  FAQs & HowTos
  Upgrade to CS130 alternator
Upgrade to CS130 alternator by fierosound
Started on: 03-15-2014 10:34 AM
Replies: 11 (5830 views)
Last post by: 82-T/A [At Work] on 09-24-2023 07:46 PM
fierosound
Total ratings: 286
Report this Post03-15-2014 10:34 AM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
The CS130 used on the 88 Fiero V6 is an upgrade to the earlier SI units.
It's more compact, better designed and better performance.
I have them on both my 87 GT V6 and my Indy's SD4 engine (pictured below)
They are a direct fit (mounting ears are 180 degrees apart) and only required a connector change.
Get the 88 V6 CS130 alternator - 105 amps (swap your pulley to it if needed).
See Cave http://web.archive.org/web/.../wombatcs/csalt1.htm
AC Delco number 334-2284 - 105 amp unit
Delco's vehicle list for wrecking yard diving
Look for the cars with A/C on them.
BUICK(5)1986-1988
SKYLARK(3)1986-1988
1988 V6-181ci 3.0L F/I Vin L
1987 V6-181ci 3.0L F/I Vin L
1986 V6-181ci 3.0L F/I Vin L
SOMERSET(1)1987-1987
SOMERSET REGAL(1)1986-1986
OLDSMOBILE(3)1986-1988
CALAIS(2)1986-1987
CUTLASS CALAIS(1)1988-1988
PONTIAC(3)1986-1988
FIERO(1)1988-1988
1988 V6-173ci 2.8L F/I Vin 9
GRAND AM(2)1986-1987
You'll have to replace the wiring end connectors, or get an adapter from Rodney or others.
http://rodneydickman.com/pr....php?products_id=361
keywords: Fiero SD4, Pontiac SD4, Super Duty 4, SD4 engine, SD4, Fiero Pace Car,
[This message has been edited by fierosound (edited 11-10-2022).]
Report this Post03-15-2014 10:59 AM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Also see my Cave, Rabid-Wombat's CS-130 Conversion for 85-87 V6.
Older L4 use same parts but need to switch pulleys.
[This message has been edited by theogre (edited 03-15-2014).]
Csjag
Report this Post03-16-2014 10:13 PM Click Here to See the Profile for CsjagSend a Private Message to CsjagEdit/Delete MessageReply w/QuoteDirect Link to This Post
Wow that is one beautiful SD4! What is its horsepower rating?
fierosound
Total ratings: 286
Report this Post05-01-2014 09:15 AM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
CS130 - 140amp, 170amp and more...
https://alternatorparts.com/cs130-alternator.html
If those aren't enough power, there's a 220A rebuild kit available.
https://www.aspwholesale.co...rade-kit-p12424.html
[This message has been edited by fierosound (edited 07-21-2020).]
fierosound
Total ratings: 286
Report this Post05-01-2014 09:16 AM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
fierosound
Member since Nov 1999
Thanks. We're thinking 250hp. It DOES NOT feel like 4-cylinders when driving.
fireboss
Total ratings: 58
Report this Post06-04-2014 03:05 AM Click Here to See the Profile for firebossSend a Private Message to firebossEdit/Delete MessageReply w/QuoteDirect Link to This Post
If the 105 amp rating isn't enough power, there's a 220A rebuild kit available.
http://aspwholesale.com/ind...wProd&productId=5159
Would there be any problems with this 220 amp upgrade on stock charging system..
Inferno
Report this Post06-04-2014 11:49 AM Click Here to See the Profile for InfernoSend a Private Message to InfernoEdit/Delete MessageReply w/QuoteDirect Link to This Post
To answer your question. No.
Simplist way to answer this without getting into electrical hoohaw. More AMPS will not damage your system. As the Alternator only provides what is needed for the electrical systems load requirements. It is much worse when you dont have enough AMPS then having too much available.
Kevin87FieroGT
Report this Post01-10-2016 09:10 PM Click Here to See the Profile for Kevin87FieroGTSend a Private Message to Kevin87FieroGTEdit/Delete MessageReply w/QuoteDirect Link to This Post
bHooper
Report this Post02-13-2019 02:59 PM Click Here to See the Profile for bHooperSend a Private Message to bHooperEdit/Delete MessageReply w/QuoteDirect Link to This Post
Question.... I have the cs130 from the 87-91 Corvette. Any issues with that alternator? Also, do I need to add the heat shield?
fireboss
Total ratings: 58
Report this Post02-26-2019 02:46 AM Click Here to See the Profile for firebossSend a Private Message to firebossEdit/Delete MessageReply w/QuoteDirect Link to This Post
as long as the mounting ears are in the same position it will....no heat shield needed. I left the cooling tube in mine..
HanksGT
Report this Post05-22-2022 05:16 PM Click Here to See the Profile for HanksGTSend a Private Message to HanksGTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks for all the advice in this thread. I decided I wanted brand new and more power, so I got a 47802 Powermaster for an '88 Fiero GT for our '85 GT. The new unit comes with a test output card for your unit. Ours showed 103 amps at idle and 138 at high speed. Now I can run the A/C, lights and factory fan at idle and not drop down to 12.8 volts on a digital gauge.
I removed the right rear toe control arm and lost the slotted nut (m12 x 1.25) but it made it easier to swap than moving brake lines.
Good thing I checked the fit of the new unit in to the stock bracket BEFORE i put it back in. There was no way I could have wiggled it in, so I did a quick clean up on the bracket where the top of the alternator goes. I cleaned the old pulley with a wire brush and brake clean and mounted it using the new fan, since the stock fan rubbed on the new PM. I used a ruler to check the location of the old pulley height to alternator then matched it on the new one, shimming as needed.
A helper would have been great when trying to put the new unit back in. I got the bracket and alternator in place, then put two bolts loosely in the bracket to engine. Followed that by bolting on the BATT lead and didn't use ANY connector for the excite wire, it's already internal on these and since we don't have an idiot light, just a gauge we didn't need to wire to 2 to 4 pin adapter. Then the belt went on. I put the bolt in the bottom of the alternator to bracket then wiggled the top mount into the bracket in from underneath.
Several hours but well worth it.
Total ratings: 200
Report this Post09-24-2023 07:46 PM Click Here to See the Profile for 82-T/A [At Work]Send a Private Message to 82-T/A [At Work]Edit/Delete MessageReply w/QuoteDirect Link to This Post
Hey guys, I'd like to upgrade to the newer alternator for my daughter's 1985 Pontiac Fiero 2m4. So the only thing I need to do is buy the NEWER alternator, swap out the pullet from the older one onto the newer one, and then get the adapter connector from Rodney Dickman?
Thanks!
