  FAQs & HowTos
  Suggestions!
Suggestions! by Cliff Pennock
Started on: 07-10-2012 11:08 AM
Replies: 27 (1885 views)
Last post by: Notorio on 03-06-2024 12:36 AM
Cliff Pennock
Administrator
Total ratings: 699
Report this Post07-10-2012 11:08 AM Click Here to See the Profile for Cliff PennockClick Here to visit Cliff Pennock's HomePageSend a Private Message to Cliff PennockEdit/Delete MessageReply w/QuoteDirect Link to This Post
As I said in the "About" thread, you can't start new threads here directly - they will be moved here from the other sections.
So if you know of a great (Fiero related) HowTo in any of the other sections, please suggest them here! Remember there's a difference between a "build" thread and a HowTo.
Of course, you can also start your own HowTo or FAQ in General Fiero Thread and request it to be moved here.
Bloozberry
Total ratings: 311
Report this Post07-10-2012 11:34 AM Click Here to See the Profile for BloozberrySend a Private Message to BloozberryEdit/Delete MessageReply w/QuoteDirect Link to This Post
Here's my axle shaft replacement thread: www.fiero.nl/forum/Forum2/HTML/109708.html
Bloozberry
Total ratings: 311
Report this Post07-10-2012 11:42 AM Click Here to See the Profile for BloozberrySend a Private Message to BloozberryEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bloozberry
Member since Jan 2009
Starting from the third or forth post down, here's a How To: Convert 1984 Tail Light Circuit to Fastback Tail Lights: www.fiero.nl/forum/Forum2/HTML/118636.html
[This message has been edited by Bloozberry (edited 07-10-2012).]
Curlrup
Report this Post07-10-2012 04:21 PM Click Here to See the Profile for CurlrupSend a Private Message to CurlrupEdit/Delete MessageReply w/QuoteDirect Link to This Post
Curlrup
Report this Post07-10-2012 04:23 PM Click Here to See the Profile for CurlrupSend a Private Message to CurlrupEdit/Delete MessageReply w/QuoteDirect Link to This Post
Curlrup
Member since Apr 2007
And my Vibe Radio conversion thread.
https://www.fiero.nl/forum/A...100421-2-094756.html
Bloozberry
Total ratings: 311
Report this Post07-10-2012 04:50 PM Click Here to See the Profile for BloozberrySend a Private Message to BloozberryEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'd also like to recommend Blacktree's archived thread on splitting the Getrag transmission case here: www.fiero.nl/forum/Archives...120111-2-109502.html
RWDPLZ
Total ratings: 306
Report this Post07-10-2012 05:04 PM Click Here to See the Profile for RWDPLZSend a Private Message to RWDPLZEdit/Delete MessageReply w/QuoteDirect Link to This Post
Heater Core:
https://www.fiero.nl/forum/Forum2/HTML/120145.html
Aux Gauge Pod into an 84:
https://www.fiero.nl/forum/A...090907-2-093286.html
later-style coil into an 84:
https://www.fiero.nl/forum/A...060811-2-068532.html
Brake Line Fitting and Line Sizes:
https://www.fiero.nl/forum/Forum2/HTML/107264.html
Remote Keyless Entry:
https://www.fiero.nl/forum/Forum2/HTML/109083.html
(Upper) Frame Rail Fabrication:
https://www.fiero.nl/forum/Forum2/HTML/120904.html
Jazzman's steering column thread:
https://www.fiero.nl/forum/F...2/HTML/088020-3.html
rubyredfiero's frame rail thread:
https://www.fiero.nl/forum/A...060811-2-068409.html
[This message has been edited by RWDPLZ (edited 07-10-2012).]
IMSA GT
Total ratings: 253
Report this Post07-10-2012 09:24 PM Click Here to See the Profile for IMSA GTSend a Private Message to IMSA GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
NJD85GT
Report this Post07-11-2012 12:55 AM Click Here to See the Profile for NJD85GTSend a Private Message to NJD85GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Cliff Pennock
Administrator
Total ratings: 699
Report this Post07-11-2012 05:23 AM Click Here to See the Profile for Cliff PennockClick Here to visit Cliff Pennock's HomePageSend a Private Message to Cliff PennockEdit/Delete MessageReply w/QuoteDirect Link to This Post
Keep those suggestions coming! I might not move them right away (since I've actually never implemented moving threads back from the Archives) but they will end up here eventually.
85sliverGT
RWDPLZ
Total ratings: 306
Report this Post07-11-2012 10:59 PM Click Here to See the Profile for RWDPLZSend a Private Message to RWDPLZEdit/Delete MessageReply w/QuoteDirect Link to This Post
Cliff Pennock
Administrator
Total ratings: 699
Report this Post07-12-2012 05:31 AM Click Here to See the Profile for Cliff PennockClick Here to visit Cliff Pennock's HomePageSend a Private Message to Cliff PennockEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks for all the suggestions. I will go through them ASAP.
First I need to implement moving threads back from the archives. Just something I never needed so I never made that.
Old Lar
Total ratings: 214
Report this Post07-12-2012 05:03 PM Click Here to See the Profile for Old LarSend a Private Message to Old LarEdit/Delete MessageReply w/QuoteDirect Link to This Post
Link to Sace Coast how to: http://spacecoastfieros.com/tech/
DPoppelll
Report this Post07-27-2012 11:55 PM Click Here to See the Profile for DPoppelllSend a Private Message to DPoppelllEdit/Delete MessageReply w/QuoteDirect Link to This Post
Any threads on removing the 4 cyl alternator? It's kind of tricky With the intake manifold and dog bone on top and the oil filter on the bottom. Any suggestions?
Dan
jaredmurray88
Report this Post08-07-2012 02:05 AM Click Here to See the Profile for jaredmurray88Send a Private Message to jaredmurray88Edit/Delete MessageReply w/QuoteDirect Link to This Post
maybe a good alternator swap? aluminum cradle bushing install? and maybe this would be handy https://www.fiero.nl/forum/F...2/HTML/121904-2.html
https://www.fiero.nl/forum/A...041015-1-015543.html
https://www.fiero.nl/forum/A...120111-2-109042.html
and maybe sway bar add?
eljibaro127
Report this Post10-15-2012 08:23 PM Click Here to See the Profile for eljibaro127Send a Private Message to eljibaro127Edit/Delete MessageReply w/QuoteDirect Link to This Post
FieroFlyer has a GREAT "How To" For a 3800SC wiring harness
https://www.fiero.nl/forum/A...110502-2-087655.html
Hudini
Total ratings: 165
Report this Post11-07-2012 05:29 AM Click Here to See the Profile for HudiniSend a Private Message to HudiniEdit/Delete MessageReply w/QuoteDirect Link to This Post
jaredmurray88
Report this Post01-25-2013 10:52 PM Click Here to See the Profile for jaredmurray88Send a Private Message to jaredmurray88Edit/Delete MessageReply w/QuoteDirect Link to This Post
DIY alignment for the guys that can't fond a good shop
https://www.fiero.nl/forum/A...090907-2-088043.html
CC Rider
Total ratings: 61
Report this Post03-04-2013 11:17 AM Click Here to See the Profile for CC RiderSend a Private Message to CC RiderEdit/Delete MessageReply w/QuoteDirect Link to This Post
CC Rider
Total ratings: 61
Report this Post04-06-2013 11:11 AM Click Here to See the Profile for CC RiderSend a Private Message to CC RiderEdit/Delete MessageReply w/QuoteDirect Link to This Post
Inside the GM tilt steering column
https://www.fiero.nl/forum/Forum2/HTML/088020.html
Bruce
Report this Post04-25-2013 11:21 PM Click Here to See the Profile for BruceSend a Private Message to BruceEdit/Delete MessageReply w/QuoteDirect Link to This Post
Can someone post a step-by-step description of how to remove and replace the factory subwoofer?
Thanks!
bb
eljibaro127
Report this Post11-16-2013 10:17 PM Click Here to See the Profile for eljibaro127Send a Private Message to eljibaro127Edit/Delete MessageReply w/QuoteDirect Link to This Post
Emc209i (l67) Has The best how to swap an F23 Getrag How to:
https://www.fiero.nl/forum/Forum1/HTML/087296.html
Formula88
Total ratings: 554
Report this Post06-01-2014 08:17 PM Click Here to See the Profile for Formula88Send a Private Message to Formula88Edit/Delete MessageReply w/QuoteDirect Link to This Post
Ignition Switch Replacement - with pics.
https://www.fiero.nl/forum/A...090907-2-090390.html
Total ratings: 465
Report this Post11-22-2016 05:24 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Fuel Pump Replacement How-To (56K beware) by Brocephus
This thread is both hilarious and very helpful...
Originally posted by Brocephus:
Grab a pair of safety glasses or if you're lucky enough to have a full face shield, that's even better. Yes, this means you. Gasoline in the eyes sucks total a$$. And for you heroes out there, working with gas with your eyes closed isn't the smartest idea either.
fierosound
Total ratings: 287
Report this Post06-17-2018 08:32 AM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
Parking Brake Cable Tips...
https://www.fiero.nl/forum/Forum2/HTML/141414.html
cvxjet
Report this Post01-12-2020 02:47 PM Click Here to See the Profile for cvxjetSend a Private Message to cvxjetEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hey, Cliff, how about my "Fiero Torque specs list" that I posted in Tech? Here is the link (Hopefully....)
https://www.fiero.nl/forum/Forum2/HTML/143320.html
Notorio
Report this Post03-06-2024 12:36 AM Click Here to See the Profile for NotorioSend a Private Message to NotorioEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hello Cliff. Please move my How To Repair Broken Spoiler Captive Nuts posting in the Technical section to here. Thank you!
