I have since removed the carpet in the living room and hallway and installed bamboo hardwood flooring. The recommendation from the seller of the flooring was to put a sealer on the floor if I was going to glue it down or put down a vapor barrier and install it as a floating floor. Both methods was because there is still a natural draw of moisture from the ground. The carpet could absorb and evaporate it, but with a more solid surface, problems could occur.
The only problem I had was the cost of the adhesive and that the vapor barrier only came in a 50 x 1000 ft roll and added considerable cost to the conversion, but it was less than a painted urethane barrier and adhesive and didn't require drying time. Luckily, one of our club members had a roll from former employment and gave it to me. If you use a vapor barrier, turn it up on all perimeters then trim it back flush with the flooring or cover it with base molding. That protects the edges from moisture.
IMSA GT
Total ratings: 253
Report this Post04-09-2018 07:02 PM Click Here to See the Profile for IMSA GTSend a Private Message to IMSA GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Seems like a few coats of a good garage epoxy floor paint would do just fine. Save some money plus it would be chemical resistant and be easy to sweep.
rogergarrison
Total ratings: 551
Report this Post04-10-2018 05:51 AM Click Here to See the Profile for rogergarrisonSend a Private Message to rogergarrisonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Seems to me just the idea of plastic square tiles...with gaps...is not any kind of barrier to water. It just comes thru the gaps somewhere. Id even consider an unbroken layer of EDPM rubber that would come up an inch or two on the walls to seal it...then lay your finish tile on that. Theyve been using that on RV roofs for years to seal out water.
Blacktree
Total ratings: 350
Report this Post04-10-2018 03:48 PM Click Here to See the Profile for BlacktreeClick Here to visit Blacktree's HomePageSend a Private Message to BlacktreeEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have a similarly constructed shed (although smaller) sitting on a bed of gravel, and the plastic floor panels do "sweat" from temperature / humidity changes. So I think a vapor barrier would be a good idea.
WBailey1041
Total ratings: 81
Report this Post04-15-2018 12:11 AM Click Here to See the Profile for WBailey1041Send a Private Message to WBailey1041Edit/Delete MessageReply w/QuoteDirect Link to This Post
During the site prep they must have thoroughly compacted the gravel bed it sits on. Seems sturdy. If I was the redneck engineer I'd cover the existing floor with 2x2 Sleepers, a minimum of 10 mil plastic then 3/4 marine grade plywood if the budget allowed. If not try THIS
Read why here
http://incomingbytes.com/ho...ure-treated-plywood/
Then I'd mix up enough Jif-Set to lay down 1/8 inch of 4500 psi self leveling Gypsum-crete. (<--- That's MY redneck engineer word)
Then do with it what you like for a final finish, you just bullet proofed a plastic shed floor cheap and easy!
javt03
Report this Post12-22-2020 11:14 AM Click Here to See the Profile for javt03Send a Private Message to javt03Edit/Delete MessageReply w/QuoteDirect Link to This Post
Hey man, about flooring you can try epoxy flooring, it's the best and can last for long time take note of this guys that helped me in previous projects [Edited by Cliff Pennock: Link removed]
Total ratings: 465
Report this Post12-22-2020 01:27 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by javt03:
Hey man...
SPAM
[EDIT] Disregard the thumbs up typo! Can't edit it.
[This message has been edited by Patrick (edited 12-22-2020).]
Notorio
Report this Post12-27-2020 04:50 PM Click Here to See the Profile for NotorioSend a Private Message to NotorioEdit/Delete MessageReply w/QuoteDirect Link to This Post
That link is dead. I've searched for every type of storage shed but am not finding it. Do you have a part number?
Hmmmn. With the proposed floor and some insulation this could be a 'tiny home' of sorts for emergencies ...
Total ratings: 441
Report this Post12-27-2020 05:04 PM Click Here to See the Profile for maryjaneSend a Private Message to maryjaneEdit/Delete MessageReply w/QuoteDirect Link to This Post
The thread original post is over 2 years old.
Mdl # 60236 Lifetime
https://www.lifetime.com/li...ng?bvstate=pg:2/ct:q
[This message has been edited by maryjane (edited 12-27-2020).]
Notorio
Report this Post12-27-2020 10:45 PM Click Here to See the Profile for NotorioSend a Private Message to NotorioEdit/Delete MessageReply w/QuoteDirect Link to This Post
LOL, thanks for the updated link.
