  Totally O/T
  Chevy Curze throwing code ---- C0800-07, any hints or helpers?
Chevy Curze throwing code ---- C0800-07, any hints or helpers? by pavo_roddy
Started on: 10-07-2023 04:36 PM
Replies: 2 (2501 views)
Last post by: RichLo1 on 10-08-2023 10:05 PM
pavo_roddy
Total ratings: 71
Report this Post10-07-2023 04:36 PM Click Here to See the Profile for pavo_roddySend a Private Message to pavo_roddyEdit/Delete MessageReply w/QuoteDirect Link to This Post
HI all
2014 Cruze with a 1.8
My car is throwing the above mentioned code. My guy tells me it could be any component in the system, and doesn't want to start replacing all kinds of pieces if they don't need it. He also told me that this is a fairly big problem for GM. From his expertise it looks like a software problem, and tells me there isn't a reason to continue driving.
Any one have experience with this code? Any one with a hint?
Thanx all,
Earick
Max The Chainsaw
Total ratings: 71
Report this Post10-08-2023 02:42 AM Click Here to See the Profile for Max The ChainsawClick Here to visit Max The Chainsaw's HomePageSend a Private Message to Max The ChainsawEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by pavo_roddy:
HI all
Thanx all,
Earick
Chevrolet DTC C0800 07
Make:
Chevrolet
Code:
C0800 07
Definition:
Device Power 1 Circuit Voltage Above Threshold
Description:
The vehicle is ON.
Cause:
The control module or sensor detects a system voltage of less than approximately 9 V or greater than 18 V for approximately 5 seconds.
Failure Type:
Mechanical Failure
This sub type is used for Mechanical Failures that cannot be assigned to a specific sub type.
Start with checking battery, cables and alternator. Possible alternator voltage excessive.
RichLo1
Report this Post10-08-2023 10:05 PM Click Here to See the Profile for RichLo1Send a Private Message to RichLo1Edit/Delete MessageReply w/QuoteDirect Link to This Post
Yea, clean the battery terminals, if its low voltage. If its high voltage, replace the alternator.
You can watch the voltage on the in-dash system. If its between 12.5-15v its normal but watch for anything out of that range to tell you if its a low or high error
