  FAQs & HowTos
  How to : Seperate Fastback Tail Lights without damage
How to : Seperate Fastback Tail Lights without damage by Danyel
Started on: 09-08-2015 10:56 PM
Replies: 7 (2696 views)
Last post by: Vintage-Nut on 01-18-2025 09:37 AM
Danyel
Total ratings: 169
Report this Post09-08-2015 10:56 PM Click Here to See the Profile for DanyelClick Here to visit Danyel's HomePageSend a Private Message to DanyelEdit/Delete MessageReply w/QuoteDirect Link to This Post
The secret to removing the lenses from the assemblies without breaking them is as follows:
1. Use a HAIR DRYER to heat the contour of the lenses where they latch together and also all around where they make contact with the rear assembly. This is to make sure the butyl that seals the lenses to the assembly gets hot and soft. (Hot to the touch NOT BURNING HOT) (DO NOT USE HEAT GUN WAY TOO HOT )
2. You will notice there are V shaped latches with plastic hooks inside, on the top and bottom of the lenses that hold everything together ... DO NOT PRY UP THESE LATCHES with a screwdriver !!!! You must slide a piece of plastic about the thickness of a credit card in between the latch and the hook so that the hook releases. (See Pic Below) Once you've inserted all the cards and the hooks have released reheat the contour a little more ....gently pull apart the two making sure all your latches are unhooked. You will see the lenses will spread and open...
3. Once apart let the butyl cool.... it is easier to clean up and remove the old when cold. You can put new sealant butyl that can be bought in any good automotive shop... the strip maybe thicker but you can stretch it thinner to fit in the slot and reseal the lenses.....
Take you time and be CAREFUL these lenses are VERY VERY BRITTLE
Have fun
My Build Thread
Tylers Toy
cam-a-lot
Total ratings: 97
Report this Post09-10-2015 09:41 AM Click Here to See the Profile for cam-a-lotSend a Private Message to cam-a-lotEdit/Delete MessageReply w/QuoteDirect Link to This Post
Great tip
Can you please send me your new OEM set so I can practice on it? I promise to return them, unless they mysteriously get lost in the mail. You know... like swap harnesses regularly do in Canada
Or perhaps you can give me your address and exact location of where you keep the lenses and other goodies, so I can pay you a quiet 3 AM visit next time I am in Froggieland And don't forget to leave the doors unlocked before going to bed!
Danyel
Total ratings: 169
Report this Post09-10-2015 10:59 AM Click Here to See the Profile for DanyelClick Here to visit Danyel's HomePageSend a Private Message to DanyelEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by cam-a-lot:
Great tip
No problem .... if you come to visit .... as long as you like Rottweillers....his name in Mushy .... called him that because I gave him a metal hammer to play with.....when he was finished with it... the damm thing was all soft and mushy
regards
Danyel
PS do you know why they call us FROGs ?? Ie Froggieland?
2tone86gt
Report this Post09-28-2015 08:25 PM Click Here to See the Profile for 2tone86gtSend a Private Message to 2tone86gtEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks for the tip danyel... Hopefully another set of unused fiero store lenses show up on ebay again i'd love to give this a try to restore mine.
fierobear
Total ratings: 382
Report this Post07-26-2021 12:37 AM Click Here to See the Profile for fierobearSend a Private Message to fierobearEdit/Delete MessageReply w/QuoteDirect Link to This Post
Have fun
A putty knife also works for this.
Australian
Report this Post08-12-2021 04:40 AM Click Here to See the Profile for AustralianClick Here to visit Australian's HomePageSend a Private Message to AustralianEdit/Delete MessageReply w/QuoteDirect Link to This Post
The mastic will stick to everything so if you get it on hands stop what you are doing and use some alcohol to clean hands before you smear it over both sides of lenses.
Old Lar
Total ratings: 214
Report this Post05-21-2022 08:25 PM Click Here to See the Profile for Old LarSend a Private Message to Old LarEdit/Delete MessageReply w/QuoteDirect Link to This Post
Separating the lens from the back was the hardest part of the swap for me. I sprayed some penetration oil on the seam. I had a plastic putty knife to get the clip apart. Very carefully prying the clip apart.
Vintage-Nut
Report this Post01-18-2025 09:37 AM Click Here to See the Profile for Vintage-NutSend a Private Message to Vintage-NutEdit/Delete MessageReply w/QuoteDirect Link to This Post
Danyel:
The 'Real' Secret to Lower the Risk of Plastic Breakage - Use SUMMER HEAT
IMHO: Don't even try in cold weather as decades old plastic can easily break...
My Advice:
1) Remove the taillight assemblies from the vehicle and then sit them in the summer sun for an hour to warm-up the plastic and soften the butyl seal
2) Use Danyel's Separate Strategy and the trick is 'slowly' spread the warmed lens from the soften butyl seal in the housing. Starting at one end; cautiously pull apart the housing hooks from the lens tabs one-by-one to open the assemblies.
3) I disagree with Danyel on this step; to me it is easier to remove the old butyl seal when warm. I removed and cleaned up any butyl seal from the housing using a small screwdriver...
After removing all the butyl seal in the sun, now let the housing cool. When cool, use isopropyl alcohol to remove all traces of the old butyl seal.
Taillight REFLECTOR: Don’t Paint, Light Reflects BRIGHTER on Polished Aluminum Tape !
https://www.fiero.nl/forum/Forum2/HTML/148286.html
I brought 3M Windo-Weld
Reassembly:
*Install the butyl strip to fit into the housing slot/track
*Place the taillight parts in the summer sun for an hour to warm-up the plastic and soften the butyl seal
*Mounted the brake light / turn signal inserts into the lenses and the red "PONTIAC" inserts on the housings
*Align and firmly press the lens into the housing until all the tabs lock into the hooks
*Let the taillight assemblies cool before installing them into the vehicle
[This message has been edited by Vintage-Nut (edited 07-12-2025).]
