  FAQs & HowTos
  Removing a V-6 Engine - By The Numbers (Page 2)
Removing a V-6 Engine - By The Numbers by Toddster
Started on: 01-01-2008 07:31 PM
Replies: 211 (31948 views)
Last post by: Toddster on 11-11-2020 05:20 PM
Saxman
Total ratings: 114
Report this Post01-04-2008 12:11 AM Click Here to See the Profile for SaxmanClick Here to visit Saxman's HomePageSend a Private Message to SaxmanEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by TK:
I turned mine upside and used a butter knife in the engine bay until it dropped out.
Toddster
Total ratings: 504
Report this Post01-04-2008 12:16 AM Click Here to See the Profile for ToddsterSend a Private Message to ToddsterEdit/Delete MessageReply w/QuoteDirect Link to This Post
In the words of Maxwell Smart, "That's the second biggest butter knife I've ever seen" !
Kuta
Report this Post01-04-2008 09:31 AM Click Here to See the Profile for KutaClick Here to visit Kuta's HomePageSend a Private Message to KutaEdit/Delete MessageReply w/QuoteDirect Link to This Post
replying so I can later (+) you . .. glad to have this thread saved on my computer;
i never would have thought pulling the engine would be possible w/o a lot of #&@!
(hopefully this saves my fingers some grief, should i have to pull anything sooner)
[This message has been edited by Kuta (edited 01-04-2008).]
p8ntman442
Total ratings: 157
Report this Post01-04-2008 03:51 PM Click Here to See the Profile for p8ntman442Click Here to visit p8ntman442's HomePageSend a Private Message to p8ntman442Edit/Delete MessageReply w/QuoteDirect Link to This Post
Big + for the O.P.
Saxman
Total ratings: 114
Report this Post01-04-2008 08:04 PM Click Here to See the Profile for SaxmanClick Here to visit Saxman's HomePageSend a Private Message to SaxmanEdit/Delete MessageReply w/QuoteDirect Link to This Post
Todd, this is for your use in demonstrating how to cut into the frame to free those damn cradle bolts:
For those who have not had the fun of cutting into the frame to loosen the top of a cradle bolt, here is what the bastard looks like when it is out. I had to cut to get to each rear nut.
and here is how the thin metal in the frame holds the nut down -pretty flimsy stuff:
Xanth
Total ratings: 174
Report this Post01-04-2008 08:10 PM Click Here to See the Profile for XanthSend a Private Message to XanthEdit/Delete MessageReply w/QuoteDirect Link to This Post
I had that problem on my Formula, I was able to remove the nuts without cutting the frame. I broke both rear bolts, then punched the nuts up into the frame and pulled them out the back. Then welded new nuts onto the diamond shaped plate and fished them back into place through the frame again.
www.FieroDomain.com
"If any car is both the parade and the rain, it is the Fiero"
Upload and Share Fiero Photos! http://Gallery.FieroDomain.com
kawana
Report this Post01-04-2008 08:35 PM Click Here to See the Profile for kawanaClick Here to visit kawana's HomePageSend a Private Message to kawanaEdit/Delete MessageReply w/QuoteDirect Link to This Post
great writeup you did there, this is very helpful to someone like me who needs visual aids'. Hopefully this will limit the quesitons i have when it comes to taking the 2.8 out. Now, if only someone could come up with an equally good tutorial on putting a 3800sc in its place :P Thanks a bunch.
Saxman
Total ratings: 114
Report this Post01-04-2008 09:21 PM Click Here to See the Profile for SaxmanClick Here to visit Saxman's HomePageSend a Private Message to SaxmanEdit/Delete MessageReply w/QuoteDirect Link to This Post
How did you break the bolts?
Xanth
Total ratings: 174
Report this Post01-04-2008 10:43 PM Click Here to See the Profile for XanthSend a Private Message to XanthEdit/Delete MessageReply w/QuoteDirect Link to This Post
I should have mentioned, they broke when I tried to turn them. The nuts didn't actually break free in the cradle.
[This message has been edited by Xanth (edited 01-04-2008).]
FormulaGT
Report this Post01-05-2008 01:46 AM Click Here to See the Profile for FormulaGTSend a Private Message to FormulaGTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Great thread Todd. Tons of information. I will probably need this someday when I replace the Fieros I have just sold. Thanks!
Toddster
Total ratings: 504
Report this Post01-06-2008 11:47 AM Click Here to See the Profile for ToddsterSend a Private Message to ToddsterEdit/Delete MessageReply w/QuoteDirect Link to This Post
Good Additional info Andrew.
Todd, don't worry, I'll be able to help you replace those Fieros one day. Just worry about the little one for now and guilt your wife something terribly for yur sacrifice.
Saxman
Total ratings: 114
Report this Post01-06-2008 01:30 PM Click Here to See the Profile for SaxmanClick Here to visit Saxman's HomePageSend a Private Message to SaxmanEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'll dump my posts if you decide to add a "cradle bolt removal" section to the beginning of this thread.
Don't forget to add the 88 instructions you mentioned!
Fie Ro
Total ratings: 132
Report this Post01-06-2008 01:51 PM Click Here to See the Profile for Fie RoSend a Private Message to Fie RoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Ah these darn cradle bolts ! I spun one yesterday while putting the new cradle in...incision time lol
User00013170
Total ratings: 224
User on Probation
Report this Post01-06-2008 03:42 PM Click Here to See the Profile for User00013170Send a Private Message to User00013170Edit/Delete MessageReply w/QuoteDirect Link to This Post
Looks like a lot of work to me to get it out the bottom..
I just removed the deck-lid, unhooked the wiring harness, disconnected the fuel lines, all 3 motor mounts, separated transmission from the engine and popped it right out the top. And except for the transmission inspection plate i didn't know about, it was painless and quick and mostly from the top of the car. The only thing that was hard was getting the exhaust manifold loose in the front because the 2 bolts were rusted solid. A quick cut with the Dremel and they were off. It was my first time and took a while but if i had to do it again it would be pretty brainless to do.
Getting it back in wasn't too much harder. Just took some maneuvering with a friend to get the transmission to click back in place.
Car stayed in place on the ground the whole time. no need for a realignment, or deal with the exhaust, brakes, cradle bolts, clutch hydraulics, car sitting up in the air, etc.
[This message has been edited by User00013170 (edited 01-06-2008).]
Toddster
Total ratings: 504
Report this Post01-07-2008 12:38 AM Click Here to See the Profile for ToddsterSend a Private Message to ToddsterEdit/Delete MessageReply w/QuoteDirect Link to This Post
I won't forget. I'm just a little buried at the moment. We had some big storms here and our power was out for 2 days; Just came on this morning.
Toddster
Total ratings: 504
Report this Post01-10-2008 11:52 AM Click Here to See the Profile for ToddsterSend a Private Message to ToddsterEdit/Delete MessageReply w/QuoteDirect Link to This Post
Andrew, I modified Step 34 to include your cradle bolt method.
To all otherts, The Word version with clear large pictures is now updated and available. Just shoot me an email if you want a copy.
Total ratings: 259
Report this Post01-10-2008 12:38 PM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
On step 35 when you loosen the front cradle bolts, I go ahead an pull them and replace them with large phillips screw drivers. Doing so makes step 37 really easy because they slide right out.
Very good write up!
Toddster
Total ratings: 504
Report this Post01-10-2008 01:50 PM Click Here to See the Profile for ToddsterSend a Private Message to ToddsterEdit/Delete MessageReply w/QuoteDirect Link to This Post
Very good write up!
I did that too but the point of the bolt and the point of the screw driver would slip too often so I got myself a steel rod, wrapped a piece of grip tape around one end and drilled the other end with a slightly convex hole. One hammer blow and you have a bolt launcher!
Toddster
Total ratings: 504
Report this Post01-26-2008 07:03 PM Click Here to See the Profile for ToddsterSend a Private Message to ToddsterEdit/Delete MessageReply w/QuoteDirect Link to This Post
FYI, here is that same engine today (topped with a 1988 Intake) in another 1986 GT I am restoring.
BMTFIERO
Report this Post01-26-2008 07:52 PM Click Here to See the Profile for BMTFIEROSend a Private Message to BMTFIEROEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks Toddster for taking the time to post this for us newbies
joesfiero
Report this Post01-27-2008 02:49 AM Click Here to See the Profile for joesfieroSend a Private Message to joesfieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Two little pieces of advice I have: One is to put the front wheels on ramps so you dont have to worry about the cherry picker hitting the back of the car and you dont need the extra links. The next is to leave the brake lines connected to the calipers. just hang the calipers with a coat hanger to the car so as not to damage the lines. This step saves you time after the swap- no bleeding the brakes.
-JOE
sjmaye
Report this Post01-27-2008 05:11 AM Click Here to See the Profile for sjmayeSend a Private Message to sjmayeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Man, why could you not have done this a few weeks ago? I was looking for something like this as I just recently pulled the engine and transmission on my GT.
Nice write up. Will save for the future.
THANKS for taking the time to share this.
Toddster
Total ratings: 504
Report this Post01-27-2008 10:19 AM Click Here to See the Profile for ToddsterSend a Private Message to ToddsterEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'm actually surprised no one has ever posted a thread like it before. I'm going to be starting a new thread soon (as soon as this GT is finished) on pulling the 4 banger; got an Indy with a rod knock.
JesseM
Report this Post01-27-2008 09:11 PM Click Here to See the Profile for JesseMSend a Private Message to JesseMEdit/Delete MessageReply w/QuoteDirect Link to This Post
Ha, in june ill be doing this on my bro's fiero i broke. It had a rod kmock, now it has a rod CLACK CLACK CLACK
thanks for the write-up, do you think you could email it to me
jesterking33@hotmail.com
thanks
The H1 my father, brother and I built.
www.suburbangorilla.com
My Myspace
cars, i build em, drive em, and brake em
Toddster
Total ratings: 504
Report this Post01-28-2008 11:21 AM Click Here to See the Profile for ToddsterSend a Private Message to ToddsterEdit/Delete MessageReply w/QuoteDirect Link to This Post
thanks
Email atcha
Xanth
Total ratings: 174
Report this Post01-28-2008 08:08 PM Click Here to See the Profile for XanthSend a Private Message to XanthEdit/Delete MessageReply w/QuoteDirect Link to This Post
Don't forget I'll host it with full-size pics for you if you're interested
Toddster
Total ratings: 504
Report this Post01-28-2008 08:19 PM Click Here to See the Profile for ToddsterSend a Private Message to ToddsterEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks Xan but It took forever to upload something like 60 pictures and I don't think I want to do it again.
I'll do it on the next thread though!
Xanth
Total ratings: 174
Report this Post01-28-2008 09:52 PM Click Here to See the Profile for XanthSend a Private Message to XanthEdit/Delete MessageReply w/QuoteDirect Link to This Post
The easiest way to upload a lot of pictures is the Gallery Remote, it logs into the gallery, then you just drag all the pictures you want onto the window and click "upload." I just used it to upload about 30 images, just had to select all and drag them on.
The offer is open for any articles you may create.
[This message has been edited by Xanth (edited 01-28-2008).]
sjmaye
Report this Post01-29-2008 04:41 AM Click Here to See the Profile for sjmayeSend a Private Message to sjmayeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Never heard of Gallery remote. What is it and where can you get it?
Xanth
Total ratings: 174
Report this Post01-29-2008 08:55 AM Click Here to See the Profile for XanthSend a Private Message to XanthEdit/Delete MessageReply w/QuoteDirect Link to This Post
Its a java application that makes uploading to the FieroDomain Gallery easier.
http://gallery.menalto.com/wiki/Gallery_Remote
JesseM
Report this Post02-02-2008 05:17 AM Click Here to See the Profile for JesseMSend a Private Message to JesseMEdit/Delete MessageReply w/QuoteDirect Link to This Post
hey thanks for the email, except all the pictures are in PFF code i think, none of them show up in microsoft word, do you think you could re email this to me with the pics?
thanks
My Myspace
Toddster
Total ratings: 504
Report this Post02-02-2008 10:48 AM Click Here to See the Profile for ToddsterSend a Private Message to ToddsterEdit/Delete MessageReply w/QuoteDirect Link to This Post
thanks
Nothing wrong with the pics. Check your settings. Your host may have filtered them out.
JCUOIT
Report this Post02-10-2008 01:24 PM Click Here to See the Profile for JCUOITSend a Private Message to JCUOITEdit/Delete MessageReply w/QuoteDirect Link to This Post
nice write up. is there a larger / 'more detailed' version on FieroDomain yet?
JC
Toddster
Total ratings: 504
Report this Post02-16-2008 10:52 AM Click Here to See the Profile for ToddsterSend a Private Message to ToddsterEdit/Delete MessageReply w/QuoteDirect Link to This Post
JC
No, but I can email you a word version. Just shoot me an email and I'll send a copy over.
intlcutlass
Report this Post02-29-2008 03:16 PM Click Here to See the Profile for intlcutlassSend a Private Message to intlcutlassEdit/Delete MessageReply w/QuoteDirect Link to This Post
Todd , do you also have a 89-90 TGP in the drive?
Also , can you email the "word" version to me as well??
intlcutlass@netzero.net?
[This message has been edited by intlcutlass (edited 02-29-2008).]
Xanth
Total ratings: 174
Report this Post02-29-2008 03:37 PM Click Here to See the Profile for XanthSend a Private Message to XanthEdit/Delete MessageReply w/QuoteDirect Link to This Post
Does the Word version have the larger images?
If you send me the word version I could upload all the images and convert it for FieroDomain myself, I've got the software to make it easier to do.
kyp
Report this Post02-29-2008 06:42 PM Click Here to See the Profile for kypSend a Private Message to kypEdit/Delete MessageReply w/QuoteDirect Link to This Post
ill definitely take one of thos word documents
elenaleerush03@aol.com
newcoolcat
Report this Post02-29-2008 07:01 PM Click Here to See the Profile for newcoolcatClick Here to visit newcoolcat's HomePageSend a Private Message to newcoolcatEdit/Delete MessageReply w/QuoteDirect Link to This Post
when can you repeat step 42? could we maybe bump it up to like 21?
Egor
Report this Post02-29-2008 08:48 PM Click Here to See the Profile for EgorSend a Private Message to EgorEdit/Delete MessageReply w/QuoteDirect Link to This Post
I printed your instructions back about a month ago and put them in a folder.
On Tuesday I used them to pull the engine from my '88. Went right down the numbers. Everything worked great. I even had the problem with the rear cradle bolts, but used the hints from the other threads mentioned to get them out.
The only thing I would do differently next time (actually when I put the new engine back in) is to put some 2 X 12 spacers under the front wheels to get it a little higher. With the front bumper touching the concrete, I only had 3/8" clearance from the top of the engine to the underside of the frame coming out.
GREAT writeup. Congradulations.
Plus for you.
____________________________________________
"Of all the things I have lost during my lifetime, I miss
my mind the most."
Toddster
Total ratings: 504
Report this Post03-03-2008 12:24 PM Click Here to See the Profile for ToddsterSend a Private Message to ToddsterEdit/Delete MessageReply w/QuoteDirect Link to This Post
Only if you think you can do the next 21 steps without slurring your speech..
