For those of you who don't know, the 84 Fiero uses a different coil than the rest of the Fieros (one of the MANY differences between the 84 and other years). As a result, noone makes a performance coil for the car. However, the later year Fieros have a decent selection of performance coils, including the MSD Blaster Coil (part # 8226), available at most auto parts stores and online. Although not so straightforward, upgrading the stock coil to the later-style coil isn't so difficult.
I would like to appologize for the lack of pictures, I don't own a camera. If anyone would like to contribute pictures of the areas in the install, I'd be more than happy to give you credit.
FIRST: Taking out the old coil
The old coil bracket is held in by a 13mm nut on top and a 13mm bolt on bottom. I got these off with a 13mm deep socket and a 6 inch extension. The top bracket is under the fuel filter bracket, just slide that bracket out far enough off the bolt you can slip the top bracket down through and off the bolt. Disconnect the connector and coil wire.
Next, you can either re-use the old bracket, or get one off an 85-86 iron duke. The 84 bracket will not fit the 85+ coil, as the 84 coil is larger. Until I can find the earlier bracket, I just bent the top ends of the bracket toward each other and put the two top screws in
If you choose to re-use the original bracket, you'll likely need to drill out the factory pins holding it in, unless the coil has ben replaced before. My car of course still had the original coil.
SECOND: The wiring.
The connectors are different. And at least on my car, so are the wire colors. To figure out which wires go where, I consulted the factory wiring diagrams:
The connectors look (something) like this:
First the grey connector: Obviously, the large pink ignition wires need to be connected together. Next, you'll notice a wire that goes along with the pink wire, back into the engine bay. This wire connects to the tach filter. Connect this wire to the black wire with the white stripe on the grey connector.
Next, the black connector. The black connector and the original harness both havea black wire with a pink stripe. These wires go together. That should only leave the original harness'es brown wire, and the black wire on the black connector. Connect these together.
Now plug the connectors onto the coil (they only go on one way, black connector first), reconnect the coil wire, and fire it up. It should start and run the first time. Take it around the block and try it out.
1984 Fiero SE
[This message has been edited by RWDPLZ (edited 11-15-2005).]
