  Totally O/T
  The latest brake regulation from the NHTSA!!!
The latest brake regulation from the NHTSA!!! by 82-T/A [At Work]
Started on: 03-03-2025 10:55 AM
Replies: 11 (124 views)
Last post by: Wichita on 03-06-2025 04:11 PM
Report this Post03-03-2025 10:55 AM Click Here to See the Profile for 82-T/A [At Work]Send a Private Message to 82-T/A [At Work]Edit/Delete MessageReply w/QuoteDirect Link to This Post
Fellow car friends... behold, the latest mandatory and regulatory requirement from the NHTSA for brakes... will be required in all cars starting next year.
It has mandatory battery regeneration, multiple layers of redundant brake pads (because 0.0001% failure rate means one crash too many), and it will be added at no cost to you (only the manufacturer will have to pay) on all new vehicles! Best of all... it'll never have any problems with the 10 brake sensors that are now required to monitor it!!!
cliffw
Total ratings: 295
Report this Post03-03-2025 12:10 PM Click Here to See the Profile for cliffwSend a Private Message to cliffwEdit/Delete MessageReply w/QuoteDirect Link to This Post
April Fools day is a month away.
Total ratings: 461
Report this Post03-03-2025 12:45 PM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yeah... no.
Report this Post03-03-2025 12:51 PM Click Here to See the Profile for 82-T/A [At Work]Send a Private Message to 82-T/A [At Work]Edit/Delete MessageReply w/QuoteDirect Link to This Post
You guys are missing out. It has a disc-mounted master cyl. This is real innovation.
Total ratings: 229
Report this Post03-04-2025 07:31 AM Click Here to See the Profile for blackramsSend a Private Message to blackramsEdit/Delete MessageReply w/QuoteDirect Link to This Post
I assume this was another idea that came out of the Biden Administration?
I especially like that it going to be free and the cost won't be passed on to the consumer. Yep, if it sounds too good to be true then............
Rams
Report this Post03-04-2025 08:44 AM Click Here to See the Profile for 82-T/A [At Work]Send a Private Message to 82-T/A [At Work]Edit/Delete MessageReply w/QuoteDirect Link to This Post
Haha... it's from an account I follow on X, and it's AI-based. It's actually an older image, way before GROK or CoPilot. Basically, it tried to create a braking system based on the homologation of a drum brake system, a disc brake system, and a regenerative braking system... and it basically came up with the craziest most useless looking thing you could possibly imagine. It even looks like it has two fuel injectors attached at the bottom sticking out the side. Haha...
1985 Fiero GT
Report this Post03-04-2025 10:04 AM Click Here to See the Profile for 1985 Fiero GTSend a Private Message to 1985 Fiero GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Well when you wear through the braking surfaces on the main disc, wait a while to wear through the cooling vanes and you'll have a second set of braking surfaces haha.
Report this Post03-04-2025 10:16 AM Click Here to See the Profile for 82-T/A [At Work]Send a Private Message to 82-T/A [At Work]Edit/Delete MessageReply w/QuoteDirect Link to This Post
My favorite part is the CAKESTOR... that's where the cake is kept...
cliffw
Total ratings: 295
Report this Post03-05-2025 01:17 PM Click Here to See the Profile for cliffwSend a Private Message to cliffwEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yeah right.
My marriage has one, .
Do you replace them all at once ?
EDIT
What was the reason why we needed new "math". The dual master cylinder was a very good improvement, front and rear. It was still only one master cylinder.
[This message has been edited by cliffw (edited 03-05-2025).]
Hank is Here
Total ratings: 103
Report this Post03-06-2025 08:55 AM Click Here to See the Profile for Hank is HereSend a Private Message to Hank is HereEdit/Delete MessageReply w/QuoteDirect Link to This Post
Where do you put the DEF?
Report this Post03-06-2025 09:01 AM Click Here to See the Profile for 82-T/A [At Work]Send a Private Message to 82-T/A [At Work]Edit/Delete MessageReply w/QuoteDirect Link to This Post
In the CAKESTOR
Wichita
Report this Post03-06-2025 04:11 PM Click Here to See the Profile for WichitaSend a Private Message to WichitaEdit/Delete MessageReply w/QuoteDirect Link to This Post
EV with Regen.
