  Totally O/T
  OK now! Cut that crap out!
OK now! Cut that crap out! by williegoat
Started on: 07-12-2020 06:38 PM
Replies: 12 (394 views)
Last post by: theogre on 08-10-2020 09:50 PM
Total ratings: 106
Report this Post07-12-2020 06:38 PM Click Here to See the Profile for williegoatClick Here to visit williegoat's HomePageSend a Private Message to williegoatEdit/Delete MessageReply w/QuoteDirect Link to This Post
steve308
Total ratings: 58
Report this Post07-12-2020 08:26 PM Click Here to See the Profile for steve308Send a Private Message to steve308Edit/Delete MessageReply w/QuoteDirect Link to This Post
But it's a dry heat!
RWDPLZ
Total ratings: 305
Report this Post07-12-2020 08:39 PM Click Here to See the Profile for RWDPLZSend a Private Message to RWDPLZEdit/Delete MessageReply w/QuoteDirect Link to This Post
I thought Phoenix was bad, until I went to Yuma and San Luis.
Total ratings: 106
Report this Post07-12-2020 08:51 PM Click Here to See the Profile for williegoatClick Here to visit williegoat's HomePageSend a Private Message to williegoatEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yeah, so is a plasma cutter.
Total ratings: 106
Report this Post08-08-2020 10:50 PM Click Here to See the Profile for williegoatClick Here to visit williegoat's HomePageSend a Private Message to williegoatEdit/Delete MessageReply w/QuoteDirect Link to This Post
Well, today we tied the record for the number of days in one year at or above 110o and there is not a break in sight. Sometime this coming week (or the next) we will establish a new record.
Usually, by Independence Day the Summer rains (inaccurately called monsoons) have started, but I haven't seen rain in so long, I had to look it up to make sure I was spelling it right.
Total ratings: 226
Report this Post08-08-2020 11:17 PM Click Here to See the Profile for blackramsSend a Private Message to blackramsEdit/Delete MessageReply w/QuoteDirect Link to This Post
As a good friend of mine says (when I complain about the humidity in Southern Mississippi), you knew it was hot and humid before you moved there, why are you bitching about it now...…
I remind him of that when he complains about how cold it is in South Dakota in the winter.
Apply as applicable.
Rams
Total ratings: 200
Report this Post08-08-2020 11:29 PM Click Here to See the Profile for 82-T/A [At Work]Send a Private Message to 82-T/A [At Work]Edit/Delete MessageReply w/QuoteDirect Link to This Post
Hottest I've ever been in was 120 degrees in Qatar during the summer.
It was unbelievable. Literally felt like what happens when you open the oven door and you're hit with a blast of dry hot air.
Boondawg
Total ratings: 342
Report this Post08-08-2020 11:55 PM Click Here to See the Profile for BoondawgSend a Private Message to BoondawgEdit/Delete MessageReply w/QuoteDirect Link to This Post
I once seen it so hot that I got a sunburn* on the under-side of my seed-sack.
* skiing naked at Alyeska.
Wait, let me guess...somebody don't like that!
[This message has been edited by Boondawg (edited 08-09-2020).]
Report this Post08-09-2020 01:07 AM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Dry Heat is your problem?
119°F w/ 127° Heat Index = ~ 20% Relative Humidity...
https://www.weather.gov/safety/heat-index and https://www.wpc.ncep.noaa.gov/html/heatindex.shtml
In East, West and Gulf areas a 90+°F day plus 70-100% Relative Humidity can kill easy even when you drink water because you sweating won't cool.
Same reason anything acting as a "Swap cooler" often doesn't work well or at all in a lot of places. Spray bottles, mister nozzles and related might feel cool when first touch you but water just clings then won't dry fast and often feels worse.
Many run AC at 75-80° or even higher just to dry the air so you won't get too hot and prevent mold.
Then add even DE PA and maybe NJ had Tornadoes this week and not just for Isaias.
Two in DE and PA was on the ground a long time too. Tornado in DE was down for ~ 30 miles but seems no-one really hurt or killed.
Boondawg
Total ratings: 342
Report this Post08-09-2020 01:11 AM Click Here to See the Profile for BoondawgSend a Private Message to BoondawgEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by theogre:
Dry Heat is your problem?119°F w/ 127° Heat Index = ~ 20% Relative Humidity...Then add even DE PA and maybe NJ...
Whoa, you had me a dry-heat, killer...
Chief08
Report this Post08-10-2020 12:32 PM Click Here to See the Profile for Chief08Send a Private Message to Chief08Edit/Delete MessageReply w/QuoteDirect Link to This Post
This is why I have to get up a four in the morning to work on my car. Here in Yuma we hibernate in the summer, I can't wait for winter.
Total ratings: 297
Report this Post08-10-2020 12:36 PM Click Here to See the Profile for MidEngineManiacSend a Private Message to MidEngineManiacEdit/Delete MessageReply w/QuoteDirect Link to This Post
We are hitting 40c (104f) with humidex today and for the rest of the week. Considering I am 1km from this giant swamp cooler known as Lake Erie, I dont wanna know what they are getting further north.
Report this Post08-10-2020 09:50 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Many places have good data like http://www.deos.udel.edu/st...dex.php?station=DAGF
Run By U Del to cover local areas but a lot of East Coast are ~ same weather.
example:
the rain from one short "Popup storm" on sun.
Real temp is "only" 90-95 max this year but you swim to go to anywhere.
Note that %RH is directly tied to Temp etc and 100% here over night is easy even w/o rain in last 25hrs. Look like a "wet" night again.
When you go out even during day time your clothes are quickly soaked and often don't cool you unless maybe have a lot on wind.
