  Totally O/T
  Any archers here ? Bow re-design math
Any archers here ? Bow re-design math by MidEngineManiac
Started on: 06-26-2022 01:44 AM
Replies: 4 (315 views)
Last post by: MidEngineManiac on 08-25-2022 04:14 PM
Total ratings: 297
Report this Post06-26-2022 01:44 AM Click Here to See the Profile for MidEngineManiacSend a Private Message to MidEngineManiacEdit/Delete MessageReply w/QuoteDirect Link to This Post
Making my head hurt trying to figure this one out.
Picked up one of these for 5 bucks. I am re-purposing the limbs into a crossbow.
Ditching the riser and the inner ends of the limbs will be about 3 inches apart. Limb angle will flatten out a little, probably around 10-12 degrees. Dont want the string hitting the back of the limbs or nose-piece, but I do want it pushing on the bolt as long as possible.
So, the new overall length is around 48-50 inches
HOW do I calculate the new draw length and weight (weight probably wont change much, but draw will be a bunch shorter). It wont be firing regular bolts, I am designing it around these and a captive-track system of 4x 1/2" AL tubes.
I could go trial-and-error and make a bunch of nose pieces and get a fishscale and measuring tape, but if there is an easier way to do it, I'd rather not waste a roll of filament and a weeks print time. It's not MAJOR changes to the geometry, but enough that a couple inches either way will be underpowered or get into the range of cracking the fiberglass. These things arent exactly high-quality.
[This message has been edited by MidEngineManiac (edited 06-26-2022).]
hnthomps
Total ratings: 50
Report this Post06-26-2022 08:33 AM Click Here to See the Profile for hnthompsSend a Private Message to hnthompsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Ditching the riser and the inner ends of the limbs will be about 3 inches apart. Limb angle will flatten out a little, probably around 10-12 degrees. Dont want the string hitting the back of the limbs or nose-piece, but I do want it pushing on the bow as long as possible.
Your starting bow is rated at 40 pounds draw and the crossbow bolts are 50-80 pounds according to the site info. You might want to consider a better match of the components to get a more effective or accurate weapon at the end of the game.
Nelson
Total ratings: 297
Report this Post06-26-2022 08:59 AM Click Here to See the Profile for MidEngineManiacSend a Private Message to MidEngineManiacEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yeh, but those are pistol bolts, designed for maybe 6 inches of acceleration. I'm giving them around 2 feet.
Think the difference if firing a bullet from a pistol or rifle. Same round and caliber, is going one hell of a lot faster out of the rifle.
Same concept.
Meh, I just grabbed this thing at a yard sale on a whim. Maybe I can do something neat with it, maybe not.
If all else fails I can cut the limbs down in size a little to stiffen them up.
TinaBeyer
Report this Post08-25-2022 07:34 AM Click Here to See the Profile for TinaBeyerSend a Private Message to TinaBeyerEdit/Delete MessageReply w/QuoteDirect Link to This Post
So, please, how to calculate the draw's parameters? I couldn't get a conclusion. When I see some data about tubes and needed calculus, I get stressed because all these are hard for me. I am still a student, and the biggest challenge is mathematics, so I do it only with college algebra help, with solved and explained questions. https://plainma...dary/algebra is my salvation. Otherwise, I would fail the math courses since it is a science too difficult for my creative personality. Therefore, life math problems are also challenging me.
[This message has been edited by TinaBeyer (edited 08-29-2022).]
Total ratings: 297
Report this Post08-25-2022 04:14 PM Click Here to See the Profile for MidEngineManiacSend a Private Message to MidEngineManiacEdit/Delete MessageReply w/QuoteDirect Link to This Post
Never did calculate it, just trial-and-error with a chunk of wood and some c-clamps. Ended up around 25" draw.
Shot it a few times and got 200 bucks for it. Not bad for under 40 build cost.
[This message has been edited by MidEngineManiac (edited 08-25-2022).]
