  FAQs & HowTos
  Swapping in a newer Getrag transmission
Swapping in a newer Getrag transmission by fierosound
Started on: 04-15-2015 01:05 PM
Replies: 10 (4947 views)
Last post by: fierosound on 05-23-2023 11:29 AM
fierosound
Total ratings: 287
Report this Post04-15-2015 01:05 PM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
Information pulled together from several threads (thanks guys).
Wiki on transmission: https://en.wikipedia.org/wi...rag_282_transmission
These are circa 1989-1994 Berreta/Cavalier Getrag trannys - note location of arm on clutch fork - INSIDE the bellhousing.
Some may have HTOB (Hydraulic Throw Out Bearing - also useable)
If they come from a V6 car, the transmission will bolt directly to the V6 2.8L V6.
Sometimes you may find a Quad-4 Getrag that's too good to pass up (new or low miles)
You can have a transmission shop change the bellhousing half of the Quad-4 Getrag transmisson to a V6 bellhousing.
Tips: https://www.fiero.nl/forum/A...100421-2-095259.html
With a Quad-4 trans you'll need the bellhousing from a V6 Getrag (you probably have a worn out V6 tranny anyway)
When you swap an original Fiero bellhousing, you'll only need the Cable Linkage Conversion Kit below.
Here's the scoop on parts needed for newer FWD V6 Getrag transmission as pictured above in our Fiero application.
In some cases you may have to split the case to change the gear for the VSS. (speedometer)
Dickman has the gear $25: http://rodneydickman.com/pr....php?products_id=330
Instructions with pictures https://www.fiero.nl/forum/A...120111-2-104858.html
You use this transmission with stock Fiero Getrag 5-speed shift cables and stock clutch slave cylinder.
Use the stock Fiero select cable bracket - or new one from Rodney if you don't have one. $24
rodneydickman.com/product_info.php?products_id=184
You will need these FWD transmission conversion items from Rodney...
- cable linkage conversion kit $75
http://rodneydickman.com/pr...o.php?products_id=58
- shift cable bracket $67 (if you don't have factory one)
http://rodneydickman.com/pr....php?products_id=184
- slave cylinder adapter $55
http://rodneydickman.com/pr...o.php?products_id=52
Dickman's brackets (in blue) pictured below. Slave cylinder bracket not shown here.
Calgary time/temp
[This message has been edited by fierosound (edited 02-03-2022).]
fierosound
Total ratings: 287
Report this Post04-15-2015 01:12 PM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
The bracket for the Select Cable will need to be bolted on.
The transmission already has pilot holes that need to be drilled and tapped for the bolts.
Here are close up pics of what has to be drilled, and one with the select bracket installed.
[This message has been edited by fierosound (edited 05-20-2016).]
fierosound
Total ratings: 287
Report this Post04-15-2015 01:14 PM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
fierosound
Member since Nov 1999
Reverse light switch...
Original switch GM part number is 10075403 (from P22 parts book - but GM likes to recycle numbers)
http://www.gmpartsdirect.co...&partnumber=10075403
http://www.gmpartsgiant.com...tch-as-10075403.html
Fiero Store original type switch http://www.fierostore.com/P...%20%205SPD&d=342&p=1
An alternative http://www.reddevilriver.com/Related_Products.html
[This message has been edited by fierosound (edited 04-06-2018).]
Total ratings: 461
Report this Post11-21-2015 04:14 PM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
Dickman has the gear $25: http://rodneydickman.com/ca...h=28&products_id=330
Instructions http://www.rodneydickman.com/n36.html
With pictures http://centralfloridafieros...dex.php?topic=1119.0
The later Getrags have a magnetic VSS that produces ~24,000 PPM. This will match up to a lot of the later PCMs. (Matched the 4.9, perfectly.)
It may also work with a 7730, depending upon the application.
You will still need the buffer circuit to connect with the speedo output of the PCM, and the speedometer.
fierosound
Total ratings: 287
Report this Post07-11-2016 07:40 AM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
Getrag 5-speed cable routing.
http://www.meisners.net/Fiero/TSB/TSB88714.htm
DonP
Report this Post05-28-2017 04:53 PM Click Here to See the Profile for DonPClick Here to visit DonP's HomePageSend a Private Message to DonPEdit/Delete MessageReply w/QuoteDirect Link to This Post
We're looking for a back-up transmission to use in our Fiero-truck Lemons vehicle. Is there any information on the specific vehicles the Quad-4 Getrag were found in? We have the spare bellhousing already available from a blown 282.
Thanks!
fierosound
Total ratings: 287
Report this Post04-06-2018 01:17 PM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
Getrag MG-284 w/Quad 4 engine
Chevrolet Lumina, Oldsmobile Cutlass Supreme, Pontiac Grand Prix,
Quad 4 engine
https://en.wikipedia.org/wiki/Quad_4_engine
Getrag w/Q4
[This message has been edited by fierosound (edited 04-07-2018).]
fierosound
Total ratings: 287
Report this Post05-07-2020 09:13 PM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
Regarding using Quad-4 FWD Getrag trannys with swapped bellhousing...
[This message has been edited by fierosound (edited 05-08-2020).]
fierosound
Total ratings: 287
Report this Post05-23-2020 12:05 PM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
Facebook FIERO Group has a files download section with manuals.
Join group and download Muncie_Getrag 5-speed.pdf
https://www.facebook.com/groups/2204429635/files/
[This message has been edited by fierosound (edited 05-23-2020).]
Trinten
Report this Post04-28-2021 07:04 PM Click Here to See the Profile for TrintenSend a Private Message to TrintenEdit/Delete MessageReply w/QuoteDirect Link to This Post
For those of us that don't have facebook, if you want to send me the files, I can host them and put up a link here so anyone can download them.
fierosound
Total ratings: 287
Report this Post05-23-2023 11:29 AM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
Another site with PDF manuals and more
https://fieroinfo.com/
