  FAQs & HowTos
  Removing a V-6 Engine - By The Numbers (Page 4)
Removing a V-6 Engine - By The Numbers by Toddster
Started on: 01-01-2008 07:31 PM
Replies: 211 (32356 views)
Last post by: Toddster on 11-11-2020 05:20 PM
fyrebird68
Report this Post06-15-2010 03:36 PM Click Here to See the Profile for fyrebird68Send a Private Message to fyrebird68Edit/Delete MessageReply w/QuoteDirect Link to This Post
I edited my earlier post to show rev D (6/15/10)
If you asked for a copy and I didn't answer, please PM me and I'll be glad to send you one.
Bob T.
[This message has been edited by fyrebird68 (edited 06-15-2010).]
bowrapennocks
Report this Post06-15-2010 04:18 PM Click Here to See the Profile for bowrapennocksEdit/Delete MessageReply w/QuoteDirect Link to This Post
Great writeup, but I would like to recommend one change. I do not like to pick the car up by the trunk latch, because it bends the latch. My modification is to remove the trunk latch and replace it with a piece of flat scrap steel, with two holes drilled for the latch bolts and a large hole to allow the crane hook connection. This also has the effect of moving the crane about an inch rearward, making it easier to slide the dolly out. The scrap steel that I used was the spacer that is bewteen the rear struts and the space frame. It is about 6-8" in diameter, 3/16" thick, and already has a big hole for the hook. I only had to drill two holes in it. I used the latch bolts to hold the scrap steel as these are higher grade bolts.
Jim
Toddster
Total ratings: 504
Report this Post06-15-2010 04:48 PM Click Here to See the Profile for ToddsterSend a Private Message to ToddsterEdit/Delete MessageReply w/QuoteDirect Link to This Post
Just as a reminder guys/gals, I am not monitoring this thread daily so if you want a copy be sure to hit the EMAIL button at the top of this post to ask for one. I check my emails regularly.
Toddster
Total ratings: 504
Report this Post07-15-2010 04:15 PM Click Here to See the Profile for ToddsterSend a Private Message to ToddsterEdit/Delete MessageReply w/QuoteDirect Link to This Post
Just now doing a V-6 pull with a 4-Speed Tranny so I will post some pics of the 4-speed removal procedure. Not much different from the 5-Speed but there are one or two things worth noting, stay tuned for pics.
antinull.com
Report this Post08-16-2010 03:11 AM Click Here to See the Profile for antinull.comSend a Private Message to antinull.comEdit/Delete MessageReply w/QuoteDirect Link to This Post
used this guide 2x
my modified fiero had a couple snags with things that were re-located
now taking the parts car cradle out and the front bolts wont budge
I am going to try a bit more hammering after that i will cut the heads of the bolts off with an angle grinder
i would prefer not cutting them with gas lines in the area
lets hope i dont burn the garage down
GADJet
Report this Post11-03-2010 03:13 PM Click Here to See the Profile for GADJetSend a Private Message to GADJetEdit/Delete MessageReply w/QuoteDirect Link to This Post
best write up i have ever seen. got one for a duke?
fiero49
Report this Post11-03-2010 09:28 PM Click Here to See the Profile for fiero49Send a Private Message to fiero49Edit/Delete MessageReply w/QuoteDirect Link to This Post
I used this while removing my v6, great write up. followed it basically step by step... Thanks for posting this Info.
Toddster
Total ratings: 504
Report this Post11-04-2010 11:13 PM Click Here to See the Profile for ToddsterSend a Private Message to ToddsterEdit/Delete MessageReply w/QuoteDirect Link to This Post
Was writing one but never finished it. I will do it when I pull the Indy engine out
ILVMYGT
Report this Post11-28-2010 11:19 AM Click Here to See the Profile for ILVMYGTSend a Private Message to ILVMYGTEdit/Delete MessageReply w/QuoteDirect Link to This Post
I am getting ready to pull an engine assy. Is there a idea height for the dolly. I have one from another project that is 8 inches tall. The one shown in the here is maybe 2 inches taller. Will that make a difference?
RULOOKIN
Report this Post02-16-2011 01:35 AM Click Here to See the Profile for RULOOKINClick Here to visit RULOOKIN's HomePageSend a Private Message to RULOOKINEdit/Delete MessageReply w/QuoteDirect Link to This Post
i am getting close to my drop out day i have read this thread over and over so i think it should be straight forward but i am a bit nervous, i have a hoist and air tools available, but i hope i dont run into any snags i only have a few days on the hoist car has no rust anywhere 3800 will be in soon
dfinn
Report this Post02-16-2011 08:15 AM Click Here to See the Profile for dfinnSend a Private Message to dfinnEdit/Delete MessageReply w/QuoteDirect Link to This Post
I didn't read every page of this post, but I'd like to add something in the event that no one has yet. If the carpeting in the trunk area is pulled back on the wall opposite of the trunk latch, a main frame support will be visible. It has holes that are perfect for a heavy duty chain, i hooked up mine to the hoist and had it up to the ceiling without beating the hell out of my trunk latch. Unfortunately i ended up pulling the motor out the top of the car instead because the cradle bushings froze, but you get the point haha
Toddster
Total ratings: 504
Report this Post04-08-2011 07:07 PM Click Here to See the Profile for ToddsterSend a Private Message to ToddsterEdit/Delete MessageReply w/QuoteDirect Link to This Post
Sorry to be awy for a while guys but work is a killer lately. I had a HD crash on my old computer with the PDF version of this on it so I need to do a new one before I can send it out to anyone. Hang in there
Axdrenalin
Report this Post04-09-2011 04:23 PM Click Here to See the Profile for AxdrenalinClick Here to visit Axdrenalin's HomePageSend a Private Message to AxdrenalinEdit/Delete MessageReply w/QuoteDirect Link to This Post
Nice write up, one I'm sure to reference in the future I'm sure. You think that anyone might still have a copy of the PDF guide that you had sent them before, just for a reference until you get a complete new one written up? Would like to get a copy of it if possible...
DMendez7
Report this Post05-01-2011 10:21 PM Click Here to See the Profile for DMendez7Send a Private Message to DMendez7Edit/Delete MessageReply w/QuoteDirect Link to This Post
Awesome post, looking forward to the new PDF file!
ILVMYGT
Report this Post05-23-2011 11:38 PM Click Here to See the Profile for ILVMYGTSend a Private Message to ILVMYGTEdit/Delete MessageReply w/QuoteDirect Link to This Post
The Aero front ends are lower to the ground then other models. How high does the front end have to start so that when the back end is raised the front does not hit? I have blocks that raise the front end 4 ½ inches. Is that enough?
88 GT 5 Speed Black with gray interior
3800 SCII Swap In Progress
"Real integrity is doing the right thing, knowing that nobody's going to know whether you did it or not."
fyrebird68
Report this Post05-24-2011 02:08 PM Click Here to See the Profile for fyrebird68Send a Private Message to fyrebird68Edit/Delete MessageReply w/QuoteDirect Link to This Post
I put my GT front on those poly ramps when I do this (about 8" tall.) At full "tilt" the nose is about 2" from the floor.
CowsPatoot
Total ratings: 84
Report this Post05-24-2011 05:10 PM Click Here to See the Profile for CowsPatootClick Here to visit CowsPatoot's HomePageSend a Private Message to CowsPatootEdit/Delete MessageReply w/QuoteDirect Link to This Post
Sorry I missed this when you first posted it, Toddster....but I have your old PDF copy of that. I do agree that it is time to freshen it up, but might be easier to start with the old one.
KaijuSenso
Report this Post05-24-2011 07:11 PM Click Here to See the Profile for KaijuSensoSend a Private Message to KaijuSensoEdit/Delete MessageReply w/QuoteDirect Link to This Post
You don't need to raise the front of the car and here is my proof.
I jacked the car up with a 4x4 across the bottom of the car where the jacking points are (with the jack in the middle of the car) like so
got the motor out with plenty of clearance and could even jack the car higher if necessary.
Toddster
Total ratings: 504
Report this Post06-16-2011 02:09 PM Click Here to See the Profile for ToddsterSend a Private Message to ToddsterEdit/Delete MessageReply w/QuoteDirect Link to This Post
Many thanks to Trevor for sending me his saved copy of the word version of this thread. My old PC crashed and took the saved PDF and Word version with it. So now I have a good word version again to share with everyone. If you need it, just send an email and I will forward you a copy.
pontiacfierokid1985
Report this Post06-16-2011 11:04 PM Click Here to See the Profile for pontiacfierokid1985Click Here to visit pontiacfierokid1985's HomePageSend a Private Message to pontiacfierokid1985Edit/Delete MessageReply w/QuoteDirect Link to This Post
This a sweet thread i had no idea hooking up a cherry picker up to trunk latch was the way to raise tje car up to slide the cradle out this will help out alot when im gonna be starting my 3800 swap
FieroGT42
Total ratings: 67
Report this Post07-06-2011 04:53 PM Click Here to See the Profile for FieroGT42Send a Private Message to FieroGT42Edit/Delete MessageReply w/QuoteDirect Link to This Post
Sorry to thread necro but...
Well no, using the trunk latch isn't the right way to do it. I was just talking with someone who did have the whole latch section tear out and the car fell! (Yes they were doing it carefully and on a perfectly rust free trunk). FFS, don't do it unless you really don't care about your car and possible injuries. Now that I've said that, go ahead and do it anyway.
I'll proceed to do it skitime's way (a.k.a. the factory manual way, i.e. the right way). Great post though. I've had this bookmarked since the beginning and I'm finally breaking my cradle bolts loose today. I hope to have the engine out this weekend!
bulldog85043
Report this Post07-07-2011 07:53 PM Click Here to See the Profile for bulldog85043Send a Private Message to bulldog85043Edit/Delete MessageReply w/QuoteDirect Link to This Post
If you've made any updates to this, could you send me a copy with the updates?
Toddster
Total ratings: 504
Report this Post07-14-2011 01:26 PM Click Here to See the Profile for ToddsterSend a Private Message to ToddsterEdit/Delete MessageReply w/QuoteDirect Link to This Post
On the way.
FieroGT42
Total ratings: 67
Report this Post07-19-2011 12:42 PM Click Here to See the Profile for FieroGT42Send a Private Message to FieroGT42Edit/Delete MessageReply w/QuoteDirect Link to This Post
I read in one of these threads that the front wheels should not be blocked because they need to roll. Please correct me if I'm wrong, but I'm pretty sure that's unnecessary and very dangerous. Floor jacks have wheels to allow them to roll because the arm moves toward the pivot point as they raise anyway. They stay in contact with the frame (or in this case the 4x4) and the base moves to accommodate the pivoting jack arm and the pivoting of the car. Having the front wheels blocked is fine because the jack will accomodate this, and not blocking it could let the car roll and fall off of the jack or stands.
Toddster
Total ratings: 504
Report this Post07-19-2011 05:45 PM Click Here to See the Profile for ToddsterSend a Private Message to ToddsterEdit/Delete MessageReply w/QuoteDirect Link to This Post
I think what the person who said "don't chock the wheels" was trying to say is not to chock them from behind. Chock the front side. As you jack the car up the front wheels will tend to roll back a few inches.
nitroheadz28
Total ratings: 94
Report this Post07-28-2011 06:59 PM Click Here to See the Profile for nitroheadz28Send a Private Message to nitroheadz28Edit/Delete MessageReply w/QuoteDirect Link to This Post
I'll be pulling my engine/cradle next week, thanks for the write up.. Sent a request for the word version.
+ for you!!!
Toddster
Total ratings: 504
Report this Post07-29-2011 02:23 PM Click Here to See the Profile for ToddsterSend a Private Message to ToddsterEdit/Delete MessageReply w/QuoteDirect Link to This Post
I've made some updates to this thread which incorporate many of the tips from other posters, new ideas, and corrected some typos even. So my newest version is much cleaner with more details and clearer pics. If you have an old word version just shoot me an email and I will send out the latest version.
Smeaudio
Report this Post07-29-2011 09:29 PM Click Here to See the Profile for SmeaudioSend a Private Message to SmeaudioEdit/Delete MessageReply w/QuoteDirect Link to This Post
This thread helped me out greatly im doing my first swap... first major anything mechanically so this was just great. and for those of you that are afraid the cherry picker isnt too safe to lift the whole car up over the engine then well i took it the next step farther and i lifted the whole car up with the latch before i dismantled anything to put the jack stands under it. It did so with ease. Also to make it even more unsafe i was only using a 1 ton cherry picker from harbor freight. I had to hit the latch with a rubber mallet to get the deck lid to shut properly again because it bent it where it was sticking up a little too much.
Toddster
Total ratings: 504
Report this Post07-30-2011 02:10 PM Click Here to See the Profile for ToddsterSend a Private Message to ToddsterEdit/Delete MessageReply w/QuoteDirect Link to This Post
That's pretty typical.
Thanks for the feedback too
Whuffo
Total ratings: 155
Report this Post08-04-2011 09:33 AM Click Here to See the Profile for WhuffoClick Here to visit Whuffo's HomePageSend a Private Message to WhuffoEdit/Delete MessageReply w/QuoteDirect Link to This Post
What's the title on that Fiero look like, Todd. Did you get it from the Fiero theives John Szpara and Andrew Villsenor?
Really; whose car is that you're stripping?
Just a friendly reminder from a Fiero supporter - if you want to be one of us, you can't steal Fieros from others.
Toddster
Total ratings: 504
Report this Post08-04-2011 09:25 PM Click Here to See the Profile for ToddsterSend a Private Message to ToddsterEdit/Delete MessageReply w/QuoteDirect Link to This Post
In the first place Mike, I bought that car in this thread from someone totally unrelated to the Fiero Club. Secondly, John and Andrew are not thieves and to even suggest that they are makes you look like a complete idiot to ANYONE who knows them. Considering John put a roof over your head when you couldn't keep a job to save your life and used his shop, tools, and parts to make money for yourself without so much as a thanks, let alone rent, one would think you might be show a little gratitude but that is your business. This thread is MY business. It is one of the most referenced threads on PFF and your trolling it up is NOT going to go over well with ANYONE. Take your dirty laundry somewhere else.
Firefox
Total ratings: 240
Report this Post08-04-2011 09:25 PM Click Here to See the Profile for FirefoxSend a Private Message to FirefoxEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'm sure Todd has a legal title to every car he's had. Are you aware what a legal title says on it? It usually has a current address on it so when you abandon your car and it's towed away the tow company can find the owner. Whuffo, do you know where your titles are? Do you know where the cars are that you used to own? Yeah....I thought so. Towed away and gone forever. You should talk to the tow yards that sold your cars and find out that the laws are. Once you abandon the car the tow company tries to contact the registered owners.....at the address on the title. You weren't there? Oops....you lose. Don't blame others for your stupidity.
Whuffo = FAIL
Mike142
Report this Post08-04-2011 10:51 PM Click Here to See the Profile for Mike142Send a Private Message to Mike142Edit/Delete MessageReply w/QuoteDirect Link to This Post
Thank you very much! I'll be doing this this weekend and thanks for sending me the word version of the file!
Toddster
Total ratings: 504
Report this Post08-05-2011 12:05 PM Click Here to See the Profile for ToddsterSend a Private Message to ToddsterEdit/Delete MessageReply w/QuoteDirect Link to This Post
My pleasure. And For the rest of you I have a new updated version of the word and pdf file with added comments and tips
nitroheadz28
Total ratings: 94
Report this Post08-05-2011 12:13 PM Click Here to See the Profile for nitroheadz28Send a Private Message to nitroheadz28Edit/Delete MessageReply w/QuoteDirect Link to This Post
Toddster, thanks for helping us out with this write up and for emailing me the word version!
JazzMan
Total ratings: 653
Report this Post08-05-2011 01:20 PM Click Here to See the Profile for JazzManSend a Private Message to JazzManEdit/Delete MessageReply w/QuoteDirect Link to This Post
You might update the part about crushing the brake hose with vicegrips, our old hoses are very likely to become permanently damaged by crushing them enough to pinch them closed inside, no matter how soft the outside padding material used may be. If one insists on disconnecting the calipers it's better to use a rubber or silicone plug in the end, use vacuum plugs from the auto parts store. Also, you might add the tip that if you don't want to disconnect the brake lines you can unbolt the calipers and leave them with the car, hung up to the steel inner fender bodywork using bent coathangers. This option eliminates a mandatory brake bleeding session, which some readers would probably want to do.
This thread is ... one of the most referenced threads on PFF...
If view count is any indication, my steering column thread has almost fifty nine thousand views compared this thread's fourteen thousand. FWIW...
[This message has been edited by JazzMan (edited 08-05-2011).]
Toddster
Total ratings: 504
Report this Post08-06-2011 09:03 PM Click Here to See the Profile for ToddsterSend a Private Message to ToddsterEdit/Delete MessageReply w/QuoteDirect Link to This Post
I actually debated this with myself. I don't recommend Vise grips for the brake lines, I recommended a line clamp that you can get from the auto store or just tucking them aside. I elected not to mention the option of leaving the capilers attached for a couple of reasons; the first is that I truly recommend bleeding the brakes. Dot 3 is hydro static and I have seen very few break lines that did not need a good cleanout. As such, I think it would suck big time to swap out that engine only to have your brakes fail at the wrong time. But also, in the rust belt, it is hard to get the calipers off sometimes and not worth the trouble of doing it on the car but easier with the cradle out of the way. Naturally, people can do it anyway they like but I find it a rather simple operation to bleed the brakes after the install and in the end, I believe it saves more time and leads to a better result.
I must account for about 30 of those clicks myself. a GREAT thread! When it comes to valuable Fiero content, I am down-right a-political.
fierobear
Total ratings: 382
Report this Post08-07-2011 01:41 AM Click Here to See the Profile for fierobearSend a Private Message to fierobearEdit/Delete MessageReply w/QuoteDirect Link to This Post
I just hang the calipers. I keep a bundle of drop ceiling wire in the shop, and cut and bed a piece to suit. Ceiling wire has 101 uses.
Toddster
Total ratings: 504
Report this Post09-20-2011 05:46 PM Click Here to See the Profile for ToddsterSend a Private Message to ToddsterEdit/Delete MessageReply w/QuoteDirect Link to This Post
Those asking for copies please remember to email me rather than PM. It makes it easier to reply with the file attachment. Thanks
SE85
Report this Post09-20-2011 06:32 PM Click Here to See the Profile for SE85Send a Private Message to SE85Edit/Delete MessageReply w/QuoteDirect Link to This Post
Todd, Appreciate the quick response. The manual is color printed and bound and will be used this weekend. This is going to save many hours work....a plus for you.
