  Totally O/T
  Shingle Roof Rejuvenator
Shingle Roof Rejuvenator by Larryinkc
Started on: 02-20-2024 02:56 PM
Replies: 11 (233 views)
Last post by: Jake_Dragon on 02-22-2024 08:15 PM
Larryinkc
Report this Post02-20-2024 02:56 PM Click Here to See the Profile for LarryinkcSend a Private Message to LarryinkcEdit/Delete MessageReply w/QuoteDirect Link to This Post
TIA
My roof is GAF Timberline, 17 years old, probably will need to be replaced in another 5 years. I went to a local home show and found a company called Roof Renew that sprays an agricultural bio-oil solution on the roof that re-saturates the asphalt shingles extending their life. The cost for my 30 square roof is $3,000.00, new roof probably at least $15,000.00 to $20,000.00. There are several similar products on the market. Has anybody had any experience or information about this process.
From their webpage
https://roofrenew-va.com/our-product
How It Works
As asphalt shingles age, the petro-chemical oils that maintain the shingle’s flexibility and performance begin to evaporate, and problems begin to develop. Roof Renew applies an all-natural bio-based solution that replaces lost petro-chemical oils, bringing the shingle back to life. The first application is guaranteed to extend the life of your roof by 5 years, and up to 15 years with 2 more applications every 5 years.
What Roof Renew Treatment Does
Rejuvenates aging asphalt shingles so they don’t have to be replaced
Extends the life of the shingles by 5-15 years
Improves granule adhesion by 86%
Reduces damage caused by wind and hail
Restores shingle color
Kills algae and moss, and hinders re-growth
Keeps shingles out of landfills (more below)
Improves fire resistance by 40%.
Lab Tested
Independent testing by PRI Asphalt Technologies compared treated vs. untreated shingles with the following findings:
Granular adhesion improved by 86%.
Flexibility improved from “fail” to “pass”.
Hail impact was improved.
Fire resistance improved by 40%.
Report this Post02-20-2024 07:58 PM Click Here to See the Profile for 82-T/A [At Work]Send a Private Message to 82-T/A [At Work]Edit/Delete MessageReply w/QuoteDirect Link to This Post
It's definitely intriguing... but there's usually more to needing to replace shingles than merely dried out shingles. Sometimes they can get damaged, the nails will pop-up, etc... but either way, that's still pretty cool. Are you going to do it?
Total ratings: 106
Report this Post02-20-2024 08:16 PM Click Here to See the Profile for williegoatClick Here to visit williegoat's HomePageSend a Private Message to williegoatEdit/Delete MessageReply w/QuoteDirect Link to This Post
It sounds like they want you to redo it every five years. Good shingles will last 25 years even in the Arizona sun. Is it really cost effective?
Total ratings: 154
Report this Post02-20-2024 09:33 PM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
I was just looking at that earlier this week. There is another company advertising the same process but I can't remember the name. How many square feet is 30 square? I've got 2000 square feet. Just want to get an idea of ballpark cost before I put my name in their database.
IMSA GT
Total ratings: 253
Report this Post02-20-2024 09:41 PM Click Here to See the Profile for IMSA GTSend a Private Message to IMSA GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
30 square is 3000 sq ft so you would be at 20 square for your 2000 sq ft roof.
[This message has been edited by IMSA GT (edited 02-20-2024).]
Total ratings: 154
Report this Post02-21-2024 10:00 AM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thank you. Might be a little cheaper down here. I'm on the edge of Metro and Farm Country.
Reading some review sites about the process, most encountered higher costs than quoted because the application company usually found other 'issues' that needed to be addressed. Something to be aware of and consider.
Larryinkc
Report this Post02-21-2024 10:56 AM Click Here to See the Profile for LarryinkcSend a Private Message to LarryinkcEdit/Delete MessageReply w/QuoteDirect Link to This Post
I am still looking for more information as this is a fairly new product. I am going to get a couple of bids on a new roof and compare the cost on an annual basis. With a new roof I know exactly what to expect, I would be taking a chance that the rejuvenation really will work.
cliffw
Total ratings: 295
Report this Post02-21-2024 11:32 AM Click Here to See the Profile for cliffwSend a Private Message to cliffwEdit/Delete MessageReply w/QuoteDirect Link to This Post
Does an all-natural bio-based solution replace lost petro-chemical oils ? I have to wonder what's in that all-natural bio-based solution.
I know railway ties are treated in a petroleum saturation of some sorts when new, to preserve them. I have gotten used ones before and "painted" them with used motor oil.
I wonder if one can not "paint" a roof with linseed oil.
Mickey_Moose
Total ratings: 145
Report this Post02-21-2024 11:56 AM Click Here to See the Profile for Mickey_MooseSend a Private Message to Mickey_MooseEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have talked to a local company about this a year ago and basically it only works if your shingles are already in good condition. It will not fix them if they have started to curl or have lost too much of the grain.
From my discussions with them, to me it sounded more like snake oil. Maybe it does help extend the life if done every 5 years as suggested, but this is still too new of a process IMHO.
I ended up biting the bullet and replaced the shingles.
Total ratings: 106
Report this Post02-21-2024 12:19 PM Click Here to See the Profile for williegoatClick Here to visit williegoat's HomePageSend a Private Message to williegoatEdit/Delete MessageReply w/QuoteDirect Link to This Post
I wonder if it is made from recycled cooking oil. There is a product used for dust control on some dirt yards such as large lumber yards, that smells like french fries.
Total ratings: 230
Report this Post02-22-2024 01:24 PM Click Here to See the Profile for blackramsSend a Private Message to blackramsEdit/Delete MessageReply w/QuoteDirect Link to This Post
While such a application does sound interesting, I have to ask what any warranty covers?
Shingle failure due to damage is probably not covered but, a lot more information is needed before I'd take a $3K risk. Most shingles fail due to wind, hail or just sun damage. What's covered if there is a warranty?
Rams
Total ratings: 403
Report this Post02-22-2024 08:15 PM Click Here to See the Profile for Jake_DragonSend a Private Message to Jake_DragonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Check with your house insurance before you do it. My insurance has all kind of odd rules. They were going to drop coverage because not all of the shingles were the same color. (You try to find shingles after a hurricane)
